My xenons look low?
rickyquicky Aug 20, 2011
  1. rickyquicky
    rickyquicky Member
    342
    Is there a way to adjust the xenon headlights?
    Mine have suddenly decided to 'dip', they are definately a lot lower tonight :think:
  2. roman3000
    roman3000 Member
    316
    Have you checked the sensors are not broken, front and rear?
  3. h5djr
    9,438
    1,757
    When you turn on the ignition with the headlights on, they should dip down and then come back up again to the correct position. Is this happening?
  4. rickyquicky
    rickyquicky Member
    342
    Thanks guys, turned out to be a broken sensor :icon_thumright:
  5. DaveA3-TDI
    DaveA3-TDI Member
    249
    I notice that mine seem to wobble when I drive over bumpy roads and you can see the light out the front of the car wobble as well. Mine is a 07 S-Line so is this normal as the suspension is a bit harder than normal a3's?
  6. RU55SSO
    RU55SSO Member
    792
    24
    Mine don't move at all
  7. Vertigo1
    Vertigo1 Well-Known Member
    3,609
    705
    Mine "shimmer" a bit sometimes when driving over sudden bumps etc. Figure it's just the levelling system moving a bit as the car shakes, never found it to be a problem.
  8. macpdm
    macpdm Member
    403
    Mine dont move either but they do seem a little low.
  9. DaveA3-TDI
    DaveA3-TDI Member
    249
    thanks for the responses, is there anything I can check to make sure nothing is broken?
  10. Khufu
    Khufu Well-Known Member
    5,704
    31
    I dont think my move either when I switch them on.
    Dave, are you sure its not that the xenons have a more distinct cut off compared to halogen and so its more obvious when you go over bumps?
  11. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,267
    163
    When i switch mine on the drop down to shine about 6ft in front of the car, they then go up to slightly above horizontal and then drop to normal dip position. All this takes 3 seconds tops. Exactly as Dave says.
  12. jungleman
    jungleman Well-Known Member
    2,035
    42
    same as mine, though mine do a wiggle to the left and right as well as ive got adaptives
  13. paddy
    5,267
    163
    Ha..mine wink at other S3's :)
  14. roman3000
    roman3000 Member
    316
    Don't know if you've bought a new sensor yet but its the same sensor in some seats and vw's. I got mine of ebay last year for approx £40 (used one)
  15. Khufu
    5,704
    31
    I got both mine off ebay too for the same price (eventully) they are £110 new :-(
