My S3 Thread
Sam_ May 10, 2011
  1. Scullies
    Scullies Well-Known Member
    1,543
    657
    Nice one :)
    does he know its a Quattro to. I had a hard time routing the wastegate return to exhaust as there wasn't much room with the propshaft coupler in the way.
  2. Scullies
    1,543
    657
  3. superkarl
    superkarl MAN OF STEEL
    9,495
    2,436
    at a cost of about 8 grand
    Scullies likes this.
  4. Scullies
    1,543
    657
    you get a good discount there?
    superkarl likes this.
  5. Sam_
    Sam_ Down under
    3,038
    480
    Haha I was actually speaking to the owner of IE today on Facebook (he randomly added me, since I had some IE issues before) about that (and other stuff) hence my post on Staceys thread. He said the sump is machined from a 65lb block of ally down to that, ending up at 5lb. He reckons the kit will be $3000-4000 all said and done. I was planning on going for a Forge sump.
    With regards to the girdle, it's not essential but it really depends on what the engine is revved to from what I can gather. Here's the fitting guide for the girdle using standard main caps:
    Integrated Engineering 06A Crank Girdle/Bedplate Kit Installation — IE AutoBlog
    As I posted on Staceys thread, the spec so far is:
    + 1mm Ferrea exhaust/inlet valves
    Ferrea spring + retainer kit
    JE 83mm pistons
    TFSI crank + oil pump
    IE rifle drilled rods
    IE inlet
    Wavetrac diff
    ...and I'll be ordering an IE girdle, forge baffled sump, Hemi TB, IE rail, timing belt gear + dowel pins, manual tensioner and a fluidampr.
    Like I said before though, this is going to be a slow build though as I have a lot of financial commitments at the moment - PR for the mrs and myself, a wedding etc.
  6. Sam_
    Sam_ Down under
    3,038
    480
    Another minute step but just ordered a .72 pagparts vband housing for the GTX30. Hopefully picking up the injectors one night this week.
    I've been away in Thailand with the mrs and driving her mum's Nissan Micra (or "Match" as they call it there), came back this morning and went straight into work. Driving the S3 felt so much nicer, so much tighter and feels like miles more grip. It's mad how a bit of time not driving the car can make it feel so different. It desperately needs a clean though :) A job for this weekend.
    Looking forward to getting into the build but realistically it's going to be ages. Not something I want to rush though since the current engine "works".
    Got a decent price from TSR for their manifold and downpipe kit so I'll go for that with a 44mm Tial wastegate after the wedding.
  7. Sam_
    Sam_ Down under
    3,038
    480
    Not really done much on the car of late as I've been busy working on the site for the guy helping with my engine build (well, his parts side of things). Homepage looks a bit naff (big ECS banner): Euro Revolution - Euro Revolution
    I ordered a couple of bits the other night.
    Massive K&N. Overkill I'm sure but that's been my theme so far, so why not carry on? It's 14" long, 6" wide at the fat end and 4.5" at the small end. 4" clamp size for the GT30 anti surge housing:
    Also bought a 90 degree 4" hose for the tip but that's pretty dull. Really the next big purchase is going to be the manifold. I'm contemplating selling my mac pro to fund the manifold & downpipe, since there's a new one out soon anyway :)
    Guess I'll need an S4 V8 MAF too?
  8. Sam_
    Sam_ Down under
    3,038
    480
    Another kinda dull update. Got the Pag Parts .72 vband housing through today so that can be added to the pile of parts forming:
    The locking tabs that Bill adds to the Tial housings (seems to be standard on the PPT ones):
    I like how it's stainless so won't look manky. I'll have to see how funds are nearer the time for ceramic coating.
    <tuffty/> likes this.
  9. <tuffty/>
    21,363
    3,929
    I do like that... did consider it myself if I decided to go v-band on whatever manifold I go to next...
    Seems a nice compromise between 0.63 and 0.82 on a stroker
  10. Sam_
    Sam_ Down under
    3,038
    480
    Yeah, everyone seems to say it's a sweet spot in the middle. Hopefully it won't be too long before I find out but realistically this is going to be a slooooow build. Similar ish spec to Staceys, but with a few less trick bits. I should really go and get some pictures of the other bits. IE inlet and Wavetrac diff have arrived. Half tempted to chuck the inlet on the current engine and see if it feels any different but not sure I can be bothered and the map would probably need a tweak I guess.
  11. <tuffty/>
    21,363
    3,929
    More power for same boost typically... depends on how yours is mapped really as boost may drop a bit due to extra flow...
  12. Sam_
    Sam_ Down under
    3,038
    480
    Would these fit the fuel lines that come into the bay?
    Aeroflow Quick Connect 3 8" TO 6AN Fuel Line Rail Pump Filter Adapter Black | eBay
    Not sure if it's better than the IE ones?
    Integrated Engineering Factory VW/Audi Quick Release Fuel Line to -6AN Male Adapter
    Bought an M12 -> AN-8 for the IE surge tank. I'm planning on fitting the surge tank in the spot where the washer tank is, and fit a much smaller tank somehow. That way I use the stock filter and just modify the plumbing in the engine bay.
    Shopping list fuelling wise:
    - Genesis HD Fuel Pump Harness Genesis HD Fuel Pump Harness [PMPHARx] - $75.00 : USRT, Usually Sideways Rally Team
    - Integrated Engineering Billet Fuel Rail For 1.8T 20V (black of course, OEM-esque)
    - Possibly these (since I've not heard from the guy selling me the 850s) Siemens Deka 870cc Injector- High Impedence
  13. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    OEM-esque? The OEM fuel rail is stainless....;)
  14. Scullies
    1,543
    657
    those look the same as what I have bought and Stacey said he also uses them - No reports of fuel leaks from Bill yet so hoping its all good.
    RUS 640853 Push on EFI 6 An Male to 3 8 Hardline Fuel Fitting Black LT1 LT4 LS1 | eBay
    My diy s/s surge tank is going to sit in the same place as you are planning. Charcoal box delete so there is a lot of space. Also plan to relocate PAS reservoir to gearbox side of the engine bay.
    I will run -6AN from fuel lines to surge tank, then -10AN to bosch 044 then -8AN from the 044 to the IE fuel rail. Then fuel return to surge tank is -6AN as well as fuel return to OEM fuel tank is -6an
  15. Sam_
    Sam_ Down under
    3,038
    480
    True Dave, but black is equally as subtle. I'm gutted I only got the silver IE inlet though. It looks way better in black :(
    Scullies: Yeah that was the setup I was planning on running but the 044 is submerged in the IE tank so it'll all be AN6 apart from 044 to rail. Ordered an 044 to AN8 adapter for a massive $8.
    There seems to be two different types of OEM hose to AN6/8 adapters, one with the plastic insert (like the one I linked) and one in two metal parts that seems to screw together (like the IE one).
  16. Gordie_S3
    Gordie_S3 Member
    85
    46
    Good stuff man! Went through the whole thread, very interesting! keep it up.
  17. Sam_
    Sam_ Down under
    3,038
    480
    Cheers mate. It's been a bit boring of late but I'm just in a slow parts hoarding stage. Getting as much ready as possible to reduce downtime.
    What do you have planned? Something big to need a dual plate 725 I assume? :) Are you in Sydney?
  18. Gordie_S3
    Gordie_S3 Member
    85
    46
    Yeah, building a 2.0 motor, AEB head (ported/polished), valves, cams etc.....GT3582r
    Still a few months out from starting, I want to get my handling sorted before I begin with the motor. Nah nah im in Melbourne ahah
  19. Sam_
    Sam_ Down under
    3,038
    480
    Nice! Building it for drags or racing or something? (going by the GT35)
    I done the same, brakes and suspension sorted now, so onto the engine :)
  20. Gordie_S3
    Gordie_S3 Member
    85
    46
    Track racing mainly, still not quite sure if to go with a GT30 or 35.
    Yeah, its all just time and money. How much did you end up paying the Milltek cat back system, landed?
  21. Sam_
    Sam_ Down under
    3,038
    480
    I guess if it's pure racing then the GT35 might be suitable but not sure what it'd be like on the road? I went GTX3071R purely because it was available at a good price.
    I think the Milltek was ~$1000 landed and fitted by CRD. Probably wouldn't be any good with a GT35 though, it's probably too restrictive for even a GTX30.
  22. Sam_
    Sam_ Down under
    3,038
    480
    Filter arrived. It's err... big. Also got a couple of AN fittings for the fuel setup. Going to order the rest from Summit Racing soon.
  23. Scullies
    1,543
    657
    Nice 13" wheel you have there :laugh:
  24. Sam_
    Sam_ Down under
    3,038
    480
    Haha it's one of the spare set of 17x9s. Picking up a set of A050 245/40/17's for them this weekend.
  25. Scullies
    1,543
    657
    Wheel whore!
    so where you going to fit this 17" filter? Out the bonnet like a snorkel :)
  26. Sam_
    Sam_ Down under
    3,038
    480
    It's 14" so not tooo bad :) I'm planning on fitting the battery in the boot and putting it there. Overkill as per the theme of the build.
    <tuffty/> and Scullies like this.
  27. <tuffty/>
    21,363
    3,929
    No such thing as overkill :p
  28. Sam_
    Sam_ Down under
    3,038
    480
    Awesome. Snap! How big's yours ;)
  29. <tuffty/>
    21,363
    3,929
    If its the one I think it is 304mm... (Jetex FR-10004)
  30. Sam_
    Sam_ Down under
    3,038
    480
    Nice :) I should have searched a bit more and got that one!
  31. Scullies
    1,543
    657
    its all about the girth
    Sam_ likes this.
  32. Scullies
    1,543
    657
  33. Sam_
    Sam_ Down under
    3,038
    480
    Yeah I'd worked out that we needed 5/16 after reading a few vortex threads. They seem a bit pricier but I'll probably just do a big order for hoses and fittings from summit.
  34. Sam_
    Sam_ Down under
    3,038
    480
    Picked up the sticky rubber today. A pair of used D03G and pair of A050 in 245/40/17 for the spare set of pro race 17x9 rims:
  35. Gordie_S3
    Gordie_S3 Member
    85
    46
    Nice and meaty!
    Shouldn't have any issues with grip ;)
  36. Sam_
    Sam_ Down under
    3,038
    480
    Exactly! Just need to book myself into a day at Eastern Creek.
  37. Sam_
    Sam_ Down under
    3,038
    480
    Clunk and creak fixing today. My rear ARB seemed to shed all the grease from its bushes and was creaking over anything remotely uneven. It was pretty embarrassing going down ramps in car parks and into my drive. I used some Inox MX8 grease (which is pretty awesome if anyone hasn't used it) rather than the included white grease which seemed to dry out. Perhaps being so close to the exhaust doesn't help. Also greased up the front top mounts. Ever since I had the front struts rebuilt, the springs would bind when parking (another embarrassing noise!) and pop every now and then. The ground control top mounts have a "cup" that the spring pan sits in and it's really picky about being greased right seemingly. Lucky I didn't have to strip it all down to do it. I love little jobs like these that make the car feel so much better to drive.
    Thinking about buying one of these for the battery relocation to the boot but not sure if it'll be enough juice?
    Odyssey PC680 MJ MJT High Performance DRY Cell Battery Plus $5 Store Credit | eBay
  38. redz
    redz New Member
    luv this thread... sharing info with source links top notch !!! and the cars my cup of tea:)
  39. Sam_
    Sam_ Down under
    3,038
    480
    Another slow and dull update. Bought a fluidampr for the build. Might be tempted to stick it on my current engine when I get it and see if it makes any difference. I think my belt is making a bit of noise anyway.
  40. superkarl
    9,495
    2,436
    Off vortex? I was spying one on there lol
