My Gauge shows -5 vac at idle
Kodak Mar 31, 2013
  1. Kodak
    Kodak Member
    65
    My Gauge shows -5 vac at idle it used to show -14 i found a small leak in the gauge hose and replaced it and now it read -5 at idle?
  2. jay1601
    jay1601 Well-Known Member
    1,317
    57
    either a incorrect gauge or vac leak somewhere.
    mine sits at -20
  3. Kodak
    Kodak Member
    65
    thought as much well best get to it any suggestions where to look first. and how the hell are you getting 34.2mpg lol im lucky if I get 22
  4. jay1601
    1,317
    57
    not always driving on boost lol.
    average mpg 34.2
    last mpg 29.2
    best mpg 40.2
  5. Kodak
    Kodak Member
    65
    well I found a leak on the connection to the gauge and fixed that now im reading -15 does this mean I have another leak?
  6. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I think mine reads about -15 and I don't have a leak.
  7. Kodak
    Kodak Member
    65
    holy sh1t I just found another connecting to the brake servo and found an article on about it on tyresmoke aparnetly its only common with APY blocks Audi S3 8L 210 APY Brake Vacuum Hose repair not sure if its ok to link to another forum if not ill remove it Regards
  8. Westy
    Westy Well-Known Member
    17,443
    1,103
    Mine is around -14 and no leaks.
  9. Tim_Attard
    Tim_Attard Active Member
    473
    44
    mine is about -0.7/-0.8 bar so thats about 10-11 psi should i check for a leak? or would it just be the guage isnt that accurate (got a cheapy)
  10. Yohan87
    Yohan87 Guest
    Mine shows -20 (no leaks) and if I'm driving then let it coast it shows about -22/-23. Newsouth gauge if that makes any difference.
  11. Kodak
    Kodak Member
    65
    I haven't replaced the brake servo vacuum line yet but im getting -15 and like you say about coasting I was getting -23-25
  12. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    If mine doesn't sit at -20 in hg i know i have a leak..
    phil miller likes this.
  13. Kodak
    Kodak Member
    65
    hi now its not dumping boost why!? its one thing after the next i did notice that it had an aftermarket DV its a Forge Split R any ideas before i get someone to go in to the back of me and write it off "kidding"
  14. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    Mine sits at -25
  15. Yohan87
    Yohan87 Guest
    Get rid of the Split-R valve, it's pretty much an expensive boost leak.
  16. Tim_Attard
    473
    44
    hi id fit an orginal dv to see if it cures it HOWEVER saying this i have a split r and just measured my vac with torque and getting between 22-26
  17. Kodak
    Kodak Member
    65
    so go for OE original dump valve? actually I think ill fix the brake servo vacuum line first to see if that sorts the vac problem maybe not enough vac to operarate the dv
  18. Kodak
    Kodak Member
    65
    Update ive been to Audi and ordered the parts i wouldnt care but after paying for them and driving a mile up the road and popping in Aldi for some milk and veg it was dumping again.. ??!??
  19. Kodak
    Kodak Member
    65
    changed the brake vacuum pipe that runs of the inlet mainfold to the brake servo and it still says -14 but on the plus my brakes are better.
  20. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Ron's sits at 22 inhg at idle, if i coast/or on over run it goes to around 28inhg, no leaks here :) (there better not be any lol)
  21. Kodak
    Kodak Member
    65
    right i changed the forge split r dump valve and put a standard one in and now! i get -21 vac at idle :) so problem sorted thanks all
  22. phil miller
    1,211
    166
    update now mine is at 25inhg, so im sure i dont have a leak now :)
  23. scotty_24
    scotty_24 Well-Known Member
    1,023
    241
    I'm at -7 bar at idle is this ok?
  24. darren t
    darren t Member
    568
    I have noticed a change in my vacume response ie when you dip clutch how quickly does your idle vacume change mine takes a while too settle if you understand ie it used too go straight up too-0.7 now it struggles any ideas throttle body cleaned??
    no leaks ect.....
  25. Kodak
    Kodak Member
    65
    hmm ive not had that problem it returns very fast i do however have a problem of over revving when i dip the clutch sometimes anyone seen this its a APY block
    also like to add that is mine is sitting at -24 now since i deleted one of the bends in the vacuum lines so very happy now.
