My S3 8L Progress Thread
Adam P Oct 1, 2012
  1. superkarl
    superkarl MAN OF STEEL
    9,405
    2,379
    Whos is the dc5???
    Awesome car, my mrs would like one.
  2. Sam_
    Sam_ Down under
    3,035
    480
    Finally some decent pics ;) looks awesome.
    Adam P likes this.
  3. Adam P
    Adam P Active Member
    539
    178
    43
    The DC5 is my girlfriends superkarl. I would suggest she gets one, they are great cars to drive and look smart!
    Cheers Sam the car is starting to come together nicely now i think.
  4. Adam P
    539
    178
    43
    Right a quick update. Have been pretty busy recently but managed to fit my boost hoses. Had a bit of a nightmare with the roose motorsport ones so purchased the creations motorsport set which i could trim to fit nicely. I have also popped in some new led side light bulbs. I am yet to tackle the dogbone mount however have got one of ebay for peanuts so will polybush it off the car then install to correct torque settings when i have access to a ramp. Anyway heres some pics.
    Next areas of work will be looking into a FMIC setup where i can keep my fogs and having the car super-guarded.
  5. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    awesome work so far dude, why are those clamps so heavily rusted in the 2nd pic?
  6. Adam P
    539
    178
    43
    Thanks mate. Im currently working my way around the engine bay replacing clips and plastics which have seen better days, this clip is one that needs replacing for sure! :yes:
  7. MIGGZ
    1,461
    304
    is that water leak that caused it or just the constant moisture in the air there? never seen clamps rust...
  8. Adam P
    539
    178
    43
    Honestly I'm not to sure mate, i know there are no leaks in there now but there could have been a leak which occurred during the previous owners time and they have just started to corrode. They will be replaced during the engine bay tidy up.
    MIGGZ likes this.
  9. stevegti2
    stevegti2 Member
    229
    13
    dc5 :hubbahubba:
  10. Adam P
    539
    178
    43
    When looking at the car the other day the callipers stood out as an item which needed some attention. Having replaced the pads with red stuff not too long ago i just opted to give them a lick of paint. Has tidied them up a bit.
    BEFORE
    AFTER
    ACWKGYTO likes this.
  11. Adam P
    539
    178
    43
    Right a quick update, over the last few weeks i have been doing some research and gaining some knowledge off Rob 'vrbob' into the next few mods and been collecting parts. This evening i tackled the n249 bypass and fitted my new Creations Motorsport crankcase breather pipe as the standard one was knackered. Big thanks to BenJee s3 for his how to in the stickies, great guide. :beerchug:
    Collecting parts for the FMIC setup now!! :rockwoot:
  12. N Jack S3
    N Jack S3 New Member
    23
    Keep up the good work mate! :icon_thumright:
    Adam P likes this.
  13. Adam P
    539
    178
    43
    Cheers M8!
    Not much to report at the moment I'm afraid, still collecting FMIC parts.
    Replaced the rear discs and pads as they were worn and thats about it. Its too cold. Heres a picture of the fresh discs and pads through the wheels. Much nicer than the worn and corroded ones.
    aterro likes this.
  14. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    make sure you grease them valve caps or they will seize
  15. Adam P
    539
    178
    43
    Saying that. I did my tyre pressures the other day, and they were a bit of a pain to remove. Another little job for the weekend i think. Cheers mate.
  16. aterro
    aterro S3 YO
    272
    Looks awesome.
    what size wheels are they? and trye size?
    and your running apex springs 30mm ones?
  17. Adam P
    539
    178
    43
    Thanks Aterro!
    The wheels are 18" x 8J
    Tyre size is 215 35 18 so there is a little stretch
    Suspension is the 30mm apex springs
    Spacers are 20mm rears and 12mm fronts.
    :salute:
  18. Adam P
    539
    178
    43
    Right a quick update for you guys. Over Christmas I decided to sort something on the car which has always been on the list. The previous owner had not wired in the aftermarket alpine head unit properly. The unit would occasionally cut out, the radio would have poor signal and the unit was not connected to the ignition feed so would stay on when the key was turned off after a drive. I whipped out the head unit quickly to have a look and found a wiring jungle and lots and lost of electrical tape. Anyway to cut a long story short new audio harnesses and proper connections made and its all how it should be now. Here is a picture of mid rewire.
    Next on the list was to get a new cam cover gasket as mine needs replacing, this is still waiting to go on as i am having the haldex serviced at the same time with the help from another forum member vrbob.
    Finally the FMIC parts are all here, all bends, joiners, samco hosing, clips etc. The cooler itself is due to arrive this Friday from Australia and i cant wait!
    At the weekend the car was treated to a good clean and wax with some g3 professional. The girlfriend got a new camera for xmas so she got some good shots of the s3 for me. Hope you guys like them.
  19. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Like it mate lots of nice bits to add in prep for full stage 2 setup. :)
  20. Adam P
    539
    178
    43
    Cheers mate, and thanks for you help and advice on bits, been a real help. BLADDY AUSTRAAAAAAAALIANS!
  21. vrbob
    2,375
    171
    I think we should fit your cooler upside down as a salute to the AUSTRAAAAALIANS lol
    Adam P likes this.
  22. future
    future Scuderia Vittoria Edition 001
    371
    33
    just found this and the car looks wicked adam! nice to see more people in southampton :)
    Adam P likes this.
  23. superkarl
    9,405
    2,379
    This is the absolute tits :thumbsup:
    S3- and Adam P like this.
  24. Adam P
    539
    178
    43
    Thanks for the comments guys, appreciate it! When i got home last night there was a parcel for me.................... :w00t:
    S3 OKR and N Jack S3 like this.
  25. vrbob
    2,375
    171
    OOoooooo Shiney............................................. :)
  26. Adam P
    539
    178
    43
    Right, here we go. The car was treated to a new cam cover gasket and cam chain tensioner gasket to sort the oil leak.After looking at the gasket that came off it looks like it had never been changed. It literally fell apart after rob changed it over. Here is a picture of the engine with the rocker cover removed.
    Now onto the joys of the FMIC
    As the car was already tucked up in the BOB 4 garage he kindly removed the front bumper, headlights, crash bar & SMIC's in preparation for when me and nick arrived after work for us to crack on with the FMIC install :yahoo:
    Here are a few pictures i managed to get during the install
    The install went relatively smoothly with the help of Nick and Rob. Its always good to put a face to a name so here is Nick lol
    Some of you may have seen Nicks picture on his thread already and as expected there are a few tiny issues with the boost hoses and clamps which will be tweaked over the next few days. Next on the list is the oil catch can installation.
    S3 OKR likes this.
  27. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
    Looking good adam :thumbsup:
  28. vrbob
    2,375
    171
    Nice just need to tweak a few bit and sort your CatchCan setup and will be good to go.
  29. Adam P
    539
    178
    43
    Well its been a long couple of weeks, as mentioned earlier we encountered a few problems with boost hoses as well as the PCV system. It was just easier for me to take the s3 off the road whilst i sourced parts which allowed me to keep my front bumper off. Luckily i have a company car so i wasn't stuck without transport. Anyhow everything has now turned up and she will be back on the road this week if all goes to plan. The PCV pipework has been removed and is being replaced with a catch can setup. I have also got a new oil dip stick and holder tube as mine was brittle and starting to break up, i cleaned my jetex induction as the car was not being used and also managed to get my hands on plastic cover which sits near the inlet THANKS ROB! The fogs are now LED and my boost gauge surround is now flocked. Cant wait to get her back on the road, there is only so much of tdi estates i can take, on the plus side its still an audi :kissmyrings:
    S3 OKR and Danny Cawsey like this.
  30. willh92
    willh92 Active Member Audi S1 Team Brilliant Black
    335
    49
    How much was your FMIC set up in total? and by the looks of it you didnt have to cut your crash bar as with most FMIC setups i've seen on here.
    looking good though mate! :thumbsup:
  31. ACWKGYTO
    ACWKGYTO Well-Known Member
    1,234
    363
    This thread is PURE CAR PORN ! :yahoo:
    Great thread thanks for sharing it
    Adam P likes this.
  32. Adam P
    539
    178
    43
    Cheers Will, The complete install came in at just under £200 which i think is very reasonable considering the forge kit is around the £800 mark. Suits my needs and setup perfectly.
  33. future
    371
    33
    looks wicked adam! glad you got your bits sorted :) yours and robs cars are like twins now!
  34. willh92
    335
    49
    Sounds spot on mate, £200 is more my budget! If you wouldn't mind could you write a quick list of the parts you bought for it?
  35. Adam P
    539
    178
    43
    Yeah no worries mate, we are currently tweaking the pipework at the moment so when it is all exactly how i want it i will pm you the list of bits i have used. :icon_thumright:
  36. willh92
    335
    49
    Cheers mate, much appreciated!
  37. Adam P
    539
    178
    43
    Cheers Tom, still fine tweaking the FMIC pipework at the moment. Its been a bit of trial and error getting rid of a nasty kink behind the drivers headlight, but fingers crossed we have found the solution now and should be sorted this week.
    In the meantime i finally got round to installing my catch can setup.
  38. MIGGZ
    1,461
    304
    hey adam
    lovely work dude very neat. but from personal experience those catch cans really are a waste of money if its not baffled the thing just bypasses
  39. Adam P
    539
    178
    43
    Cheers Miggz,
    All of the PCV pipework was completely shot and corroded so thought this was a good option to take. For the sake of £30 including all the pipework and fixings i didn't think it was too bad as it tidies up the bay nicely too.
    MIGGZ likes this.
  40. MIGGZ
    1,461
    304
    yeah dude for sure and to replace all the pipes that were shot would cost 10x that
    Adam P likes this.
