My S3 brakes do not stop squeaking!
eugegall Mar 11, 2010
  1. eugegall
    eugegall Member
    66
    Obviously when im slowing down but for about a year non stop when im stopping they do the loudest most high pitch squeak!
    So i poped into Audi today for them to tell me that its one of the S3's caricaturistics.
    IS HE HAVING ME ON?
  2. thebott
    thebott Member
    211
    Yes he is , mine don,t squeak ........
  3. NHN
    29,284
    1,695
    Yeah he's having something, what a load of ******
  4. Spin140
    Spin140 Well-Known Member
    2,196
    186
    Birmingham Audi changed my pads on the previous S3 due to squealing, the car had covered 7,000 miles when I first reported it, they commented Audi were aware of an issue with some of the pads and now use a revised compound, don't know how true all this was but I'd try another Dealer.
  5. madvw
    madvw Active Member
    2,489
    mine used to squeal like crazy on my 58 S3 SB, 4k miles. Every brake, from 30mph to 0. People used to stare in their rear view and panic.
    I took it in for an inspection, and they replaced them FOC.
    no more noisy brakes.
  6. GConn
    GConn Member
    236
    All s3 brakes squeal after hard use. It's a rather known issue. I changed the pads 5.000 miles ago and have no squealing issues since. I used Ferodo Premier pads
  7. boggym
    boggym Member
    158
    My original pads used to squeal all the time. I needed new pads and discs a while back and put on OEM parts and not heard a dicky bird out of them. I guess Audi must have changed them, probably following all the complaints they've had!
  8. dc240969
    dc240969 Member VCDS Map User
    925
    l had my fronts done under warranty. Seems that the pads contain to much ferrous. Audi will sort it, if not your local then take it to another audi dealer, if its in warranty. lve also heard that if you take the leading edge of the pads with a file that helps, but that was just a general mechie.
  9. S.
    S. Well-Known Member Team Ibis TFSI Owners Group quattro Audi S3 Manual
    1,936
    498
    mine does it too. it's really annoying :uhm:
  10. N8
    17,163
    718
    Time for new brakes :wub:
  11. NHN
    29,284
    1,695
    I'd agree with that, would help not to create that glazed effect & this is usually IMHO where the screeching comes from on the lip area, a good skim has always cured this for me.
  12. Dan!
    Dan! Quattro Drive
    278
    I don't know if this would help if this is a known issue but when I had my CTR I had a really bad squeaking problem after sticking on new disc and pads. To solve it I did what I should have done in the beginning to bed them in:
    Accelerate to 60-65mph then hammer on the anchors almost to the point of ABS kicking in until you get to 10mph (do not stop!).
    Repeat this a further 7 times (8 decelerations in total) and you find that you probably start to get some fade and smell the pads cooking, this is what you want as it de-glazes the system and imparts a new boundry layer between the pad and disc.
    After the last deceleration drive at 60-70mph for a good couple of miles without hitting the brakes to let them cool.
    This worked for my CTR straight away and should give you good brake feel too.
    Hope it helps, but like I say, if there is a known issue then it may only work temporarily or not at all... :unsure:
  13. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    ditto, i got told by an audi service engineer that they have developed a revised compound pad and that they purposely try to fob people off for as long as possible without replacing (e.g tell you they will deglaze, clean down your existing (this will not work long term trust me)... but if you hassle hard enough like i did cause it f***in drove me insane they will change them, havent had one squeak since...
    nothing worse than in the summer blinging fresh car go to stop and squeeeaaakkk, so embarassing in your 30k hatch!!!
  14. EvolutionV
    EvolutionV Member
    203
    Mine does it but only after i give it a beating...
    Stops squeling once it cools down.
