My S3 has just had the JBS 05 conversion.
S3 Paul Nov 27, 2007
  1. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Back off topic.....
    Dave B what's the issue with Storm?
  2. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    Not really an issue as such, but I wanst happy with a couple of things.
    Firstly, I left my car with them for a week whilst I went away.
    During the mapping process they rang me, and told me they though my FMIC piping was too small and might be causing constrictions. As it happened, I was actually in Irvine in California, so popped in to the place that makes the FMIC in California! They explained that the standard IC piping is 50mm, as is theirs, and the output from the turbo was 45mm, so it couldnt cause any issues, they also showed my a lot of California cars running the same thing, and they have no issues in Cali heat.
    When I left the car I also brought a checksheet along and with one guy noted down every scratch and mark on the paintwork, and told them not to change the spark plugs.
    I get back from an 11 hour flight to find they changed the spark plugs (and tried to make me pay, I made them swap them back) and they had washed but not dried the car so it was COVERED in water spots.
    I actually had to get the porter cable out to remove the water spots as that week was hot.
    Then, I find a scratch, and they denied they had done it, despite me marking it down with them before I handed over the keys a week earlier.
    Anyway, I was at the end of a long day and long flight and couldnt be bothered, and all that said, the map is great.
    However, JBS supplied the map, Storm simply applied the map.
  3. mbs3
    mbs3 Member
    54
  4. HTC
    HTC Active Member
    3,428
    9
    If all works out and the JBS05 see no failures, then I would have to agree that for someone who does not want to get involved with swapping engine internals, this has to be the choice over the IHI setup for a 4WD car.
  5. simch
    simch Active Member
    2,028
    Ball bearings on a k04 hybrid........?
    Did not realise that. Thought is was just a better thrust bearing?
  6. HTC
    HTC Active Member
    3,428
    9
    JBS05 is 360º thrust bearing.
    I doubt turbo dynamics is ball bearing. CHRA is too small.
  7. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Hi again.
    The car has a few other mods here and there...
    Brembo calipers and discs up front.
    Koni Coilovers.
    Forge tip and other boost hoses.
    Now wearing a Milltek Cat back exhaust too.
    So many people mention failure of the engine... I was led told by many that the BAM engine was "safe" to around 350bhp?
    I have seen a bent rod but that wasn't from a S3 engine it was a ibiza .
    I had the clutch swapped about 2 months ago so... fingures crossed there.
  8. danotto
    danotto VAG HUNTER
    1,090
    i have an amk engine on an x2001 platewhat is the difference between amk and bam
  9. HTC
    HTC Active Member
    3,428
    9
    Nothing except for the ecu map I think.
  10. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    They're more than good for about 350bhp, but its your high torque fiqure that could bend things.
  11. JBS Sales
    JBS Sales Member
    395
    Paul:
    Thank you very much for the write up, really glad you are happy with the car and you will have to take me out for a spin in it next time I see you :)
    Jim:
    We did want to do this on your car but as mentioned you could not get the money in time for us be we could not work that way it is nothing personal but company policy. I also recall you had a slight family problem which also delayed getting the car up to us and then you had the issue of someone running into your car.
    Again Jim it was nothing personal, if you want to give me a call we can still arrange an offer/deal for you.
    HTC:
    All I can do is apologise about the delay with your turbo kit. There were a few things we wanted to change for the better as we wanted to be 100% the products were perfect before we sent them out to you. I do recall you asking for the CAT in the downpipe but by this time we had already made the downpipe for you. Again sorry for the delay and if there is anything else I can help you with please feel free to ask. :)
    MBS3:
    The JBS05 is a different spec to the TD turbo, almost like a night and day differance between the two on how they perform on the road.
    Dave Bayern
    Just to clear up mate, it is Custom-Code that supplies files to Storm Development not JBS ;)
    ChriS3
    The figures produced by the JBS05 are safe for the engine internals, as I said to Paul if we feel there are too much we would either back the power down or if the customer requested max power a disclaimer will be signed.
    I hope this helps everyone
    Mike
  12. Pat
    Pat Member
    515
    Well i know Paul and know he is very happy with the car, i also spoke to Mike the other day about having pretty much the same done to mine, very helpful and not pushy.. If i do decide to have it done then it won`t be till new year.. In the meantime i ordered some H&R ARBs to keep me entertained.. Which came today..
  13. ChriS3
    2,239
    27
    Mike, probably should have emphasised the 'could' as I really wouldn't expect it to happen. However to deny that its a possibility is a little naive and potentially misleading. You're producing a lot more torque than most BT kits.
  14. glen_jai
    glen_jai Member
    340
    Just spoke to Alec at JBS. Seems like a nice guy and really willing to explain the technical details of the hybrid k04.
    After deciding not to sell my car for a 993, I am "this" close to doing a BT conversion. I was (and still am) interested in the gt28rs conversion done by Backdraft. Mark seems friendly also, and appears to know his stuff.
    However, the hybrid JB05 turbo sounds almost too good to be true. The spool up rates of a standard k04 with sustained boost to hold to 7k. That's impressive.
    Alec did mention that an FMIC was not required, though to reach the 340bhp a new manifold, dp and sports cat would probably be required.
    Paul, did you notice any loss of power after a spirited run? (with respect to still using your smics)
  15. george80
    george80 New Member
    Why do you guys run cats when tuning(other than the obv mot time issues), in evo world most of us use decat..
  16. ChriS3
    2,239
    27
    Because they're not restrictive on the S3 and removing them just throws up emissions warning lights.
  17. george80
    george80 New Member
    ok - thanks for clearing that up :)
  18. jojo
    28,881
    3,532
    Am I right in thinking that you can use this hybrid turbo with standard exhaust, manifold and injectors, and just requiring a custom remap? Of course the added benefit of uprating the other parts is more power, but I'm thinking this would be a good replacement for a blown turbo and getting more power in the process without spending silly amounts of money north of £2k.
  19. HTC
    HTC Active Member
    3,428
    9
    Yep, sounds about right.
    Backdraft are offering a similar turbo for £650 +vat.
  20. jojo
    28,881
    3,532
    Thanks, just what I wanted to hear. :)
  21. s3ollie
    s3ollie Member
    762
    Is that for the part only? how much extra would fitting be? also + a remap ~£500 i guess?
