my last question regarding my maf sensor
4rings Apr 12, 2011
  1. 4rings
    4rings Member
    94
    ok asked a few questions about this and got good feedback. so thank you :)
    my last question is this. and ill problaby sound like a tit for asking but there you go.
    i am going to by the correct cleaning spray and remove the maf sensor and try cleaning it up. as the chap at amd said it was only runing about 85%
    SO. i do the claning then take it for a drive e.t.c but how will i actually no if cleaning it has done the trick??
    i would of course take it back to amd but its a good 100 mile drive and i dont want to go all that way just to be tested for that. i no he took the car out after it was remaped and plugged his laptop in. but thats all i no. is this something that can be tested at audi?? (i do have a good freind who works for vw so i can get it "plugged in" for free
    thanks rob.b
  2. aragorn
    18,025
    718
    You can test it with Vagcom, which you presumably dont have, but perhaps if you post your location someone nearby from the forum might have it and can do some logs.
  3. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    ur vw mate can plug it in for you
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    How can it be functioning 85%? lol. It's a bit of a wild estimate that - you would have to know what the output of a working MAF on that engine would be to work it out.
    You will need to log it, not just plug it in. Check the VCDS users map in the sticky and see if you can find a local ASNer who has VCDS.
  5. aragorn
    18,025
    718
    i took it to mean that at full power its showing about 85% of the airflow that it should be.
  6. 4rings
    4rings Member
    94
    well im just going by what the chap at amd said really. thanks for the help ppl :) xx
