my first log
Bradderz_1988 Aug 4, 2011
  1. Bradderz_1988
    3,945
    235
    so ive actually done it but it came up with a message with 'obd something baud' along them lines and crashed so didnt really do a full log as such heres wot i got.
    one thing i no is there is a leak on the decat where it bolts to the the turbo at the stud under the manifold (before lambda) about 5mm gap any one see any thing out of the ordinary ?? (aragorn lol)
  2. jamie226bhp
    jamie226bhp Member
    468
    Do you need genuine Ross tec to log or will eBay leads do
  3. Bradderz_1988
    3,945
    235
    eBay one I got one that was uk dispatched for £8.30
  4. aragorn
    18,019
    716
    Log doesnt really show much unfortuantely.
    You ideally need to start at Low RPM in third gear and do a pull thru the revs at full throttle. You can use second if the roads by you arent good for doing dodgy speeds on though.
    looking at the log you only went full throttle right at the end, your peak of 135g/sec indicates 170hp but its not really enough data.
  5. Bradderz_1988
    3,945
    235
    That was full throttle from second to third you can see were I let off at the last time stamp As it crashed and I had to slow down as I came upto a roundabout I will do another one tomorrow on my way home from work so would you say 20-30mph engage 3rd and pull all the way up to the limiter ??
  6. Jason.s
    Jason.s Active Member
    2,879
    348
    Keep it in gear and then pull. Dont change gear whilst logging would be best.
  7. aragorn
    18,019
    716
    I just used 2nd the last few times as while there are a few 60 limits round here its a fair drive before i could get to a road i'd be happy doing a full third gear pull on.
    I usually start at 1500-2000rpm and go full throttle thru the revs to 6.5k or so.
