My scan results S3 8L
rhubarb4 Apr 24, 2011
  1. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,753
    187
    Hi just had this scan done by fellow member Lewis583. and thought post them to see if theres anything I really need to worry about. I also have some bar charts and scans but im not sure how to put them up.
    Sunday,24,April,2011,16:42:47:40857
    VCDS Version: Beta 11.2.0 (x64)
    Data version: 20110305
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUZZZ8LZ11003135
    Address 01: Engine Labels: None
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 09515
    VCID: 387ABD503093
    WAUZZZ8LZ11003135 AUZ7Z0A1838821
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 00189
    VCID: 3E76AB4812B7
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 J
    Component: A3 KLIMAAUTOMAT 0105
    Coding: 00041
    Shop #: WSC 01236
    VCID: 2F68860CC5DD
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 5008
    Coding: 01104
    Shop #: WSC 01236
    VCID: 4584C4A47761
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 L
    Component: AB-KOMBIINSTR. VDO D12
    Coding: 01444
    Shop #: WSC 00189
    VCID: 3C72A14004AB
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 D
    Component: HALDEX LSC ECC 0011
    VCID: 214C70348309
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15178
    Shop #: WSC 01236
    VCID: 2F68860CC5DD
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01366 - Opened Due to Crash Signal
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0CAB5304883
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00014
    Shop #: WSC 01236
    VCID: E5C4A42457A1
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 8L0 035 186 A
    Component: Radio D05
    Coding: 00001
    Shop #: WSC 00385
    VCID: 2C529100F4CB
    1 Fault Found:
    00856 - Radio Antenna
    36-00 - Open Circuit
    End ---------------------------------------------------------------------
  2. rhubarb4
    1,753
    187
    Hi how do i put the graphs and bar chart results on here there in Excel but cant work out how to get them on here :banghead:
  3. NHN
    29,333
    1,717
    Ok did he clear anything before doing the log or thats just a straight forward 1 time log, with no atempting to clear, as some of them could disappear when cleared & rescanned, also any issues with your radio reception?
  4. rhubarb4
    1,753
    187
    just a straight forward log I think I will ask him tomorrow. The radio seems fine no signal problems strange that one
  5. rhubarb4
    1,753
    187
    Hi Lewis583 has sorted my graphs out for me, so heres the run charts I dont know what they mean or if there good or bad so any help and info is appreciated :arco:
  6. Lewis583
    956
    91
    Hi chaps, just to confirm i did not do any clearing of codes before or after doing the logged runs. just as a matter of interest how long had the jubilee clip been loose mate? as it being loose after the MAF sensor could potentialy throw readings out due to unmetered air entering the system and therefore alter how the engine runs.
    though if you would like i will clear any fault codes for you and then rescan after maybe a week to see if any have returned? of course free of charge:icon_thumright:
  7. NHN
    29,333
    1,717
    Always best to log, then clear any codes thrown, then log again & then look at returning codes, as quite often there's some codes in central locking which arent much to worry about, I had an S3 for 7 years & often saw some warnings in CL module, but no actual hardware/software faults.
  8. rhubarb4
    1,753
    187
    Yeah hes going to delete and rescan for me, so as soon as I get it sorted il post the new info. Thanks guys
  9. Lewis583
    956
    91
    Replied to your PM chap
