My minor modding thread
<tuffty/> Jul 29, 2009
  1. Scullies
    Scullies Well-Known Member
    1,543
    657
    and straight out the side
    like so
    limbo118118 and superkarl like this.
  2. <tuffty/>
    21,157
    3,835
    That would be no... :)
  3. badger5
    9,471
    1,988
    sounds broken/****
  4. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,829
    677
    Fingers crossed this doesn't buckle the flange too much during welding. Distortion is a b*tch
    badger5 likes this.
  5. <tuffty/>
    21,157
    3,835
    Tial flange and manifold flange will be clamped to a jig...
  6. Lavis89
    1,829
    677
    Ideal. We don't have that option welding things in situ on the boats, leaves some interesting gaps to fill up! Looking forward to seeing this all put together and on the rollers
  7. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    The lads at Nortec are great, Ive been there a few times as its local to me,
    Regarding the front/side exit exhaust... the look and sound stupid, Im not even a fan of screamer pipes, I would always have the waste gate exit go into the exhaust again.
  8. <tuffty/>
    21,157
    3,835
    You can rest assured I will not be having a side exit exhaust, screamer pipe or running 40psi :)
  9. Jason.s
    Jason.s Active Member
    2,879
    348
    Screamer and manboost ftw
  10. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    This I believe for sure, 45psi+ easy!
  11. Scullies
    1,543
    657
    nothing to see here :)
  12. <tuffty/>
    21,157
    3,835
    Had a day off work today to have a faff with the manifold in the car to see if it fits, what clearance issues I may have and where the wastegate might go...
    Thankfully there appears to be quite a lot of room... I had to remove the transfer box bracket as the box attached to the mock up block is the older alloy type and I built the mani to my later (and modified) steel one... once removed the mani fitted perfectly..
    I knew the bracket for the OE heatshielding would need attention...
    ...so a bit of tweaking later...
    Turbo sat well....
    ...I also took an opportunity to check for OEM++ ness...
    Have started playing with the wastegate position... one thing is clear, the Tial 44mm gate I have is a big bugger... plans are still formulating but will have a further update tomorrow or Sunday on that...
    Munch, Lavis89 and jojo like this.
  13. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Done well there, not even the comp housing touching the head....:icon_thumright:
  14. <tuffty/>
    21,157
    3,835
    Ta... there is a little issue over the cam cover removability... I have clocked the comp housing round a bit so that the silicon hose connecting to the charge pipe sits at the right height... this means that the cam cover won't come off without the turbo being moved... this of course is not a major issue as everything is v-banded and therefore dead easy to undo and move out the way... in fact I shall be making all the lines to the turbo with enough give to allow this...
    One of the compromises of fitting big stuff into small places... thank the lord for v-band :)
    Dani_B19 likes this.
  15. BuuBBa
    BuuBBa Member
    133
    Nice looking manifold! Could you take some measurements of the turbo? I would like to know the diameter of the housings and the total lenght of turbo. I could compare how my stone age turbo (Holset HX35) compares to Yours in size, so would know how tight fit mine will be.
  16. Prawn
    11,510
    3,423
    Looking great PT, not surprised it's a good fit to be honest, I wouldn't expect anything less with your expert level of OCD :laugh:
    <tuffty/> likes this.
  17. <tuffty/>
    21,157
    3,835
    http://www.turbobygarrett.com/turbo.../drawing/Garrett_GT3582R_714568_1_2_3_new.pdf
    Been playing with wastegate fitment today... 44mm gate is massive... struggling with it a little tbh... if I go the same sorta way as the TSR mani the gate fouls the gear change cables... facing the other way is plausible but could get in the way of the DP
    The older style Tial I currently have is quite a bit taller than the MVR...
    ...the position I am currently looking into means the MVR is around a finger width clear of the bulkhead... not a massive issue as the engine doesn't move much on the VT mounts and the 20v's rotate back on the mounts anyway under load pulling the gate away from the bulkhead...
    however... I am also toying with the idea of taking a stub off the collector runner of cyl 3 so rotating the gate towards the drivers side a little... gives a little more room at the back but obvs brings it closer to the DP etc... will see how it goes...
  18. <tuffty/>
    21,157
    3,835
    So... made a rather monumental f*ck up... drilled the hole for the wastegate and the hole cutter snagged when it punched through the collector ripping a couple of my somewhat dodgy tack welds off and launching the mani to the floor where it proceeded to dissemble itself...
    So... had another go....
    Decided to sort a couple of things I was slightly unhappy with... this was a bit of a journey quite frankly... I am a patient person by this did really push my patience to the limit... clearly fluked the first one... tried number one runner a few times before I got it workable... was a right pain... tape stuff, tack stuff... cut tacks, break apart, clean fittings and start again.. 12 hours later....
    Slight differences to the previous version... and still have runner 4 to do but it broke me this time lol...
    Will finish it off next weekend (use stronger tacks this time) and hopefully it will be off to be welded (and may even stay in one piece this time!)
    Vex182 likes this.
  19. badger5
    9,471
    1,988
    before disassemble
  20. <tuffty/>
    21,157
    3,835
    Got a little more done this weekend...
    Got started on runner 4
    ...at this point I thought I had better check the heater matrix coolant pipes to see how it would all come together...
    I cut the top hard pipe off the main one as the Forge hose kit I had didn't have these hoses anyway but the one it did have came straight off the coolant housing so will use that... applied a little heat to the pipe to help it bend taking care not to over do it as some of the outlets are brazed on... and bent the pipe away and more upright to the compressor housing as it was hitting it in its original position... this gives me enough clearance for the turbo...
    With that done I tacked runner 4 ready for final tig welding...
    Phew!... not doing the wastegate now until the mani has been fully welded as I want to see where it all ends up... still not finalised the position but that will happen when the mani is done
    Bill has a couple of projects ongoing for the new year all using Garrett/Tial turbos so lined them up for a bit of a turbo pr0n photo shoot :D
    Left to right... GTX2867, GT3071 (HTA billet wheel Owens upgrade) and my GT3582
    Now making a list of stuff I still need to get and do... seems a fairly large list of small but significant items, this will get ordered up in the new year... I have a bit of time off over christmas and I'll be flitting between mine, the Lupo and whatever else is kicking around...
    Mani should be going off tomorrow to the guy doing the welding but not sure when it will be back...
    Still... its progress and the list of jobs is going down slowly...
    Sam_, StaceyS3 and chaz20vt like this.
  21. vroomtshh
    vroomtshh Active Member
    362
    49
    Is that coolant kit a special order? I didn;t get those two hoses in my kit :-(
  22. <tuffty/>
    21,157
    3,835
    No special order... just what came with the kit Forge gave me... TT kit iirc...
  23. vroomtshh
    362
    49
    FMKC8LS3 ?
  24. <tuffty/>
    21,157
    3,835
    I had a kit based on FMKCTT225 which is the TT one... they didn't have an S3 one at the time and built the kit off my feedback... yours should have the joining hose from the coolant housing on the head to the hard pipe and the pipe to the after run pump which my kit didn't have
  25. vroomtshh
    362
    49
    Yeh looking at the images, theres one hose different, and I should have the coolant housing to hard pipe one extra (it's different on an LCR btw, I bought an S3 coolant housing)
    The photo of FMKC8LS3 has 14 hoses. I'm pretty sure they only sent me 13, so that might be the problem.
    Will need to double check them all after work now
  26. <tuffty/>
    21,157
    3,835
    Small update... have painted a few things but not taken pics as yet as I have a couple more things to sort...
    In the meantime I got a pic sent to me from Marcus at F4B UP who is doing the welding for me...
    early done... exhaust flange, tial flange and wastegate left to do... I am getting the mani back so I can review the wastegate position as I am not 100% as to where I want it to go as yet..
    ...in other news... my order for hoses etc from ASH came today... sterling service considering I ordered this little lot from eBay on boxing day and it turned up via courier on a Saturday!!...
    100mm pipe work for the TIP, 63mm hose for turbo outlet plus a TB hose and some stuff to use for the PCV... should have the charge pipe stuff arrive next week too...
    Should have another update at some point this week as I have all next week off to play :D
    Vex182 likes this.
  27. Lavis89
    1,829
    677
    looks like it is going to be a awesome piece of kit!
  28. superkarl
    superkarl MAN OF STEEL
    9,468
    2,427
    Hour many hours labour we talking for the welder to complete what you've started??
    I think later next year if I have the time il hopefully have learnt at least to tack a weld (wana buy a Clarke mig).
    so would be keen to build a mani out of mild steel and have a pro put it all together.
    So many skills I want to learn, not enough time to do it lol.
    Can't wait for it to come together, itl look great once in the bay.
  29. <tuffty/>
    21,157
    3,835
    Not sure off hand... good couple of days so far I think.... once mine and his initial mani is done he plans to make more and sell them through Bill... I think £850 was mentioned but would need to confirm that.. (1.5" NB version although a 1.25" NB version is planned)
    I wouldn't use mild steel tbh... stainless fittings are relatively cheap and worth using if going to all the effort... biggest headache is finding a supplier for the straight lengths... most only supply in 6m lengths... bit much for one manifold
  30. <tuffty/>
    21,157
    3,835
    Did a little more today...
    Fitted the partially welded manifold to my engine as the charge pipe stuff had turned up...
    Found an ideal alloy bend, 63mm OD and 600mm long... pretty much does the whole top pipe without welding lol (although I will have to as I'll explain later)
    The brackets and clamps need a little modification of course as they are designed for the 60mm OE pipe which has a tighter bend too...
    So I cut slits in the clamps to open them up a little and welded it all up... (ok, I used loads of tacks as thats all I can really do at the moment lol)
    Now the brackets as they need a little work too...
    Extended the clamp and welded all back together...
    The finished result is that the pipe sits in nice and the clamps fit too...
    Had to pack the clamp up a little to allow clearance for the cam belt cover...
    Next I need to add a slight bend to each end as the OE pipe pitches down past the clamp to connect to the hose going off past the the headlight and the hose off the turbo is a little kinked so a slight bend in the pipe will sort that too...
    For those in doubt that my quest for OEM++ may be a little unachievable with a dirty great turbo bolted to the back of the engine then maybe this will give you an idea of where I am heading...
    What big turbo???
    ...oh... THAT big turbo... :)
    Still got the wastegate to sort out and a few other odds and sods... have ordered the heatshielding and heat wrap for the downpipe... have also emailed a couple of companies asking for quotes on ceramic coating as I think its worth getting the mani done..
    More tomorrow hopefully
    sssline, StaceyS3, Sam_ and 3 others like this.
  31. micky2 not 1
    micky2 not 1 Member
    59
    Tufty has been given special dispensation to fab his own...( Bills secretly paying me to get it done so he can have his garage back!!!!!)
    Personally its very hard to redo someone elses work. Mines th other manifold for my HTA wheeled GT30 turbo.
  32. Prawn
    11,510
    3,423
    Only you PT, Only you could install a fecking GT35 and somehow keep it looking OEM!
    Amazing!
  33. Gops
    3,198
    666
    Porn!! It's all porn!!!
  34. Broken Byzan
    13,237
    465
    Shouldn't you be welding something? :p
  35. daz-20vt
    daz-20vt Well-Known Member
    2,835
    582
    Oem cars arent that clean lol. What a car. I dont know how you guys do it. The time money or patients. Top work!
  36. Lavis89
    1,829
    677
    is being built @ B5? if so then im going to have to get my eyes on this beast in the flesh when i head up there next week!
  37. micky2 not 1
    micky2 not 1 Member
    59
    cant, waiting for tufty to stop fannying around with brackets and covering his manifold in oil again and get me his wastegate tacked *cough* on. :p
  38. <tuffty/>
    21,157
    3,835
    Oh shush you big blouse lol... top of the list for tomorrow... :)
  39. Broken Byzan
    13,237
    465
    I need to line mine up so you can do that, can't have you getting bored :whip:
  40. badger5
    9,471
    1,988
    Is that why I am now down 2 ramps currently with other peoples cars? lol
    hehe
