haaaaa you guys had a good debate here about the caninster and boost spike, pro and cons... Well, I have installed and used for almost 15 months now and I think ECU is learning the pattern how I drive -no expert or prove for this. I am assure you there is no boost spike or irratic boost drop or what so ever. I enjoyed every moment of s3 how it boost up responded to my throttle pressure. The harder-or sooner I press or release the boost goes exactly where I intended. This does the same when I removed the canister, except the boost is lower and I beleived its because wastegate is venting off earlier therefore it would required MORE energy to spool up again. Therefore-a slower spool up time....What you reckon guys ??? How about I do a video on it while I am driving and you can tell me if anything wrong with the boost pattern??
Ps You reckon thiscanisiter should be filled with nitrous ....
