My quattro needs new brakes - any recommendations?!?!?!?
Richardesty Apr 15, 2010
  1. Richardesty
    Richardesty loves quattro
    742
    20
    Hi guys.
    My car's about to hit 50,000 miles and during a service this morning I've been advised that the discs and pads are 'about ready' for replacing.
    I'm thinking of going with OEM discs with EDC Green Stuff, or Red Stuff, pads all round.
    Any thoughts or experience would be really appreciated :icon_thumright:
    Rich
  2. Dazmo
    Dazmo Active Member
    1,762
    Hi mate, i replaced my front discs and rear discs for OEM discs, i also have redstuff pads and have braided brake lines, i did all this at 45k miles.
    Its a great setup, however im looking at getting drilled discs now and i would reccommend you get drilled or grooved discs too as they are about the same price as OEM and you will get less brake fade and better heat loss.
    Just look on ebay mate, loads of discs and pads, if i remember correctly my OEM discs were about £180 for front and rear, my redstuff pads were about £120 for front and rear and my braided lines were custom made for about £40.
    If you want to go down the OEM route like i have buy from here mate, http://www.premier-factors.com, i even bartered them down abit, they are also on ebay.
    But...personally if i were your position right now i would get some grooved and drilled discs, with redstuff pads and get yourself some braided brake lines from DPM.
    The whole lot should cost you no more than £350.00 excluding fitting.
  3. solaris
    solaris Member
    416
    17
    out of interest do the red stuff pads come with wear sensors?
  4. harmless
    harmless Member
    79
    yes redstuff pads come with wear sensors, i highly recommend buying the red stuff pads they are awsom and while your changing the discs might aswell get some groved and drilled ones will help with fade and loose heat alot better = better braking!
  5. aragorn
    18,297
    804
    Personally drilled/grooved disks are a waste of time. The grooves just eat up the pads, and the holes often cause cracking.
    Stock disks and some good pads (DS2500's would get my vote. Redstuff is junk) will see you alright.
  6. Dazmo
    Dazmo Active Member
    1,762
    Yes holes can cause cracking, but they reduce brake fade, which under heavy braking is essential.
    This is why you see drilled discs on performance cars.
    As for the grooves, yes they do wear the pads down slightly more than normal but the added aspect of removing water and heat from the discs is not to be overlooked.
  7. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    Rich- if your not going to be tracking the car I wouldn't bother with drilled/grooved discs. Stick with Original discs and either original pads or DS2500 pads as already stated.
    Drilled/grooved are good to have IF your going to be tracking the car and IF you are prepared to spend £100's per disc otherwise the quality isn't there!!
  8. Dazmo
    Dazmo Active Member
    1,762
    Nothing wrong with having drilled discs if your not tracking the car.
    I get brake fade all the time on mine and im tired of it.
    You can pick up perfectly adequete drilled discs for £150-200, just the same quality as OEM discs.
  9. solaris
    solaris Member
    416
    17
  10. Andy D
    Andy D Member
    276
    I'm pretty convinced the drilled discs are the way to go, my OEM ones are drilled, I don't think Audi would have them on there if they weren't required, I also have a bit of extra power to my wheels so I suppose it gives that bit more confidence that brake fade shouldn't be an issue.
  11. Richardesty
    742
    20
    Thanks all - just moved house so have been netless......
    I have used drilled/grooved discs on my previous car and wasn't desparately impressed........I am tempted with drilled though.
    Just wondered which way you guys had gone.
    I understand Redstuff pads aren't great from cold - which is putting me off a little.
    I reckon I'm either gonna go OEM discs or Drilles, with Greenstuff pads.
  12. rowdyboy
    rowdyboy Member
    804
    19
    Just brought OEM pads for the rear and going for redstuff on the front with the original, genuine discs. I looked at ferodo DS pads but they are slightly more expensive.
    I have had drilled and grooved discs on previous cars, which were good but i don't hammer brakes like I used to so won't be going for them on here.
    I'm sure the redstuff will be fine straight away, the cars are that heavy that heat will build up in no time.
