My minor modding thread
<tuffty/> Jul 29, 2009
  1. ap
    ap Member
    Sorry to interrupt you build thread with a question, how or what is the technique of getting the plastic scuttle panel to clip back into the windscreen lower channel? I replaced mine with nice new one a week or so ago and could only get the ends to lock in place.
    Andy
  2. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    place it on the groove and light tap it into place, but be very careful that you dont crack the windscreen, if you can use your thumbs
  3. MIGGZ
    1,461
    304
    top work as always dude. but that tank is small hey, dont know how much driving you do with the car
  4. Scullies
    Scullies Well-Known Member
    1,543
    657
    LOVE YOUR WORK DUDE - you make things look so easy.
    Are these the only things you need to run a "DIY" WMI setup ?
    Plus the tank/fluid lines/fittings/wiring - obviously :blush:
    So my understanding is,
    Once the boost reaches the preset on the pressure switch, the pump kicks in at full operating pressure, suppling the WMI to the small nozzle(s)
    BLACKEYE S3 likes this.
  5. MIGGZ
    1,461
    304
    elcorecto boss!
    reading gets taken off map sensor or maf
  6. <tuffty/>
    20,827
    3,670
    The channel that is 'glued' under the windscreen that the cover clips into had come unstuck... so as you push to clip it in the channel just sank down so there was no way you could clip it in... I carefully removed this and cleaned it up... using silicon sealant to 'stick' it back to the bottom of the windscreen then I used some hotglue to support the channel as there was a massive gap which I guess if it was stuck on using the proper stuff would not be an issue but I didn't have any to hand...
    This supported the channel well enough to enable me to push the cover back into the groove...
    Yeah, its a little small but I only plan to run it occasionally (hence the switch) and hoping using the smaller nozzles won't use it up so quickly... will see how it goes... I will re-evaluate if it turns out the tank is emptying too quickly... it was ideal for where I wanted to fit it :/
    Pretty much yeah... just works off the pressure feed to my boost gauge... into the pressure switch and bingo... 18psi it switches the relay and the pump gets full juice...
  7. <tuffty/>
    20,827
    3,670
    Mine doesn't... I do have a progressive controller but not using it... they are unreliable and not totally convinced that its particularly 'progressive' at all... dual nozzle and maybe a 2 stage system using another pressure switch and a solenoid maybe... but will potentially try a dual nozzle setup depending on how things go with this... I am only after a drop in IAT's... not fussed about tuning for it as the car does alright as it is :)
  8. MIGGZ
    1,461
    304
    snap did not even see that! sorry bud
  9. Scullies
    1,543
    657
    What psi rating is the pump you have?
    I have seen a few that range from 150, 200, 250 and 300 psi.
  10. <tuffty/>
    20,827
    3,670
    Its a devils own pump... 200psi iirc... the newer ones seem rated higher (300psi)...
    Scullies likes this.
  11. <tuffty/>
    20,827
    3,670
    So finally after owning a WMI kit for over 2 years I have actually got it fitted and working...
    First of course I de-blinged the pump and the tank...
    Fitted the pump and made brackets for the tanks... piped it all up and wired the pump....
    Had a leak initially from the tank pipe as I hadn't pushed it home far enough but once sorted all was good...
    Quick test on the way home from Bill's... ambient was 20 degrees... on cruise IAT's sat at 22/23 degrees.... 'armed' the system and gave the car a blast in third to properly load her up... didn't log with VCDS but fired up the 'Torque' app on my sammy S3....
    The 25 deg was from idling while parked up taking the screen shot... you can see the minimum figure of 12 degrees... exactly the result I was looking for out of this... normally IAT's would increase to 30/35 degrees in 20 degree ambient under boost but the results so far are very good... I gave the car another burst and had the same result... the car felt strong too... she has felt a little lethargic since the weather got warmer which is to be expected but the WMI appears to be doing exactly what I fitted it for... happy bunny :)
    ScottD3 likes this.
  12. superkarl
    superkarl MAN OF STEEL
    9,329
    2,334
    8 degrees below ambient?! Really? I didnt think it was that good wow.
  13. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    What water/meth ratio did you use there Tuffty!
  14. <tuffty/>
    20,827
    3,670
    Yeah... its good **** man... when running on the dyno its typical to see it drop below ambient... not as much as this as a rule as it does get hotter on the dyno than it would on the road... will get some logs at some point when I find the time.... meth off and meth on back to back... get a good idea of the actual benefits then..
    50/50 currently as Bill had some already premixed... will see how it goes and maybe drop to 30/70 at some point as this would be safer to use if I still get the cooling benefits from it..
  15. superkarl
    9,329
    2,334
    I honestly thought it just knocked a few degrees off iats but still ambient or above, climbing with boost. I had no idea it was capable of dropping below ambient on boost. I do remember welly saying his mani wne frosty during winter but thats understandable, and not really good conditions to gauge the gains. Im not sure anybody has documented back to back runs with it on and off, but then ive not bothered to go searching really.
    Up until now ive had absolutely zero interest in wmi...
  16. <tuffty/>
    20,827
    3,670
    Well... its not definitive by any stretch... but Torque uses the same data as VCDS etc (ECU data from the sensors) and I fired it up when the engine was warm and had done a few miles so IAT's were sat at a realistic 2/3 deg over ambient (which is normal on my setup from previous experience)... Torque records min and peak figures on the dials you have setup and there isn't anything else that would make my IAT drop to 12 deg on a 20 deg ambient day :)
    I was surprised tbh too... its not to say WMI would do this on any install as its hugely subjective (my hardware setup is quite exotic compared) but I have seen WMI consistently drop IAT's lower than the registered ambient temps to varying degrees on cars run on Bill's dyno...
    No idea why I left it so long lol...
    s3dave likes this.
  17. Westy
    Westy Well-Known Member
    17,440
    1,097
    Well done Tuffty. WMI is great stuff, I'm still running a 50/50 mix but I don't have a liquid gauge so haven't really done much logging. All the logging I did last year was on VCDS and on a partially working WMI kit. I really should do some more logging.
  18. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Agreed, after a few teething issues mine is faultless now and I can tell real time that its working, having the switch just by the steering wheel....
    Mougge likes this.
  19. Westy
    17,440
    1,097
    I started with a switch but ditched it. My car relies on the WMI so I wouldn't use te switch anyway.
  20. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    Great stuff tuffty carnt wait till mine is done Saturday coming.
  21. g60leigh
    1,674
    207
    I really need to get back on with my wmi set up. Tuffty you are a inspiration LOL
  22. Westy
    17,440
    1,097
    An inspiration lmfao! It took him 2 years to fit it...
    <tuffty/> likes this.
  23. g60leigh
    1,674
    207
    That's why I LOL'd it
  24. Scullies
    1,543
    657
    WOW that's impressive. Did you put ice water in the 50/50 mix :eyebrows:
    Is that just on the small single nozzle setup?
    So you running wmi on the current map?
    Does wmi not throw out the fine tuning of a BT file?
    Are you going to map the wmi in or just run it as you need it?
    sorry for the 20 questions :blush:
  25. <tuffty/>
    20,827
    3,670
    answers in CSV format...
    No, Yes, Yes, No, B
  26. Gops
    3,190
    648
    That looks awesome dude! Love it! :thumbsup:
  27. badger5
    9,321
    1,891
    lol
    Gizmo20VT and <tuffty/> like this.
  28. <tuffty/>
    20,827
    3,670
    Interesting day out today... went the TT Forums North vs South dyno day at Powerstation...
    Bill took the Lupo of course :D
    In preparation of course I cleaned the car... she was looking pretty damn good despite my somewhat epic fail of over wet sanding the **** lacquer job from the 'warranty' paint work I had done...
    Over did the bit where the lacquer had peeled away from the original paint and broke through :(
    ...so for now I have just slapped some touch up over it and will address it later... despite that the rest came up fine.... ah well
    Still she came up ok in the end...
    Anyhoo... back to the dyno day... I hadn't intended to run my car but after a little badgering from Hollie and Bill (no pun intended) I ran her up...
    The runs on Powerstations dyno are very long... seems the dyno puts a lot of load on the car as the poor old girl was glowing a good one... for what ever reason they ran the car again and sadly this lead to the coolant hose behind the turbo decided to let go and piddle coolant over the glowing hotstuff... this lead to loads of white smoke and a small fire on the downpipe... marvellous!!!
    The pipe in question is a stainless hard pipe but has a high pressure heat resistant rubber section to join the two halves together... (right of the picture below)
    Not an easy fix and topping up with water just poured out the bottom again... brilliant!...
    Thankfully Bill being the super hero that he is donned his Badger Man outfit and came to the rescue...
    Hopefully should be a case of remove driveshaft and downpipe and I'll have access to sort it out...
    Cars... gotta love um and todays lesson is (the same as all the others tbh)... heatshielding, heatshielding, heatshielding... anything that is likely to melt probably will :)
    Engine will be out soon for 'some work' so I am going to address some of the issues like this to up the reliability factor...
  29. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    534
    Nice little write up but shame about the ending :(
    I know this probably isnt the best comment....but the pic of bills S6 towing your S3 on the back of a trailer- both in silver is pretty cool looking :) If anybody saw it on the way home they would have just thought it was on its way to a track day!
  30. badger5
    9,321
    1,891
    big audi, little audi... lol
  31. Chlippo
    Chlippo Member
    679
    15
    Aint much lucky there man!
  32. Andrew@A.L.D
    3,872
    608
    I bet the S6 doesn't even feel like its pulling anything, That reminds me?
    Does the S6 have the same engine as the S8?
    You could do this Bill
    Trains part 1 - Top Gear - BBC - YouTube
    National Badger5 Rail
    StaceyS3 and kwistof like this.
  33. badger5
    9,321
    1,891
    yes same 4.2ltr v8 engine
  34. <tuffty/>
    20,827
    3,670
    Got the car on the ramp today and as suspected it was the rubber joiner... looking at it now I am thinking 'why the hell did I do that!' but you live and learn... irony being if a customers car came in like that I would most likely point out that its not a very good idea lol...
    New bit of hose this time with extra heat protection...
    ...and finally (when everything has cooled down after the leak check) a bit of ceramic backed stuff...
    This of course is a sort term fix... I am under no illusion that I need a full hard pipe there and thats what will happen (plus some other planned tweaks) when the engine comes out for 'some work'
    Moral of the story is never to under estimate how hot these things get and heatshielding plus other preventative measures are your friends
    She is leak free now at least and shouldn't have this issue again before the engine is out... yay!
    kwistof, burns3 and StaceyS3 like this.
  35. Westy
    17,440
    1,097
    Good work Paul. Very unlike you that rubber pipe! Sort of thing is do lol.
  36. <tuffty/>
    20,827
    3,670
    Seemed a good idea at the time and I did heat shield it... in fairness its lasted more than 12 months but Powerstation runs are epically hard on cars... things were glowing big time... relentless mani's would melt lol...
  37. badger5
    9,321
    1,891
    Hell yea!
  38. burns3
    burns3 Member
    224
    17
    Heatshielding, heatshielding, heatshielding lol, yeah you made it clear to me i needed some :)
  39. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    Love the picture of bills s6 towing your s3 .......... Mint! Only better would be if bill had badger break down assist graphics on it! :)
  40. Rice
    Rice Active Member
    247
    37
    S6 towing the S3 looks awesome lol.
    Didnt realise how much power this thing was running, oh dayum! Bet you surprise a fair few porschers etc in that!! Looks really clean too, good work! What an S3!
