My s3 is driving me mad
Andrew@A.L.D May 23, 2010
  1. Andrew@A.L.D
    3,877
    617
    I'm not having much luck with this car as its seam to be problem after problem
    Now i'm getting this code
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    I've checked hoses and pipes
    I got a new N75J a bit ago ( on a APY )
    Cleaned things and so on
    I've not done many miles in it since its rebuild, managed to get out in it this weekend
    Also the dump valve is still not dumping even after a service, it does work and you can hear in move when you take the vacuum pipe off and suck on it
  2. badger5
    9,472
    1,988
    you have a totally different engine now to what the ecu is expecting to see, so to this would all go hand in glove
    you have a boost deviation +250mb over requested hence the fault code.. mbc will clip and give you adjustment, but your mechanical mods outweigh the ecu's expectation.
    dv not working... how do you know its not working?
    whats it doing?
  3. Andrew@A.L.D
    3,877
    617
    Just been out in it and plumbed in a boost gauge, it runs 5psi then 20psi then 5 and back to 20 again, its jump about a bit.
    The engine can run smooth on the spot but put it under load and it can spit and fart then its off.
    I can't hear it at all, all i can hear is wastegate chatter and no dump valve like it did before the engine build, strange as there is vacuum from the inlet
  4. Andrew@A.L.D
    3,877
    617
    If i swap back to a N75F valve will that help as i have the J valve on right now
  5. <tuffty/>
    21,161
    3,838
    Having a 'J' on isn't gonna help tbh...
    Needs logging tbh, see what has changed... at a guess the turbo is spooling earlier catching the ecu out... 5psi sounds like soft limp.... logging may well help give you an idea but as Bill says you have changed the characteristics of the hardware that much the std map is not going to be working well... try disconnecting the N75 electrically (leave it plumbed in though) this will prevent the turbo over boosting while you get the rest sorted and it up and running.... it will throw a few codes but at least you can see if the engine will run ok enough to get you going.... I would imagine that you are going to be needing a stage 3 map sooner rather than later though
  6. Andrew@A.L.D
    3,877
    617
    It runs but i have done what you said
    It feels like the ignition timing is off too but i'll try and get it logged
    Turbo feels like it will come in very early
    I'll have to get it booked in for a mapping as i would like to drive it and to get rid of the water thats still in the exhaust from when the head gasket went
  7. Andrew@A.L.D
    3,877
    617
    Runs better without the N75 plugged in and i can hear the dump valve working now thank god as i was worried about the damage it could do to the turbo, just greased it a bit more, still running on the green spring but have a yellow one when mapped
  8. Andrew@A.L.D
    3,877
    617
    Booked in at RS Tuning in leeds to take some logs to find out whats going on
