My silver S3 from South Africa
Sidey Nov 9, 2012
  1. Sidey
    Sidey Active Member
    285
    153
    43
    Hi guys, I am from South Africa and purchased a 2001 8L S3 3 weeks ago, so thought I would start a rides thread.
    2001 Audi S3 Quattro
    99000km
    FSH from agents
    Black leather
    Sunroof
    Bone stock and only 1 owner since new
    Few things to sort out but for the price I paid I could not let this one slip away.
    Before I collected the car I had already bought some parts for it.
    Audi TT pedals
    EVO digital boost gauge
    Gauge pod
    BMC filter and K&N cleaning kit
    Forge type DV
    Pioneer AVH-P4350DVD
    Some pics of the car itself
  2. gingergoolies
    gingergoolies Hello
    13
    looks really nice and clean!! look forward to seeing more pics of its progress!
    got any other mods planned?
  3. Sidey
    Sidey Active Member
    285
    153
    43
    Thank you, I will update shortly.
    Performance mods ill do the usual TIP, intake, FMIC, DP and exhaust, software.
  4. Sidey
    Sidey Active Member
    285
    153
    43
    Got cracking on the boost gauge install.
    The universal pillar pod really is a piece of s**t and does not line up with anything.
    So thought id trim it down as much as I could and then id fibreglass it to the shape of the pillar trimming.
    Got carried away with the trimming a bit and was left only with the cup piece.
    Used some tape to hold it in position to get the right angle and temp fitted it to the car.
    Got some brackets and epoxy from builders to fasten it to the pillar.
    Found some fabric at chamdor to match the rooflining. Made the holes for the screws and the wiring.
    After lots of pulling and swearing and sticking and and and....we have this.
    Fitted the gauge last week, not lots of space in the S3 with all the wiring and electronics.
    First had to clean all the leaves away to get the the grommet
    Fat people never get off easy with this type of job.
    And all done and fitted.
    Best pic I could get at night time.
  5. Purdy99
    Purdy99 Member
    90
    fair play, that looks really good! keep up the good work!
  6. guzzy_431
    guzzy_431 Member
    107
    Good work coming along there bro, loving the auto gauge it looks neat. What sort of BHP gains are you wanting to acheive? in the tamed beast?
  7. Sidey
    Sidey Active Member
    285
    153
    43
    I am redoing the suspension on the car at this stage, not really happy with the ride.
    Purchased some goodies this week.
    Koni STR.T struts for front and rear.
    Apex Coils.
    Powerflex bushes , all thats missing is the powersteering rack mounting bush and the dogbone mount bush, they are on order and will have them in 2 weeks.
    Front control arm bushes
    Rear trail arm bushes
    Rear Tie arms bushes
    Front ARB bushes
    Rear ARB bushes
  8. Sidey
    Sidey Active Member
    285
    153
    43
    Im new to the quattro world, so I know there is quite some drivetrain loss, but 280whp will be fun.
    Not new to the 20v world though, this was my previous car that I sold to buy the S3...
  9. Sidey
    Sidey Active Member
    285
    153
    43
    This past weekend got cracking on the suspension, Did not get as far as I would have liked to, but working on quattro is a bit more challenging than normal fwd cars and takes time.
    Fitted all the rear bushes, So will do the fronts next and then fit the shocks and springs.
    Must say im going to have a very colourfull car with orange shocks, yellow springs and purple bushes :lol:
    Some parts I have purschased.
    Balljoints
    Front control arm bushes solid TT
    Febi shock mountings
    Stabilizer bar links
    Thermostat
    Anti Freeze
    Turbo gasket
    So onto the suspension,
    Rear Tie bars revomoved
    Pressing old bushes out in the vice
    New powerflex bushes lubed up with copper slip and inserted
    Bars fitted back with lots of swearing
    Rear sway bar bushed installed
    Rear trailing arm bush (Original)
    Oem vs powerflex
    Fitted (its not damaged in the pic, just dirt)
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Excellent progress mate..:icon_thumright:
  11. Sidey
    Sidey Active Member
    285
    153
    43
    Replaced the thermostat and then decided to replace the turbo gasket, because it was leaking quite a bit, which was suppose to be a short 1 hour job turned into a nightmare of a 10 hour job.
    The turbo was replaced recently and instead of it having the OEM bolts, it had studs with nuts, so had to remove the complete manifold to get to the turbo gasket.
    Here you can see the gap on the left where it was leaking
    So had to strip a s**t load of stuff in the engine bay to get the manifold out, and with the quattro system everything is in the way and struggled my **** off getting to the bolts.
    I was left with this, got some new gaskets and bolts and nuts today, so will put it all back together tonight.
    [​IMG][/quote]
    New bolts/copper nuts/nordlock washers and vasbyt inserts
    One insert in
    Gasket now flat and tight
    New OEM DP gasket
    So one of the bolts on the exhaust side on the turbo was fecked, so to be able to get it out I had to strip it all off again :bang:
    Hence my status on Facebook being
    SO new studs fitted and all is back again.
  12. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    Always awsome, neat and pro work done by you! And it helps that you got a looker of a car!
  13. Sidey
    Sidey Active Member
    285
    153
    43
    Did a sump service on the S3 the past week.
    New oil was purchased (Indy oil 5W40 Full synt) and two filters and new pickup with pan sealant.
    Motor was flushed and oil pan dropped, was expecting to find a sludge filled oil pan with blocked pickup, but to my surprise its actually damn clean.
    Oil pan inside
    oil pickup
    Internals looking nice and golden.
    New pickup fitted.
    Sump cleaned.
    Sealent applied and fitted.
  14. Sidey
    Sidey Active Member
    285
    153
    43
    The clutch is also on the way out, major vibration from the DMF and rattle noises from the Cylindric slave.
    So the past Saturday Gizmo, Daniel and I tackled the job of dropping the box and fitting the new setup :crazy:
    New DMF, pressure plate and clutch plate
    OEM bolts
    Slave, OEM rear crank seal, OEM stretch bolts for mounts and dogbone mount, OEM oil seals for transfer case that needs to come off
    Last Thursday night I got cracking on stripping parts off the car to remove the gearbox on saturday.
    Gizmo and Daniel rocked up at 9am and we got going on the gearbox right away, about 2 hours later the transfer box was separated from the gearbox and the gearbox was out and clutch assembly removed.
    New OEM rear crank seals was fitted while everything was off.
    New transfer box O-rings were also fitted, atleast now I know why mine was leaking, stuffed seals.
    Long ass powersteering line that needed to be removed.
    Gizmo tightening up the flywheel :lol:
    Dougi looking like is gonna get butsexxxxx
    Gearbox was soaked in cleaner and then pressure washed.
    Old clutch setup pics, the DMF was completely nackered and had plenty of play on it.
    The complete job of dropping the gearbox and fitting it back into place took us around 4 hours with lots of screwing around and joking and a case of beers. Was a great workshop session and I would like to give a big thanks to the guys that came to help.
  15. MIGGZ
    1,461
    304
    lmao dude i hate dropping boxes with my whole heart! but at least its done now, good work boy
  16. Sidey
    Sidey Active Member
    285
    153
    43
    Agreed boy, its the job I absolutely hate the most.
  17. Gizmo20VT
    Gizmo20VT Active Member
    294
    Its done and dusted, was expecting it to be harder with transfer box and prop, so forth.
  18. Dougi
    Dougi New Member
    Hi im here now and it was fun fitting the clutch!:sadlike:
  19. MIGGZ
    1,461
    304
    welcome dan-son!!!! remember spell check :friends::Flush:
  20. Dougi
    Dougi New Member
    Thanks dude, ill try.
  21. Sam_
    Sam_ Down under
    3,038
    480
    Nicely done. Hats off to ya. Think my DMF is buggered too. Judders pulling away sometimes :(
  22. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    Top work doing all that yourself. I wouldn't know where to start with dropping the gearbox.
  23. Sidey
    Sidey Active Member
    285
    153
    43
    Thanks for all the kind words guys.
    Collected my goodies to service and redo the CV shafts yesterday. Will do that this weekend and then assemble the car.
  24. Sidey
    Sidey Active Member
    285
    153
    43
    So lost a bit of motivation to fix the S3, but after 5 weeks of being non mobile its running again, and driving like a dream with all the new bits and bobs.
    So first onto the CV's.
    They were completely stripped, cleaned and repacked with new grease.
    Cleaning process
    Nice and clean
    No signs of wear
    Repacked with grease
    Shafts cleaned and sanded and received a fresh lick of paint
    Before
    After
    Powerflex dogbone mounts
    Poweflex bushes and new Solid bushes in control arms
    Top shock mounts have seen better days
    Rear colourful smartie box suspension
    Powerflex Steering rack mount installed
    New CV joint heat shield
  25. Sidey
    Sidey Active Member
    285
    153
    43
    Did a joey mod on the headlights too. Came out quite awesome, need to pop around to NeVaG to get the lenses proper polished up.
    Headlights before, lenses all pitted
    Stripped
    Lenses sanded down, wet sand 300/400/600/800/1000/1200/1500/2000
    The drill attachment I used that works like ass together with plasti-X
    Insides masked off and painted
    Pics of the results to follow
  26. Sidey
    Sidey Active Member
    285
    153
    43
    My boy Tiaan popped through one saturday so we could drill and re-tap his dogbone mount holes as the previous owner farked it up proper. So pics of the broken S3's :lol:
    And onto the pics of where it is at now, had wheel alignment done yesterday and the car is a dream to drive now.
  27. MIGGZ
    1,461
    304
    i was wondering yesterday when will there be an update! looks sick dude i love it
  28. Sidey
    Sidey Active Member
    285
    153
    43
    Bought a Forge 007 a steal.
  29. <tuffty/>
    21,231
    3,875
    Won't be needing that red spring!! lol... to pre-empt the question, just use the green spring and one shim... seal the shim in using a bit of grease or a little sealant as this reduces the piston volume and improves response... only need a green spring to hold it 'shut'
  30. Sidey
    Sidey Active Member
    285
    153
    43
    Thanks Paul, Been reading a few threads on the forum about what spring to use but that clears it up nicely.
  31. Purdy99
    Purdy99 Member
    90
    Amazing stuff! fair play to bud!
  32. Gizmo20VT
    294
    Update your timing chain noise! Might be usefull in future for another user :D
  33. s33nyboy12
    s33nyboy12 Well-Known Member Team Ibis Team V8 Audi R8 s tronic
    1,488
    203
    ???????? share with the rest of us????????
  34. Sidey
    Sidey Active Member
    285
    153
    43
    I'm quoting and posting this from one of the other forums I frequent.
    I replaced turbo gaskets and when I started her up she sounded too good, no more gaskets blowing, real nice and smooth, until you rev it up, sounded like a TDI with marbles in the head.
    Sounded identical to this
    Audi A4 1.8T Cam Chain Tensioner (CCT) Failing? - YouTube
    So after some troubleshooting etc, it was narrowed down to the Cam chain tensioner, Message was sent to Wikus at GW delarey and some new parts were collected yesterday (4k later :mad:)........OH how I love my S3 :lol:
    New Chain Tensioner
    New Chain
    New Tensioner Gaskets
    New tappet cover Gasket
    As per the above post
    Fitted the new chain tensioner and seals, but the noise is still there :bang: But will get to that now later in the post.
    Was too happy to fit new tensioner seals and cover gasket as it was leaking like a b**ch.
    Head inside still looks good, nice and gold from the full synthetic oil used its whole life.
    Old tensioner
    New Tensioner fitted
    So after being all positive and starting her up, the noise was still there, so very pissed off Gizmo and I run Vag-Com to check for codes, and found that a code that pointed to the CPS (Cam position sensor), so went and purchased a new one, but to no luck, still makes the noise.
    So the chain rattle/head noise directs to a few things:
    Chain tensioner failed
    Cam chain slack
    Oil pressure channel to tensioner blocked/sludge
    Oil pickup blocked
    Low oil pressure
    So tensioner has been replaced and noise is still there, so next on the list was to flush the motor and do a sump service.
    Oil pan inside
    oil pickup
    So I will clean the pan out, fit new pickup and then run the new oil for 500km, then drain it again and fill with new oil and filter, and see if this clears up the problem.
    So after having chain rattle/tensioner problems for the past 2 months I have done the following to try and cure it.
    New tensioner
    New cam position sensor
    Engine flush
    New oil
    Sump service
    New oil pickup
    Oil pressure test
    So one thing that was left to do was change the chain itself.
    Gizmo and Daniel popped past saturday morning to lend a hand with changing the chain.
    What we found was the timing was out 2 teeth, so the previous owner who changed the cambelt fcuked it up.
    Well we changed the chain, set the timing and the car is running like a dream, no more chain rattle, power is back (Better than before, never wanted to boost past 0.8 bar, now boosting 1 bar).
    Some random pics that gizmo snapped.
  35. Gizmo20VT
    294
    :yahoo: thanks bud!
  36. Sam_
    Sam_ Down under
    3,038
    480
    Guess you didn't re-use that old cam belt?
    I'm fitting a new VVT tensioner plus chain on the new engine. Pretty glad after reading this!
  37. Sidey
    Sidey Active Member
    285
    153
    43
    That belt has actually only done 5000km. They previous owner did not install the plastic cover right and it rubbed a little bit, but inspected the belt and it is still 100%.
  38. Sidey
    Sidey Active Member
    285
    153
    43
    At last I have got a rear hatch emblem, thanks to gizmo.
    Fitted my badge last night, its the one thing that was missing from the start.
  39. *P3nfold*
    *P3nfold* Member
    368
    15
    That looks fresh
  40. Sidey
    Sidey Active Member
    285
    153
    43
    De-wipered the rear yesterday, might not be everyone's taste, the rubber grommet is just for temporary, getting a glass plug cut shortly.
    Before
    After
    Stu2206 likes this.
