my scan results hmmmm
dplovin Nov 4, 2012
  1. dplovin
    dplovin Member
    416
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Sunday,04,November,2012,08:26:27:32264
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8EZ1A028382 Mileage: 168500km/104701miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 8E0 906 018 B
    Component: 1.8L R4/5VT 0003
    Coding: 11501
    Shop #: WSC 63351
    VCID: 2757E545C5F6351
    WAUZZZ8EZ1A028382 AUZ6Z0A0013741
    1 Fault Found:
    17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
    P1296 - 35-00 -
    Readiness: 0000 1000
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front D620
    Coding: 04275
    Shop #: WSC 06435
    VCID: E5CB2F4D7F7A671
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 A
    Component: A4 Klimaautomat 0406
    Coding: 00000
    Shop #: WSC 63351
    VCID: 1F47FDA59DA6FD1
    2 Faults Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    01273 - Fresh Air Blower (V2)
    41-10 - Blocked or No Voltage - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279
    Component: int. Lastmodul RDW 0510
    Coding: 00001
    Shop #: WSC 63351
    VCID: EFE74D65AD86AD1
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655
    Component: Airbag 8.4E 3001
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: F4ED420994A08E9
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0302
    Coding: 00001
    Shop #: WSC 63351
    VCID: 36693801125C5C9
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 D
    Component: KOMBI+WEGFAHRS. RB4 D10
    Coding: 00400
    Shop #: WSC 00000
    VCID: 2A511C71D6E4089
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0403
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDF5975999E511
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 AJ
    Component: Komfortgerát T9F 0619
    Coding: 06858
    Shop #: WSC 00487
    VCID: 79F3F33D63C2731
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 4.11
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 4.11
    3 Faults Found:
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    01366 - Opened Due to Crash Signal
    36-10 - Open Circuit - Intermittent
    00912 - Window Regulator Switch; Front Left (E40)
    27-10 - Implausible Signal - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 152
    Component: chorus II GRO 0001
    Coding: 00002
    Shop #: WSC 63351
    VCID: DDBB07AD572A2F1
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    End ---------------------------------------------------------------------
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    159
    Clear, do a few ignition cycles and rescan :D
