My minor modding thread
<tuffty/> Jul 29, 2009
  1. Prawn
    11,675
    3,672
    to be technically correct and factory, which way should the writing be on the cambelt?
    Not that I'm going to change mine if it's wrong of course :laugh:
  2. badger5
    9,603
    2,061
    I presume viewed from #1 end it should read correct?
    good question..
  3. aragorn
    18,608
    871
    The Audi service manual makes no mention of belt installation orientation.
  4. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    That made me laugh! I have no idea which way mine is facing, but I do care about it staying tensioned and on! :)
  5. Scullies
    Scullies Well-Known Member
    1,543
    658
    the cambelt is an easy fix, just paint it black
    no writing = no problem :)
    MIGGZ, StaceyS3 and <tuffty/> like this.
  6. Sam_
    Sam_ Down under
    3,038
    480
    It should be covered up anyway....
  7. <tuffty/>
    21,885
    4,204
    It will be once I have decided if I am just painting the old cover or getting a new one :)
  8. chaz20vt
    chaz20vt Member
    428
    21
    I like how much detail you go into with this
    Spot on...
  9. <tuffty/>
    21,885
    4,204
    Little something turned up at the Badger Cave today :D
    ...project manifold is a go then :)
    Gizmo20VT, Westy and Sam_ like this.
  10. Westy
    Westy Well-Known Member
    17,443
    1,105
    Thought you were making a Pegani Zonda exhaust ;)
    fema|| and Gops like this.
  11. Andrew@A.L.D
    3,879
    617
  12. <tuffty/>
    21,885
    4,204
    Here :) ->collector info
  13. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    Where are you sourcing the tubing Tuffty? and what schedule?
  14. badger5
    9,603
    2,061
    Gops and Goubo1 like this.
  15. CazzaVR
    CazzaVR Member
    260
    15
    Oooh- looks very interesting! Very nice car mate- been working my way steadily through your thread- it's a real credit to you 8)
    Gizmo20VT and <tuffty/> like this.
  16. <tuffty/>
    21,885
    4,204
    Been a little while since my last update as I have been helping Bill catch up on stuff and had to send the collector back as they had made it in 1.25" ID tube rather than 1.5" ID tube... in the mean time I got the 70mm TB blasted ready for having beads welded on and of course painting :D
    I also painted the cam belt cover and modded it for the manual tensioner
    The new collector turned up Friday so game on...
    ...Nortech (the stars that they are) even did the final capping run on this one...
    ...and of course the obvious difference between 1.25" and 1.5"...
    ...it begins...
    So tomorrow I am gonna make a start and see where I end up... what is evident from my initial faffing is that its not as easy as you would imagine to work out where all this goes and to keep it all away from stuff that could melt...
    I have not discounted going underslung either... :)
    Hopefully some progress pics tomorrow...
  17. Broken Byzan
    13,237
    466
    actual YAY !!!
  18. <tuffty/>
    21,885
    4,204
    Long but productive day...
    rigged up a bracket to hold the collector in place as its next to impossible to hold that and tubing etc at the same time...
    Started with cyl 1 runner as this would have to tuck close to the block..
    Unfortunately some idiot had put a transfer box in the way and both the runner and the collector was too low to get anything else in so pulled it apart and started again... moved the collector a little higher and re-did runner 1
    runner 2 in weld tape (tm) stage...
    Runner 2 coming together...
    Now clears stuff and fits nice...
    Runners 3 and 4 were pretty straight forward comparatively...
    Had to make some adjustments to the bends to allow clearance (not loads of course but hopefully enough)
    Need to trim the transfer box bracket though...
    ...but it seems to fit ok and looks pretty good all things considered...
    ...so of course I had to try it on the new engine...
    ...and of course I made sure that all the studs were accessible... the most "awkward" ones being..
    ...and
    The manifold should be easy to fit in situe which of course is the next thing I have to do and once fitted to the mock up engine in the car I can work out where the wastegate will go
    All in all not too bad considering its my first attempt and I have never used a welder before... started just after 10am and finished up around 7pm... rather tired now to say the least lol..
    Plan to grab a couple of days off work to finish it off and then it can be welded up... :D
    Kuvi-S3, Alex C, ScottD3 and 6 others like this.
  19. badger5
    9,603
    2,061
    Superb
    <tuffty/> likes this.
  20. micky2 not 1
    micky2 not 1 Member
    59
    like it paul. Personally id want it a little higher purely to stop it cooking the TB. bt mines more track than road so you'll have lower temps. Great job....i got competition ;]
  21. jojo
    28,998
    3,652
    x2
  22. Gops
    3,198
    666
    Looks absolutely brilliant! Was following this all day on FB!
  23. Lewis583
    956
    91
    That looks the nuts Paul. Easily on par with some of the professional manifolds available.
  24. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Nice... you will be making TFSI Quatrro Downpipes soon...;)
  25. superkarl
    9,610
    2,481
    How did you figure out where to mount the turbo? I mean whats the thought process behind the collector being in between 3 and 4? Youl obv have loads of room for the downpipe
  26. Sam_
    Sam_ Down under
    3,038
    480
    Awesome work. Placement looks close to TSR but lower and more central between 3 and 4 whereas TSR is closer to 3.
  27. Prawn
    11,675
    3,672
    Fantastic work PT!
    Drilling into that with a big holesaw to add the waste gate will be a scary moment!
    I assume the WG take off HAS to come from the very top of the collector so as to divert gasses from all 4 runners?
  28. <tuffty/>
    21,885
    4,204
    Thanks guys... I was quite surprised how well its gone so far... didn't expect to be this far along... of course the tricky bit now is getting the weld sequence right so as not to 'paint yourself into a corner' so to speak...
    Karl... most of the mani's I have worked with or seen tend to place the turbo centrally between cyl 2 and 3 or just over cyl 3... they also stick the turbo high up which on smaller turbos works ok but they all still make the DP a challenge... most manis are made for the US market and they don't have servo's and other stuff in the way so I wanted the turbo in a more OE position so it gave me more room there...
  29. <tuffty/>
    21,885
    4,204
    Yeah pretty much... this is why it will be measure twice and cut once :)
    Will have a faff at the weekend
  30. Prawn
    11,675
    3,672
    can't wait until it's all done mate, getting the mani out of the way seems like a massive step
  31. Scullies
    1,543
    658
    Awesome work meneer :thumbsup:
    When the guys welded my mani together, they started with the runners, once they were all done, its was a calculation game to see which runner to weld at what time to the collector. But im sure you know all this by now after welding for a day :)
    LHD and RHD manis both have their issues. RHD has more space on the TIP side, where LHD has limited space on the TIP side. On mine, a 4" to 3.5" silicone reducer just fits past the valve cover and brake servo and my turbo sits higher up. Would never fit if I mounted mine at your level. I would have to go TIPless :(
    Then on the exhaust side, RHD is limited by brake servo and LHD could fit a 5" DP :)
    Also with the turbo being lower you have tighter angles to work with for the downpipe VS the turbo being a bit higher up you have a bit more room, not much but every ball hair counts :)
    S3 with longitudinal setup FTW
    Interested to see where you route the wastegate pipe? Similar to what Bill did on Stacey's?
  32. <tuffty/>
    21,885
    4,204
    I am no stranger to the awkwardness of making a DP for a low turbo... my last setup was underslung remember ;P
    I might look at using 3.5" out the turbo but tbh 3" serves Bill's Ibiza ok so rather than try to fit large stuff in a small place I may just stick to 3" all the way... not chasing numbers with this so its down to whatever is practical...
  33. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,496
    212
    Very impressive mate!
    you must have the patience of a saint.........I'd be dying to drive it , clucking to get it finished lol
    Sean
  34. badger5
    9,603
    2,061
    feck that lol... biggest we can fit in there dude :)
    'because we can'
    Lewis583 and <tuffty/> like this.
  35. <tuffty/>
    21,885
    4,204
    Well... thats the down pipe plans sorted LOL... :D
    Vex182 likes this.
  36. <tuffty/>
    21,885
    4,204
    My patience is a side effect of my OCD... I do want to get it done and it kills me not being able to drive her but it needs to be done right and it would kill me more if I rushed anything for the sake of it and it wasn't right :)
    badger5 likes this.
  37. scotty_24
    scotty_24 Well-Known Member
    1,052
    250
    Awesome work mate, this is some car!
  38. Sam_
    Sam_ Down under
    3,038
    480
    Forward planning for the 40 psi ;)
    StaceyS3 and Jason.s like this.
  39. Scullies
    1,543
    658
    Thats pretty low :)
  40. Andrew@A.L.D
    3,879
    617
    for me would be very low lol
