my s3 has started smoking :(
richy1819 May 19, 2013
  1. richy1819
    richy1819 New Member
    15
    hi i was wondering if anybody can help,a week ago i noticed after a puff of blueish grey smoke whilst starting my car at a petrol station over the next few days it seems to have got worse and worse,if its left to idle theres continuious smoke coming from the exhaust,id say its defo blueish colour,whilst driving theres nothing on boost or over run still nothing just when the car is at traffic lights etc ideling,anyway took it to the garage and he noticed that the breather hose going to the black pot on the right side of the engine had completely collapsed so i had all 3 breather pipes replaced and was told to run it over this weekend to see how it goes,but its still the same :( ive also noticed when the car is running if i unscrew the oil filler cap there is no noticable change in engine sound,it doesnt begin to die which i thought it would the revs dont even drop the slightest bit,any help would be appreciated
  2. XFi
    XFi In need of a V8.
    491
    47
    It sounds like the turbo oil seals are on there way out. Removing the oil filler cap won't make a difference or cut the engine off, just spit oil out.
  3. richy1819
    15
    also what could i do to check to see if the seals have gone?
  4. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,188
    Are you a mechanic? Would you be better to take it to a specialist?
  5. richy1819
    15
    ive just taken the air intake off the turbo theres no sign of any oil in there ......
  6. Scullies
    Scullies Well-Known Member
    1,543
    658
    Check the exhaust side too :icon_thumright:
  7. darren t
    darren t Member
    568
    you have possibly a leaking valve stem/seal...only does it when parked up and restarted (hot)?
  8. richy1819
    15
    if i start in the morning theres nothing noticeable coming from the exhaust after a couple of minutes ticking over it starts and is worse when warm, clouds come past when im in traffic,turn it off when its hot and start again then a puff of blue and then constant smoking,so for first couple of mins in the morning when its cold its ok
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Sounds like piston rings mate unfortunately,, or turbo seal exhaust side?
  10. richy1819
    15
    well came to start my car this morning,misfiring for about 10 seconds and beeeeep coolant level indicator is on,so now im losing water and gaining a misfire :(
  11. Scullies
    1,543
    658
    Check the plugs if there is any coolant on them. You might have a blown head gasket.
  12. badger5
    9,637
    2,073
    opps.. sounds head gaskety now too then :(
  13. robloake
    robloake Member
    62
    I remember when I started smoking............oh happy days:whistle2:
  14. Scullies
    1,543
    658
    smoking from your exhaust? Party trick?
  15. robloake
    robloake Member
    62
    got some family in Dubai you guys have motor city cool there, green with the desert envy!!
