My spacers
DJ-S3 Dec 24, 2012
  1. DJ-S3
    DJ-S3 Active Member
    690
    43
    Hey everyone. Had my spacers fitted to the rear wheels 10mm ones and they don't look to fill the arches... My car is a S3 56plate with original wheels. I was thinking of moving the 10mm spacers to the front and getting some 12mm (actually 13mm as there FK's) for the rears. What does everyone think?
    Will there be any rubbing? I don't think there will as there's still a significant gap to fill the wheel arch. So I was thinking 15mm spacers?? Has anyone else experience this with a s3 the same age?
    Hope everyone has an amazing Christmas and a very drunk new year!!
    Dom
  2. poli84
    poli84 Member
    425
    57
    I'm running 12mm rear on my OEM S3 wheels (ET54), 225 tyres and on coilovers.
    Even with arch screw removed, I get rubbing when I have back seat passengers.
    Thinking of changing to 10mm myself.
  3. KemiksiZ
    KemiksiZ Active Member
    570
    142
    43
    Poli, u should get some -2 ish camber so :))
    I ran with et35 - 9 inch rims, I almost dont have rubbing anymore.. Even we are 4 in the car.. ( Except big bounces.. )
  4. AdriansS3
    AdriansS3 Member
    77
    How do people find the tyre wear when you increase the rear camber as I imagine the inside edges would wear very quickly?
    How much rear camber does the S3 have as standard?
  5. DJ-S3
    DJ-S3 Active Member
    690
    43
    Has anyone got any photos of their cars on 10mm spacers so I can see how it sits with the arches?
  6. timmythechef
    timmythechef Starin' Through My Rear View
    263
    This is mine on a 15mm spacer, ET52 to ET37 on a 9j.
  7. Jonse
    Jonse Active Member
    448
    49
    ^^^^^^ Like this
  8. DJ-S3
    DJ-S3 Active Member
    690
    43
    I was expecting mine to be similar to that. Not quite as wide but you get me.
  9. timmythechef
    263
    You can just fit a finger tip between the wheel and arch.
  10. DJ-S3
    DJ-S3 Active Member
    690
    43
    Does it scrape on the arch?
  11. KemiksiZ
    570
    142
    43
    What about fronts mate? R they the same? Any rubbing for the fronts?
  12. timmythechef
    263
    Fronts are on 8mm spacers again orginal ET 52 9j.
    They do rub but only cause I took the adjusters out of the coils and went for a high profile tyre for winter. On a 35 profile tyre it wouldnt rub at all
  13. timmythechef
    263
    I did run an 18x7.5j (A8 winters) on a 15mm spacer so went for an ET40 to ET 25 and that never rubbed.
  14. DJ-S3
    DJ-S3 Active Member
    690
    43
    your signature thing. HaHahahaha
    I might try 13mm on the rears
