My slightly broken CV joint (with pics :))
Welly Aug 10, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    New shafts arrived today - top notch. Well impressed. No splits at all in the boots.
    For anyone interested - the shafts from a TT Quattro will indeed for an S3 with no problems at all.
    So..... The inner CV joint that was knocking? Oooooooohh dear. It was FUBAR in a whole new way.
    For openers, I removed the CV from the box and found the circlip for the joint sat in the back case, in the grease. Not good.
    Anyway, the damage was quite impressive to be fair. The balls were OK-ish - a few dents and grooves aside.
    The bearing race and inner cage however, were impressively broken.
    Even the circlip has signs of wear on it.... Somehow.
    Anyway, I have my suspicions that this may be the cause of the my mysterious 'clunk'.
    The outer boot also had 4 separate tears in it, and was dry as a bone.
    Fingers crossed.
    PAS not fixed yet so couldn't test drive :(
  2. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    That not too bad Welly, you should see the CV's we have back at work the shattered. Those can be recon'ed :)
  3. luckydave
    luckydave Member
    55
    That looks good considering it ran dry. Normally the cage is in about 5 bits! On my track car I had the cages shot peaned to remove the stresses and fingers crossed keep them together longer!
  4. Welly
    10,696
    130
    Thats the worst joint i've ever seen to be fair, but then again, I've never run them dry before.... lol.
    It was making one hell of a din...
  5. Welly
    10,696
    130
    LOL, na, new shafts FTW!
  6. Dani_B19
    9,380
    402
    So what was actualy causing your knocking welly? Was it the inner cv boot? Its just i cant find whats knocking on mine at all and while im buying all my suspension parts i want to sort this out too!
  7. Welly
    10,696
    130
    It was causing some of my knocking, some knocking was the prop shaft, and the third knocking remains at large..... lol.
  8. sportstractor
    sportstractor Chugger
    2,709
    3rd knocking?! dam, what a shed
  9. Dani_B19
    9,380
    402
    Cheers alex.
  10. Welly
    10,696
    130
    Oh yes.... Tell me about it! lol
  11. Dani_B19
    9,380
    402
    So even after the cv and prop shaft, it's still knocking?
  12. Welly
    10,696
    130
    Yep, less I grant you, but this isn't a knock, more like a clunk. Bearing in mind I've had the underside apart now as well and replaced the prop shaft.
    Track rod ends and shocks/top mounts suspect.
  13. S3KO4
    S3KO4 Member
    850
    Welly I have the same clunk noise since day 1, and to date I have not been able to find it I think it must be coming from the shocks I did steering rack, cv joint re grees, bushes but no luck as yet
  14. Welly
    10,696
    130
    LOL, does it drive you spastic too? It makes me soooo mad sometimes. :lmfao:
