My minor modding thread
<tuffty/> Jul 29, 2009
  1. Prawn
    11,355
    3,197
    Awesome :D
    I would say I want one of these large port inlets, but as I've already got one as standard, I'm not sure simply increasing the plenum size would help.
    Which plenum are you going to use PT?
  2. <tuffty/>
    20,840
    3,677
    Using the Xcessive one as per Andrew/Stacey etc... gonna be all smoothed out though and painted in an aluminium colour in a vague attempt to keep it OEM esque looking
  3. Andrew@A.L.D
    3,872
    609
    Will you be adding the bosses so you can fit the engine cover?
  4. Jason.s
    Jason.s Active Member
    2,879
    348
    You mean like this kind of thing on post 20? KilometerMagazine.com - Big turbo 1.8t Golf with the luxury of AWD
    People going BT with A4s on Zine seem to love doing this. Don't know how effective it actually is but enough of them do it do must do some good? Someone over here needs to test one. How much are aeb inlets going for?
  5. <tuffty/>
    20,840
    3,677
    Yes mate... will be keeping the cover on but I will be painting the cam cover the same colour as the mani and charge pipes anyway...
    This plenum...
    Larger plenum gives more consistent distribution of air to the cylinders (like a reservoir of air)... it is said that for a forced induction car the plenum should be 1.5 x the capacity of the engine so in the case of a 1.8t thats around 2.6ltrs...
    Paid £20 for my AEB inlet... AGU runners can be used too of course... AEB runners curve down while AGU runners are straight... no real benefit of one over the other really just down to what you can get your hands on I guess...
  6. Jason.s
    2,879
    348
    Yeah i know what one you`re using just thought Prawn meant the sort of thing i posted :) Might at some point find another inlet and get it extended like that link. Although i cant see it doing a huge amount on my basic set up but worth a go if its cheap.
  7. Andrew@A.L.D
    3,872
    609
    I saw a 20 bhp gain from my manifold with it only running 10 psi I didnt take note of the torque but it did want to rev more with it
  8. Westy
    Westy Well-Known Member
    17,440
    1,097
    I'd quite happily buy an inlet mani for my car if they were a bit cheaper.
  9. Prawn
    11,355
    3,197
    You see it's posts like this that get me thinking!
    Everyone is saying it's not needed at lower power levels, yet you say you've gained 20bhp from the inlet when you're only at ~280bhp levels.
    I'd love to know how much of this is down to the better design and larger plenum, and how much is simply down to you having the 'wrong' small port inlet on the large port head.
    I'd love to try it and see if there are gains to be had, but I'm not sure if I'll see any gains at all considering I've already got a large port inlet on my large port head.
  10. Andrew@A.L.D
    3,872
    609
    Don't forget we have bigger turbos that flow a lot more than the k04
  11. Prawn
    11,355
    3,197
    true, but 280bhp is 280bhp and will be flowing the same amount of air surely? The boost isn't even THAT different, mines 275bhp at 14psi from the hybrid.
    So if it's making those kind of gains at 280bhp then surely similar gains should be seen regardless of turbo?
  12. <tuffty/>
    20,840
    3,677
    Arguably but that doesn't mean you would get the same gains... too many variables involved... the Mk2 GOlf we did had an AGU inlet mani and managed over 450hp...
    Only one way to find out :)
  13. Westy
    17,440
    1,097
    At the moment I already have too much air for the injectors to cope with ;)
    I cant wait to see some more comparable dyno results for the inlet.
  14. StaceyS3
    StaceyS3 Well-Known Member
    2,487
    466
    Got to admit I'm pretty gutted that I won't be able to see before and after results for my inlet unless bill changes it halfway through the mapping :(
    But will be good to see some documented dyno results ;)
  15. <tuffty/>
    20,840
    3,677
    I have some previous dyno data to fall back on when I come to run mine up... the main changes between my last runs and when I run her up wit the inlet etc on will be the inlet, 63mm pipe work from the FMIC to the TB and thats about it... it will of course be running a map I have been developing but tbh from a WOT power run perspective it will make no real difference.. .airflow is airflow, boost is boost, AFR is AFR ect and all that will have essentially changed is airflow capabilities..
    I have spent a lot of time on my car so will know if the inlet makes a difference... you only have to see the result Welly had with his to know that at this level at least there are gains... most of the GT3071 turbo'd cars that have been mapped at Bill's that have had larger inlets have made over 400hp... those that didn't (mine included) had other issues such as restrictive hotsides/smaller turbines etc... its all about total flow through the engine...
    Its not the sort of thing thats an easy swap to do on a before and after test realistically as typically the TB is in a different position and requires mods to get it all plumbed up right even if bolting the thing on take only 'some' minutes...
    I did see improvements when I fitted the SEM that one time with no other change but again my setup is wildly different to the average S3 owner
  16. <tuffty/>
    20,840
    3,677
  17. Schlaag
    Schlaag Bwah
    472
    32
    Amazing thread Tuffty... I initially popped in to check out your JR cone in a std airbox info... but carried on right through. Great stuff
  18. Prawn
    11,355
    3,197
    Argh. No links to manifolds please Tufty! I'm SOOOOOOOO tempted.
  19. <tuffty/>
    20,840
    3,677
    Decided to take advantage of the nicer weather and longer evenings this week and make a start on doing some stuff to the car thats long overdue...
    I have a coolant leak and Forge have been kind enough to supply me with a hose kit they are developing for the S3 based on the current one they do for the TT.. doing all these hose meant taking most of the bay apart to allow easier access especially as I have a few extra bits in the way... I also took the opportunity to offer up the AEB runners I have for the inlet manifold I am fabricating and see where everything is going to end up...
    Engine bay emptied... also removed the alternator and belt tensioner as I believe it to be causing my flat battery issues and the tensioner is making an odd noise due to the proximity of the coolant leak...
    AEB runners test fitted... will grab the plenum from Bills tomorrow to mark where the back plate will go and I can trim the runners and cut the holes out the plate ready for welding... I turned the dipstick tube around so that it sticks up more upright and should sit nicely between the runners...
    The hose that was leaking was the one going to the bottom of the expansion tank...
    ...sat next to the Forge replacement...
    Tomorrow evening I plan to drain the coolant and start replacing the hoses... there are two hoses I know aren't in the set Forge gave me so will let them know in case they have left them out by mistake or just not made them yet... not sure... there are also a couple of extras I am not sure about either but then thats kinda the point of this exercise :)
  20. StaceyS3
    2,487
    466
    Nice one mate am patiently waiting on this kit ;)
  21. Westy
    17,440
    1,097
    I could have done with this kit at Easter :(
    Good to see this thread on the move again.
  22. <tuffty/>
    20,840
    3,677
    Quick update...
    Seeing as I am all up in the OEM look I have been seriously tearing my hair out (whats left of it) to work out how the hell I can make a rather large fabricated inlet manifold look OEM... so... made a desicion that I would smooth it and colour code the charge pipe, cam cover and inlet manifold so that it is more OEM++ than my normal OEM+...
    I bought some Simoniz wheel paint ages ago to refurb either my TTRS's or the spare set of Avus I bought as winters that I have now sold to the wheel/tire whore Prawn... Thought I would start small just to see what it would it looks like and prepped one of the charge pipe clamps...
    Doesn't look too bad colour wise... it did go a bit dark at one point but seems to have settled ok... good few coats of lacquer too and nice and shiney... I know everyone will start saying I've copped out but tbh I am still going to retain the covers and it will take a second look to realise that somethings not quite right... :)
    Plus I am fitting a huge intake for more power so waddya gonna do!!
    Charge pipe is off... looks tatty compared so something had to be done really anyway... already modded for the turbo location and painted black...
    However... the join may look a little obvious once painted a lighter colour so I might grind and fill this bit to smooth it out...
    Off to remove hoses now :)
  23. Prawn
    11,355
    3,197
    Steady PT, or you'll end up looking like this:
    Good work though, can't beat a bit of 5 wheel steel!
  24. Rosso TT
    Rosso TT Member
    146
    Tuffty, have you ever though about sandblasting it?
    Got my roker cover sandblasted, it doesn't quite match the finish of the intake mani but one day i'll sandblast that too.
    It is a pita to get it cleaned once i stick my greasy fingers on it but with a coat of clear will solve that.
  25. <tuffty/>
    20,840
    3,677
    I will be getting it blasted prior to painting it... happy enough with the finish of the wheel paint so painting it all that colour will pull it together nicely I think
  26. <tuffty/>
    20,840
    3,677
    Busy evening... had to remove quite a bit in the end as it was easier to do with all the hoses out of the bay... so ended up with...
    As you can see I ended up cutting the ends of the hoses as they had welded themselves on to the metal hard pipe... I have seen this before so was expecting it but what a ballache!!..
    Left a nice amount of rubber stuck the to stubs too...
    Which I cleaned up with a sharp knife and wet and dry...
    The OEM clips are a ******* to do without the right tool (which Bill has at the workshop) but managed to get them all off and the Forge hoses fitted
    Will clearly look a bit better in the light and once the bay is back together and clean of course... couple of clips to do up, expansion bottle and the lower rad hose from the stat housing to do and that will be all done
  27. Scullies
    Scullies Well-Known Member
    1,543
    657
    Tuffy, have you relocated your battery yet? Where does it sit in the boot? Wondering if it will fit in the sub box area.
  28. <tuffty/>
    20,840
    3,677
    Not done it yet but will be fitting in in the spare tyre well against the back panel and in the centre...
  29. <tuffty/>
    20,840
    3,677
    Warm day at the 'office'.... took the opportunity to OEM++ paint some more stuff...
    First the DV...
    ....turned out quite well...
    ...and did the charge pipe and remaining clamp...
    Finished off fitting the hoses too... large one from the bottom of the rad... still a c-unit to get off but brute strength and ignorance prevailed and got a nice G12 shower for my trouble too...
    Last hoses to go in were the one that goes to the bottom of the expansion tank (the leaky one) and the one to the top of the expansion tank...
    Will paint the throttle body and some point and the cam cover once blasted... might play with the inlet manifold a bit tomorrow if I get the time :)
  30. Prawn
    11,355
    3,197
    We need pictures.
    I know they exist, so show us the goods!
  31. <tuffty/>
    20,840
    3,677
    Hot day again and far too hot to be hot to be cutting out and filing holes in the mani back plate but I did anyway... could have probably got them machined but where is the fun in that :)
    Anyhoo... here are some pics of a test fitting for position.. was only a quick throw it on job as I was due out for a meal...
    ...and of course as its the OEM++ look...
  32. Andrew@A.L.D
    3,872
    609
    Big buggers arn't they when fitted lol
    looking good
  33. badger5
    9,321
    1,891
    that looks reasonable position wise.. nice
  34. <tuffty/>
    20,840
    3,677
    Yeah surprisingly... vac outlets underneath will be next to useless though I feel as its pretty close to the alternator... the phenolic should lift it a bit but I am thinking of a thickish bit of ali plate welded underneath and drilled/tapped for outlets will present a better solution...
    The pipework will need doing again I think but then was expecting that and will go to 63mm (60mm currently)... but battery needs to go in the boot first :)
  35. Oke Phill
    Oke Phill Member
    152
    Bloody hell Tuffty!! Just read this whole thread, and it makes good reading. loving the car and the attention to detail. Best colour too!!lol
  36. <tuffty/>
    20,840
    3,677
    Good friend George dropped off my cam cover today all blasted.... so after a wash and a rinse to remove any media that may be left I got on with a bit of painting... not much left to say really so here are a few pics... just before the bloody rain started!!!!
    OEM++ and clean looking... :D
    Sandra likes this.
  37. Prawn
    11,355
    3,197
    Looking good PT,
    your obsession with OEM look will never cease to make me chuckle, but it is impressive!
  38. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Gold Supporter quattro Audi S3 s tronic
    25,436
    8,530
    Looking very impressive Paul. Get out there and work in the rain, you wont melt. Btw, its sunny here in West of Scotland. :) x
  39. <tuffty/>
    20,840
    3,677
    Got up early in between showers... finished putting the engine bay back together and well pleased with the results so far...
    Happy that the colour of the charge pipe doesn't make the bay look too modified :D
    Started the car up after nearly 3 weeks off the road... warmed her up and topped up the coolant... all good so far so decided to take her to Bills and get some fuel on the way as the warning was on...
    Got about 2 miles down the road and the low coolant warning came on again... bugger... probably needs topping up a bit more as I did drain quite a bit when doing the hoses..
    Opening the bonnet I was shocked to see that there was coolant everywhere!!! arse!!! I had some coolant on me so topped up and decide to drive home carefully... 200 yards down the road and on it came again!!! arse++ must be a big leak :(
    Managed to nurse the car home and washed down the bay to stop the G12 from staining everything... little bit of an investigating later and discovered that the plastic housing leading to the top of the rad had broken...
    Aged brittle plastic + brute force and ignorance = fail!
    Looking at the one housing revealed that it may well have been a pattern part and changed in a previous life as Bill had one kicking about (like he does) which had VAG part number on it but mine didn't and the shape of the thing is a little different...
    Ah well... I will order some from TPS Wednesday although this has stalled my plans somewhat this week... cars... gotta love um :)
    Sandra likes this.
  40. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,119
    353
    Thats a shame tuffty! Been waiting so long for this to be up and running.
    Engine bay looking very smart and OEM btw
