my vacuum woes
DaveA3 Nov 30, 2010
  1. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    Hi All,
    I swapped my boost gauge over to a brand new one as i dropped my old one on the floor and it had a mind of its own. Anyway now i can see proper reading i realised last night that my vacuum is a bit all over the shop:
    It starts at -20hg as normal
    Then if i put a bit of throttle on idle or moving it goes down to -26hg then after a while it goes to -25hg -26hg bouncing between the two each time i left off the throttle. if i idle after a lil drive it sits at -26hg.
    Does this mean i have a leak somewhere? :think:
    cheers
  2. S3BAM
    S3BAM Member
    362
    Most probably i changed all the boost hoses on my old scooby had same prob cable tied them all up cured it.
    What gauge are u running as some cheaper runs seem to flutter a bit my Led one(already on car when i bought it) on my Octy Vrs flutters a little
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    you can put a little reducer in the pipe that stops the fluttering
  4. DaveA3
    2,370
    15
    yeh i have the reducer and it does stay steady on the number its reading but it just doesnt sit nicely. i cable tied all the pipes a few months back i should get to see if i missed one anywhere. i think its the pipe off the manifold that has the check valve in between as i have a blue silicone one on instead as my standard one was split. I remember the originalone has a reducing pipe inside the end so its probably not as snug as that. hmm ill have a think and check it out later :)
    cheers
  5. <tuffty/>
    21,965
    4,240
    Idle vacuum is less on initial start up as the throttle is held open more on cold start/fast idle until warm... the idle vacuum should increase once past that and will also increase when you let off the throttle as the ECU will close the throttle completely... you will see this for example if you are off the throttle going down a hill...
  6. DaveA3
    2,370
    15
    ahh i see but would u say that -26 is still a leak somewhere?
  7. <tuffty/>
    21,965
    4,240
    If you had a vac leak then I would expect the vac figure to be more positive than negative...
  8. DaveA3
    2,370
    15
    hmm ok just strange how i can have more vacuum than normal lol
  9. <tuffty/>
    21,965
    4,240
    Because by changing the boost gauge you fixed a leak?
  10. DaveA3
    2,370
    15
    not that i mean i thought the standard vacuum was -18 to -20 but somehow i have more. guess im just being paranoid
  11. s3dave
    10,110
    736
    Is it a cheapish gauge Dave? it may not be calibrated correctly...-26 would mean your rev counter would be showing 6/700 nearly stalling?
  12. DaveA3
    2,370
    15
    it was £40 not a cheap one at all really. At full boost it holds at 18psi and sits at 0 when off etc
