  1. 97_A4_1.8Turbo
    97_A4_1.8Turbo Member
    50
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    Looks like a sex toy. Will also mean you are running lean if you are letting the already measured air escape instead of 'recircing'.
  3. 97_A4_1.8Turbo
    50
    i still hooked up the hose that was hooked up to the dv so its all good
  4. Markey
    Markey Active Member
    2,175
    I think Supie has one of these ones on his car and has had no problems with it :)
  5. PaulJC84
    PaulJC84 Owner
    2,904
    17
    Yeah I have the GFB twin port one. Have run it loads of different ways.
    I was of the impression it ran rich when not resurculating not lean.
  6. Andy.B
    Andy.B Member
    401
    How will you be running lean? Surely if the car has meaters air in the system and you let it out to atmo then the ecu will be still putting the same amount of fuel in for the air that was meatered? Then you will be running rich...
    I'm only saying that as it was like that on my MR2 as putting a DV on one made it run rich and flame out on gearchanges.
  7. Blue_Thunder
    1,771
    31
    :blush:
  8. S4TAN
    S4TAN Evil Incarnate
    45
  9. PaulJC84
    PaulJC84 Owner
    2,904
    17
    My valve only opens when it is blowing off, and I dont think anything would go in it at the rate the air comes out.
