MY09 White dials for 2.0TDI what part number?
~RS~ Jan 30, 2011
  1. ~RS~
    ~RS~ Active Member
    1,466
    22
    Which one of these part numbers is the correct one for the A3 2.0TDI, I want to retrofit the MY09 cluster into my 05 2.0TDI have read NHN's thread on doing the mod so just need to get the right pn for the cluster and Audi to code.
    8P0 920 951 RX
    8P0 920 950 SX
    or is the latter just a revision? My current one has DIS do the 2 above have DIS?
    Cheers?
  2. N8
    17,163
    718
    Not sure brother! I would whip mine out but I ain't got the car lad atm :wacko:
  3. ~RS~
    ~RS~ Active Member
    1,466
    22
    Cheers mate, I think a few people here know but getting straight answers these days is like getting blood out of a stone!:tapedshut:
  4. micasb
    micasb Member
    327
    HI mate,
    I retofitted the white cluster and the one i used was 8P0920931S.
    Regards
  5. ~RS~
    ~RS~ Active Member
    1,466
    22
    Cheers mate, the few I have seen on ebay are listed as being for a 160mph Diesel. but those have the part numbers I listed above, maybe they changed the pn's? Does yours have DIS?
    Anybody with etka that could give pn or check one's I have posted would be appreciated!
  6. micasb
    micasb Member
    327
    Sorry that PN is for km/h :(
    I'll check ETKA. 5 minutes.
  7. micasb
    micasb Member
    327
    8P0920982JX is for mph and DIS but for A3 from 25/05/2009 Don't know if the IMMO is the same as yours 05 model.
    8P0920982CX is for A3 before 25/05/2009 wich i think has the same immo version.
    Etka info.
    Regards
  8. micasb
    micasb Member
    327
    Both diesel dials
  9. micasb
    micasb Member
    327
    The ones you supplied on the first post are for gasoline engines.
  10. micasb
    micasb Member
    327
    Mind that the X on the end of the PN reffers to a refurbished part... :) the real PN is without the X
    Regards
  11. ~RS~
    ~RS~ Active Member
    1,466
    22
    Schizer! so none of those are good for me then?! What's this about immo being different must have missed that in NHN's thread on retrofitting. Though was just pump and washer level sensor that needed fitting if car was pre 05- facelift... Any more details would be appreciated bro as you have done this already.
  12. micasb
    micasb Member
    327
    I only mentioned the IMMO because they have those timelines on the parts... before and after 25/05/2009...
    I was told that those after 25/05 didn't fit mine...
    Mainly when i want to upgrade a module i always search parts before that date. I think after that they changed the electrics of the car, namely different CE module and others, so it would be logic to think those clusters would not fit our older cars...
    But that's me thinking :)
    NHN maybe knows something about this.
    Regards
  13. ~RS~
    ~RS~ Active Member
    1,466
    22
    Ahhh, OK I see now... Thanks micasb. A mate has told me that he maybe able to source another TDI one so I'll see what PN that one has, hopefully NHN will chime to confirm what you've said.
    Thanks for taking the time to check it out for me mate :)
  14. N8
    17,163
    718
    You have to get Audi to code it either way...
  15. NHN
    29,284
    1,695
    Immo hasnt changed on the 8P since inception, even the newer keys (I also did a thread on) work with older 8P's, so any TDI cluster will do as long as its correct for your car interms of mph or kmh.
    Dates in etka for me dont mean to much, as long as you do research, which I always do, as imperative on modding, then you should know for sure if will work or not.
  16. micasb
    micasb Member
    327
    That's ok ;) That's what we're here for...
    I only got the one before that date because my friend at Audi told the newer one wouldn't work...
    But if the modgod says it does i'll believe it... :)
    Best regards.
  17. roston100
    roston100 Member
    370
    does anyone have a picture of these? would be interested how they look
  18. NHN
    29,284
    1,695
    I did a whole thread on this, use the search function & you'll find it.
