My suspension sits lower in the back than the front
9 below zero Jan 12, 2010
  1. 9 below zero
    9 below zero Member
    76
    Why?
    I've just had it lowered 40mm all around and i can just about get my finger inbetween the arch and rear wheel but on the front i can fit my whole fist in. (oooh, sailor)
    Now the garage told me it will settle but these have been fitted to a car for 100 miles before mine so i dont think they will.
    On the front suspension he put the spring with the touching coils at the top, is this correct?
    I've just taken a pic of it now but it's snowing and dark so it's not so clear, but i'll try uploading it...
  2. aragorn
    18,306
    807
    Sounds like they're off the wrong car?
    IE V6 springs on a 4cyl or something?
  3. 9 below zero
    9 below zero Member
    76
    it's a standard 1.8 petrol 5v
  4. Sandip
    2,450
    91
    Are they supersport springs by any chance?
  5. aragorn
    18,306
    807
    Springs are probably for a different model, either incorrectly packaged or badly made.
  6. s4 osh
    s4 osh Member
    41
    i have also got this 'problem' and trust me it doesnt settle. the spring i have are apexi, good set massive difference, would 'sport' top mounts solve the issue or are they the same size as oem??
    another words i should have spent on full adjustables i know
  7. Broken Byzan
    13,237
    465
    Not sure why this happens but it seems common on SE cars.
    When i lowered my SE on Eibach springs it was the same, i ended up removing the rubber/alloy insulator from the bottom.It sits between the spring and the shock sring cup. That made a huge difference, but it was still too high for me so i pikey'd it and removed the end off the spring with a grinder. She was a nice stance then.
    I did however migrate to coolies afterwards for adjustability sakes.
  8. aragorn
    18,306
    807
    If its a progressive spring, cut the top coil off and see how that goes.
