My minor modding thread
<tuffty/> Jul 29, 2009
  1. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Did you get the DV black mate? as all i can see on the forge website for that is the gash alloy coloured one.
    cheers
  2. <tuffty/>
    21,899
    4,206
    Painted it... was silver when I got it...
  3. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
    did you have any celebrations for reaching 1000 posts??
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    lol, thanks a good question Tuffty, this thread is getting sizeable...
  5. superkarl
    9,612
    2,481
    the rolling road day should be a /1000postparty for tufty. he has to get the beers in though
  6. Welly
    10,696
    130
    He needs an 'I Am Tuffty' T Shirt me thinks....
  7. superkarl
    9,612
    2,481
    Or we could have made some, I :wub: tuftythread t-shirts
  8. <tuffty/>
    21,899
    4,206
    oh dear.....
  9. Welly
    10,696
    130
    That's it, I'm off down the T Shirt making shop....
  10. superkarl
    9,612
    2,481
    lol
  11. MUSH
    713
    12
    Aah, cheers mate, think ill be doing that...
  12. finesse
    finesse Active Member
    2,805
    tuffty, did you remanufacture your autobahn88 tip?
    looking for one...
  13. <tuffty/>
    21,899
    4,206
    No mate, was sold with the K04..
  14. <tuffty/>
    21,899
    4,206
    Little update....
    After popping the throttle body hose for the second time (at low boost) in a country lane in the middle of the night I asked Bill to weld some beads onto the throttle body to stop this happening again... R32 TB's don't have the bead around the edge like the std 60mm TB as its not a turbo car... lack of a bead for the hose/clamp to sit up against is the main contributor to hoses popping off...
    Thanks mate :thumbsup:
    While Bill was happy in TIG land fabricating bits for a GT30 powered Mk2 Golf, I got my car on the dyno to take a few logs and see where the N75 was in the grand scheme of things as I want to use the N75 again albeit in parallel with the MBC... part throttle with MBC's is a little erratic at times and I want to see if I can sort that...
    I have found a page where someone uses an N75 normally but uses a switch on WOT (wide open throttle) to switch an N249 valve into re-routing boost control from the N75 to the MBC... this way you get ECU control over boost when driving normally and MBC boost sustainability under WOT
    The link is here:
    MBC/N75 Boost Control results - NewBeetle.org Forums
    I may well have a go at this at some point...
    Anyhoo.... operating a car on a dyno is a very unnatural experience... first thing I wanted to do is release the handbrake (which is left on while the car is on the dyno) and then once I started off in first gear I wanted to put my seat belt on!!!... lol!
    Did a couple of runs on actuator pressure... pretty evident I am getting bad boost creep as the internal gate is now far to restrictive for all the extra flow the charge system and head now provide... its a 1 bar actuator but with preload starts opening about 0.8 bar... boost then creeps up to over 24psi at over 7k rpm... this will be manageable once the mapping is sorted as this will be around the boost I will end up running but not the best thing that could happen... Basically it means I have to have the head off again and either port the **** out of the internal gate (as Bill did to Welly's) or go external gate as my manifold supports this... I am of course going external gate as I want to do it right, first time...
    I did a couple of runs logging timing pull etc (there was no timing pull at all) and AFR was far too rich killing any hope of power higher up the rev range... I didn't run the car today to see what power I had anyway but its pretty evident there is some work to do as the current map is way out...
    Last run I did was to see what the N75 was up to.... I pulled out about 4k rpm as the boost hit 33psi!!!!... N75 is now unplugged :blink:
    After the runs I pulled the graphs together including one from before I fitted the large port head etc...
    The red lines are the current setup with actuator (and boost creep) pressure only... running my previous map etc... the teal coloured lines are from my previous setup with the unmodded FMIC and charge pipes + small port head.... the orange lines are from the aborted run with the N75 connected... I have included this as you can see the potential the engine now has once I throw some boost at it...
    In the second pic you can see where the boost was heading before I aborted (orange line) and the boost creep (red line)... I didn't log boost on the runs before the large port but was running about 1.5bar at the time..
    The interesting thing is I am potentially getting full boost (1.6bar) well under 4k rpm, which (from memory) is much earlier than before... also when you compare the power lines from before (teal) to now (red and orange) everything is happening much earlier in the rev range than before....
    Thats about it for now... got a bit of work to do but she is showing potential for plenty of power :yes:
  15. Welly
    10,696
    130
    :faint:
    All the boost then..... lol.
    On a side note, I see that losses between flywheel and wheels have increased quite substantially since the run there in July... Any idea why?
    Interesting that again it looks like the cylinder filling capability of the large port heads shines through - I'm looking forward to final maps of this, will be very interesting.
    I'm standing by my 401 bhp predicted....
  16. <tuffty/>
    21,899
    4,206
    No mate.... may have just been an issue with that particular run.... maybe the ramp rate.... regardless of 'figures' its the curve etc that counts... ;p
  17. jimes
    jimes Member
    30
    clean the tb and pipe although i dont think yours is oilly and spray a bit of hairspray on then clamp up, works on my impreza and is a ****** to get apart!
    Anyone thought of using a twin plenum intake like the skoda wrc's? just wonder if theres any gains? maybe because they use alot of compression? would like to know!.....
  18. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    I like that link Tufty, thinking outside the box
  19. <tuffty/>
    21,899
    4,206
    All clean mate... bead rolled on ali pipework or beads like this is the only way to prevent silicon popping off... some cheap ebay kits come with non at all on the pipework... as soon as a bit of boost goes through them they pop off... simples :)
    Sheer clamping force isn't really enough...
  20. <tuffty/>
    21,899
    4,206
    Wish it was my idea but still a good one non the less... simple yet effective...
  21. badger5
    9,603
    2,061
    WD40 on the tyres, much grippier & stickier.
  22. Broken Byzan
    13,237
    466
    Already seen that from slighly exagerated rollers.LOL
    Time will tell, by the time he has finished re specing and building it will be a solid 420, then when Bill has his way ( GT35) it will keep going up and up. Snigger
  23. badger5
    9,603
    2,061
  24. badger5
    9,603
    2,061
    :D
    tiggy-tastic
    GT3071/0.63, 38mm tial external gate.
  25. Welly
    10,696
    130
    That's looking good now dude, I will have a good ganders later on....
  26. Andrew@A.L.D
    3,879
    617
  27. <tuffty/>
    21,899
    4,206
    As mentioned in post #1014, yes... :thumbsup:
    As can be seen in the pic below, there is a platform for 38mm bolt on external gate, it just needs to be machined... I may look at using a v-band one though and make up an adaptor plate... the v-band wastegates tend to be smaller physically which is a little better in terms of getting it to fit nicely..
  28. badger5
    9,603
    2,061
    not to detract from tufftys thread... but i cant resist
    another gt30 kinda installation going on presently
  29. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Is that a screamer pipe?
  30. superkarl
    9,612
    2,481
    looks like it goes back in to me. orrrrr does it. they sound insane
    im guessin its not in an s3, no way will that fit. would be nice to see that huge blower though!
    p.s you have the cleanest workshop i've ever seen
  31. <tuffty/>
    21,899
    4,206
    Not a screamer no, goes back into the exhaust...
    That setup is actually going into the Golf in the background but would potentially go into an S3... fits better with the compact comp housing like mine... thats the same spec cartridge (GT3071r) as my turbo but its using a T3 0.63 A/R turbine housing rather than the T25 0.64 A/R I have... did similar installations on an A3 TQS (GT2871r), Polo GTI (T3 somat or other) and an Ibiza Cupra (GT3071r... Polo was well tight but got into Redline magazine and was dyno'd at 485bhp...
  32. superkarl
    9,612
    2,481
    its hard to see how that would fit it being top mounted and freekin huuuuge. serious piece of kit though. and in a mk2 golf, that will be one bonkers car!
  33. badger5
    9,603
    2,061
    kind of.. but not.. it joins the exhaust system. Too loud otherwise and not track friendly (this is a track car toy for someone)
  34. badger5
    9,603
    2,061
    the fmic picture a few posts up is the same car.
    Almost identical setup going into a mk3 ibiza cupra also. 400bhp cars when done (and some) :) nutty but fun.
  35. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    I read about that Polo in Redline and read most of his build on Edition 38, awesome stuff.
    Nathan
  36. Speedy Steve
    Speedy Steve Active Member
    1,258
    i want one
  37. <tuffty/>
    21,899
    4,206
    Not had time to do much to the car recently but had a chance today to do a minor mod I have been planning for a while...
    I have been running an MBC for some time now and while it does exactly what it says on the tin, part throttle situations can be a little rough so I really wanted to go back over to the N75 as a method of boost control to see if it would smooth things over...
    The first attempt at this resulted in 33psi at 4k rpm... not the best... duty cycle of the N75 needs a tweak in the map then :thumbsups:
    After reading about running an MBC in parallel I thought I would give that a go... here is a pic I found on how to connect it all up...
    I bought a couple of t-pieces and had a go...
    The turbo holds 1.5bar once spooled to the redline... brilliant :)
    Spoke to Bill before I left the unit this evening about mapping and will hopefully be looking to get this sorted as soon as he has a slot to fit me in.... ME7.5 ECU's are pretty damn clever and can compensate really well for the differences my recent mods have made but I am still getting no timing pull and there is more power to be had and some improvement in spool...
    Only other thing I have done is fitted a JR cone filter after being inspired by seeing the jolly decent OEM look install by Warleydaddy when he was over for the ASN dyno day at Badger 5 earlier this month. I will of course be developing this a little further and do a write up with pics once I am happy with it all...
  38. Welly
    10,696
    130
    TIP end of the N75 venting to atmosphere there dude?
  39. <tuffty/>
    21,899
    4,206
    Yarp... think of it like the bleed hole of an MBC....
  40. Welly
    10,696
    130
    LOL, don't worry, I was.
    Thats cool dude, glad this has worked out well as per our discussions about it.
    May follow suit if all good.... :thumbsup:
