My First Audi, my first VAGCOM scan, thoughts
madmax2 Aug 24, 2011
  1. madmax2
    madmax2 New Member
    10
    Hi guys, quick intro
    defected from bmw to audi (long time bmw owner), managed to pick up a fairly nice B5 S4 2000 facelift but with old style badges, black outside /silver leather/carbon fibre combo in March and been loving it ever since. Been lurking and reading up on B5's since then and comparing notes...
    Bought privately with two faults
    1) airbag light on
    2) oil pressure/temp sensor not working
    3) (minor, DIS lines...hehe)
    Scanned with VAGCOM today:
    Please check my comments in bold to see if I am on the right path here..
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01: Engine
    Controller: 8D0 907 551 D
    Component: 2.7l V6/5VT 0002
    Coding: 05711
    Shop #: WSC 00209
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8D0 907 389 E
    Component: ABS/ESP allrad D36
    Coding: 04395
    Shop #: WSC 06435
    Address 08: Auto HVAC
    Controller: 8D0 820 043 M
    Component: A4 KLIMAAUTOMAT D57
    Coding: 00061
    Shop #: WSC 06325
    Address 15: Airbags
    Controller: 8D0 959 655 J
    Component: Airbag Front+Seite 1001
    Coding: 01104
    Shop #: WSC 06325
    1 Fault Found:
    01217 - Side Airbag Igniter: Driver Side (N199)
    32-00 - Resistance too High
    CONNECTOR UNDER DRIVER SEAT/DRIVER FOOTWELL?
    Address 17: Instruments
    Controller: 8D0 920 980 BX
    Component: B5-KOMBIINSTR. VDO D07
    Coding: 00464
    Shop #: WSC 00209
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1173469
    2 Faults Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    30-00 - Open or Short to B+
    29-10 - Short to Ground - Intermittent
    SENSOR BY SUMP - MAKE SURE TO GET THE CORRECT ONE?
    Address 25: Immobilizer
    Controller: Bit teA dre ss
    Component: e 17 eingeben
    No Faults Found
    or DTCs not supported by controller
    or a communication error ocurred
    Address 35: Centr. Locks
    Controller: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D13
    Coding: 13130
    Shop #: WSC 00209
    6 Faults Found:
    00991 - Interior Lights
    28-00 - Short to B+
    NO IDEA, INT. LIGHTS SEEM FINE
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    PREVIOUS OWNER ********?
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    77-00 - Internal Supply Voltage
    49-00 - No Communications
    ALARM UNIT IN RHS OF BOOT, FLAT BATTERY
    Address 45: Inter. Monitor
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 00056
    Address 55: Xenon Range
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D003
    Coding: 00012
    Shop #: WSC 06325
    Address 56: Radio
    Controller: 4B0 035 186 E
    Component: Radio 0001
    Coding: 00205
    Shop #: WSC 06325
    End --------------------------------------------------------------------------------------------------
    BTW, I am in Ilford, Essex if someone needs something scanned :)
  2. Bradderz_1988
    3,958
    240
    Airbag ones under seat just Disconnect with ignition of leave for 5 mins or so then reconnect should be ok clear the code before doing this and it should knock the light off.
  3. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,722
    162
    Bear in mind that some of those codes could be years old. All depends on when the car was last scanned and the had the codes cleared. Best thing is to clear the codes and rescan in a week or so after the car has been driven.
    Obviously, the air bag light on the dash and oil sensor is a current DTC. But the others could be old.
  4. madmax2
    madmax2 New Member
    10
    thanks for the info guys,
    I cleared all codes yesterday, fixed the connector under the seat for Airbag light problem, went for my usual drives to and from work this today, rescanned
    these are the only ones that remain
    Coding: 00464
    Shop #: WSC 00209
    1 Fault Found:
    Coding: 13130
    Shop #: WSC 00209
    1 Fault Found:
    I've heard/read or the oil temp/press. sensor you have to get the correct one, it would be great if someone can confirm this either way.
    By correct, I mean, not one form eurocarparts as apparently it wont work even though it is listed as correct...or rather, it works for some year models.
    mine is a 2000 January and from VAGCOM deciphering the ECU is a d-box type.
    Last question, how would I be able to tell if it has the original map or has been reflashed already? only on dyno?
