- Joined
- Jan 30, 2008
- Messages
- 18,708
- Reaction score
- 909
- Points
- 113
- Location
- Glenrothes, Fife, Scotland
Storming through it Did you sort out the alternator and starter wiring?
Not fully. The AWT loom has a plug that goes straight into the back of the alternator, which is neat and tidy, and explains my puzzlement as to why the AWT start/charge loom didnt have an alternator connector. So the alternator is plugged in and ready to go.
For the starter, i couldnt be ***** trying to get at the starter itself for the solenoid cable, so i cut the wire off the old loom down the back of the engine (and i actually forgot about that last night, hence why it wasnt mentioned, and why i havent sorted that already!). I've got a wire tail from the scrappy with the plug that matches the connector on the AWT loom, so i will crimp or solder that onto the existing wire, and then it'll plug in. Ideal situation would be to get the starter harness from an 06B car (either 1.8T AWT, or 2.0 passat etc) and it'd all just plug in, but i didnt know that at the time! If the turbos ever off i might revisit it and swap the starter to alternator loom out for the proper one, but this way should work just fine.
