My Stealth S3 has been to hell with regards remaping )Need advice)
madalex Nov 28, 2007
  1. DemianM
    DemianM RWD sucks!
    175
    Can someone post which is the NGK iridium plug you used?? thanks!
  2. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    I'm sure they were: F6KPP332S (Bosch OE part number)
    and this translates into:
    BKR6EIX (NGK Platinum)
    or
    PFR6Q (as NGK standard OE replacement items)
    cheers
    Warren
  3. mister.c.
    mister.c. Active Member TeamMisano Audi A3
    676
    131
    43
    Has the Original issue been solved?
  4. DemianM
    DemianM RWD sucks!
    175
    Bump from the dead! I just got a remap, and my car now throws a DTC for misfire at 6300 rpm (happened in 3rd gear). I had previously installed NGK plugs, which I am now going to remove and try the OEM ones.
    Is there any update?
  5. boggysv
    boggysv Member
    573
    misfiring at 6.3k rpm after remap? sounds awfully similar to this.
    http://www.audi-sport.net/vb/showthread.php?t=51689
  6. phantom
    phantom On Boost
    1,750
  7. DemianM
    DemianM RWD sucks!
    175
    Thanks boggy! Just the same as my case!!
  8. newbiecrg
    newbiecrg windsurfer
    1,328
    This misfire thing... 6300 RPM is almost touching redline... has anyone considered that the misfire might be a feature to make you realise you are close to blowing your engine?
    Like a pre warning until engine limiter kicks in? Just a thought....
    Pedro
  9. julians
    julians Member
    312
    no flat spot/misfire on mine at any rpm, mine is totally standard, pulls cleanly all the way to the limiter.
    The rev limiter comes in gradually from about 6800rpm and totally stops you going past around 7000rpm.
  10. newbiecrg
    1,328
    same here... no misfires as well... but one never knows....
    Pedro
  11. DemianM
    DemianM RWD sucks!
    175
    Not at all! In fact the car is quite eager to rev still at those revs!
    The problem has to do with a misfire of some sort which got accentuated by the remap :(
  12. whiteunderarm
    whiteunderarm Member
    81
    Who did your remap?
  13. DemianM
    DemianM RWD sucks!
    175
    APR, but that does not seem to be the cause (the map itself) because other forum members are experiencing a very similar issue! Misfires above 6000 rpm which are worse once chipped :(
  14. whiteunderarm
    81
    Take it back to the dealer...let them sort it out..if it was misfiring before the remap why didnt you have it checked out??
