My S4, Westec Performance and advice. Monster BHP or not?
SonicDeathmonkey May 25, 2006
  1. So, after the little incident when I was overtaken by a Pug 106, I decided it was time to sort out my S4 and its problems.
    Took it to Westec performance, Newport, today and Grant and Jock had a good look at it. Turns out that the rattle I have is the heatshield, which was a recall fault, but I am unsure if mine was ever done.
    The problem with the way the car is running is that one of the cats is toast.
    So, I am at a point where I need to decide what to do next.
    Both the cat and the heatshield need to be sorted out. The question is, when the engine is out to fix the heat shield ( mucho expensive ), what should I be doing at the same time, if anything?
    I had originally planned to sell the car and get myself a 996, but that looks like its gone out the window.
    I can keep the car stock by replacing the cat with an Audi unit ( 600 quid ) and sorting the heatshield.
    I can replace the whole exhaust with a full Milltek one ( cost unknown ) and do the heatshield
    I can upgrade to a set of RS4 turbos while the engine is out and replace the exhaust with the Milltek.
    I can upgrade the turbos with a pair of Garret ones, plus replace the Exhaust with the Milltek one.
    Obviously, the highest BHP will be the Garret/Milltek route, but the cost is unknown at this time.
    Any advice?
  2. rs13219
    rs13219 Member
    114
    If you go for an exhaust system with de-cat you'll still need the cat at mot time so i'd say sort your cat out first. Have you not thought about a re-map which would give you over 300bhp. Lots of power out there if your willing to pay for it. Check out this place,
    www.amdtechnik.com
  3. I must replace the cat. Thing is, do I spend £600 getting the Audi part, or approx £1200 getting a full sportcat from milltek.
    Also, sine the engine must come out, should I spend the dough to get bigger turbos, or HUGE ones...
  4. PaulJC84
    PaulJC84 Owner It's my birthday
    2,912
    17
    I would see if there are any other cats availiable.
    And i would get the turbos to suit your needs. K04 turbos would probably do and still be reliable and semi fuel efficient.
    Bigger ones if your prepaired for the other costs like fuel and maybe a few other upgrades.
  5. jonnya
    jonnya Member
    102
    Is it a main cat or a pre-cat which is gone?
    How was this determined?
    My advice would be to take it to Doug and Mihnea at MRC Tuning in
    Banbury. They do very little else other than work on RS2, S2, S4, RS4.
