Yeah mate she wants a new kitchen so I don't tell her how much I spend on the motor. I know my priorities!!
I think spending like for like is a very fair compromise - 10k on the Kitchen and 10k on the car...... that will give you a very tasty S3
Women always want something when they see you happy coz they know poor man cant be happy!
I usually buy chocolate, that does the trick lol
but then you end up spending loads on PT sessions and other stuff to keep them fit
The other alternative is to trade her in, like I did, get the mods done and then see if she wants you back. Risky strategy but worth it
I just have a separate bank account,and divide the price of everything by at least a factor of 10.
And before you know it the Audi will be gone along with the Mods!................Id seriously reconsider that Kitchen!
A TTS engine cover will cure all your woes! Otherwise nice job!
On a brighter note the heat shield from Garage Midnight arrived today so I fitted the REVO race CAI instead.
As for noise, not as loud as I though it would be so really pleased. Gives lovely whooshing noises during acceleration and lift off also when changing gear. Sounds as if the air vents are transmitting the sound to the cabin weird. Not intrusive and unnoticeable at cruising speed. With music on you can hardly notice.
It may well be the placebo effect but it definitely feels more eager under acceleration even on Stage 1.
Oh and don't tell me the engine needs a clean, I know!
Is the damper longer than the standard damper, it'll be fine once there is weight on the spring, it's just like having coilovers with the helper springs removed.. The spring bounces around when there's no weight on it but once it's sat on the ground the spring will re seat itself.
That cant be right though, so every time the car lifted and the load is taken off the suspension the the front springs are free to rattle around....? Cant see it myself.
Sorry to hear you're having problems mate, I'll be buying these dampers soon enough so very interested in how this pans out for you.
Cheers, I would say they will work for standard height springs but I want the front lower, no positive rake, which why I went for the Eibachs. Maybe I should have got the coil overs. Hoping Damien has an answer, he's contacted Bilstein to find out. Keep you all posted.
Something ain't right mate B8's are designed for lowered springs, they sell the B12 Pro-Kit for most cars which is B8 dampers and Pro-Kit springs as a package.
I'm sure Damien will hook you up.
When you say pro kit springs do you mean Eibachs or do Bilstein do their own? Theres no way I want to fit the shocker unless it clamps the spring before fitting to the car can't see this is correct. Also its worth noting you don't need the spring compressors to fit the Eibachs to the standard dampers they just about clamp them which is what I expected from the bilsteins.
The Bilstein B12 Pro-Kit is Bilstein B8 dampers and Eibach Pro-Kit springs, I bought the kit for my previous Focus ST3 and ****** great it was too.
BILSTEIN B12 Pro-Kit
Agreed, I'd not be fitting them like that either.
Yeah looking at the damper photo its way shorter than the ones I've got, must be the wrong ones.
are you 100% sure the part number is for an s3?
would make sense if you've got one for an a3 being that bit longer?
its just a stab in the dark as I've no idea when it comes to dampers on their own, but i was just thinking to check your part numbers against the ones on what you ordered to check you have the correct dampers.
im not sure if s3 dampers are shorter than a3 dampers but id have thought so what with the s3 being 30mm lower than an a3, which is where I'm thinking you've got the extra length on the dampers you've been given..
They're the right ones according to the Bilstein online catalogue and every site I've been searching through for the last hour to try and help.
Good job wish my 10 plate did could take the coding any word on your dampers?
