My mapping day didn't go as planned
Andrew@A.L.D May 8, 2012
  1. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Purest! Lol, your engine must barely resemble a 1.8T now! Love it though, hope you break 600bhp :)
  2. badger5
    9,400
    1,944
    i dont have any balls... they fell off years ago
  3. badger5
    9,400
    1,944
    I do corners... and have to brake too :p
  4. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
  5. jojo
    28,846
    3,509
  6. vrbob
    2,375
    171
    Thats the one Jo so hopefully for the 16K asking price its been put back together properly :)
    I do like his wheels though......
  7. Sam_
    Sam_ Down under
    3,035
    480
    I mean you can get decent power from a 2.0 without worrying about rods. Seemingly bolt ons and a map gets you a lot more. I might be on crack though...
  8. Andrew@A.L.D
    3,873
    609
    A little update on the noise coming from the pulley
    Its seams a bolt from behind the crank pulley had worked its was loose and was scrapping the back of the pulley
    A simple fix and its back on the rollers for a bit more work today as i popped in today to fit a better T pipe that i made this morning for the dump valve back into the tip
    Paul is a bit busy today mapping a Drift Skyline this morning and he hopes to do a bit this afternoon on mine
    There was talk between Paul and I about 550bhp. Yes i'm sure 630bhp can be made but that would mean running max boost
  9. fitzdog88
    fitzdog88 Member
    59
    I hope i see this monster roaming around leeds its gona wipe few smiles of peoples faces mate
  10. badger5
    9,400
    1,944
    you said you were wanting to run 30psi...... >600bhp from GTX3076
    I would'nt personally want to run it that high tho
  11. Andrew@A.L.D
    3,873
    609
    I will see how Paul goes with it
    I will be fitting a boost controller to turn it down for day to day driving so its not going to run its full 500+ @ XX? psi of boost
  12. <tuffty/>
    20,896
    3,705
    TFSI have the same **** rods as 20v's... they just aren't of an age where they have started to fail... they also suffer from coking up of the inlet valves from not having fuel pass over them, injector size is limited to the largest ones available to std production cars as they are special... they also rattle a bit on idle and have issues with the high pressure fuel pump drive...
    That said... they are responsive to certain mods and yes you can get 'more' power for your money as such but its relative... its a 2ltr stroker, the turbo's are larger, its fuelling is more efficient etc... so from that respect they are good and the Mk5 chassis handles better than the Mk4...
    Converting a 20v 8L to a TFSI imo is a bit of a task as you would need the ECU and all the other gubbins as the MED9 is far more complex an ECU than the ME7 due to the funky fuelling system of the TFSI... personally I would stroke the 20v and whack a GT3071 on it... but if you want a TFSI engine tbh you may as well just buy the whole car as its arguably a better all round package... and thats from someone who loves his 8L ;P
  13. Barks
    Barks Member
    337
    Hello Andrew,
    Looking at the circuit diagram, pin 63 on the ecu is a wire to the lamba after the cat, or is this wired else where on a narrow band??
    Barks
  14. Andrew@A.L.D
    3,873
    609
    I think its something else on the narrow band
    can you post the circuit diagram
  15. Barks
    Barks Member
    337
    Pm'd
  16. Andrew@A.L.D
    3,873
    609
    More bad news
    The engine seams to be leaking oil into cylinders 2 & 3?
    Rings were changed in jan from bore wash, valve steam oil seals done at the same time?
    It did make 440bhp but at 1.9 bar which isn't that good because of the oil leak
  17. Prawn
    11,413
    3,302
    Argh. nothing but bad news for you it seems Andrew! did the pulley issue get sorted before this oil leak happened?
    Oil in the cylinders will be absolutely killing the mixture, so power figures are a bit meaningless :(
  18. badger5
    9,400
    1,944
    oh dear
    what head gasket did you use for the 2.1?
    83mm bore?
    unlucky dude
  19. <tuffty/>
    20,896
    3,705
    Had a similar issue with Welly's at one point... the seals appeared to have lifted themselves up... maybe I didn't push them home as well as I thought when rebuilding it but it smoked like a good un for a bit... think it was the exhaust seals though...
  20. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Not good news Andrew, are you leaving it with them? anything to do with the total seal rings? i am booked in tomoz but if yours is still with them i might have to postpone?
  21. Andrew@A.L.D
    3,873
    609
    Bill.. Used the head gasket you recommended
    Tuffty.. It could be the seals we don't know?
    Dave... Not sure if it is the total seal rings?
  22. <tuffty/>
    20,896
    3,705
    You are using ARP head bolts? have you re-tourqued them after running the engine in?
  23. Andrew@A.L.D
    3,873
    609
    i am and i did but not sure i did them too soon now?
  24. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    473
    Sorry to hear this mate :(
    Sure you'll be able to sort it all out and have her fighting fit in no time :)
    Don't mean to sound stupid but is there a way of telling how much oil is getting into the cylinders besides the obvious sniff of exhaust fumes and seeing the smoke?
  25. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    Any of you willing to elaborate on how much cash pound notes you've sunk into these s3 to get 500+ bhp out of them? Oh and don't worry , I won't tell your partners!
    Cheers, sean
  26. superkarl
    superkarl MAN OF STEEL
    9,404
    2,378
    just google the specs of andrews in his sig. you'l soon stop counting lol
  27. <tuffty/>
    20,896
    3,705
    I did a long time ago... lol
  28. badger5
    9,400
    1,944
    Same head gasket is on mine......
    I've not heard good things about total seal rings personally... Ran them years ago in a valver.. they wore out very quickly.
    Whats next then? Head off (again) and rummage around inside to try and see the cause?
    gutting... :(
