They are a coded countdown sequence for an advanced anti theft thermonuclear device.
Once activated you need to start the car using the key within 10 seconds of the OK symbol or bad huge bangy type things will happen.
Either that or you have pressed the check button on the dash and I am reading the wrong manual.
Don't forget the initial screen; it may be hard to read the picture, but it is warning you against listening to Capital Radio.
It may be injurious to your health!
One final thing; your car may work better if it is on its wheels, and not on the passenger door!
Goes through a sequence of checks when check buttons pressed. Yours is saying ok at the end so no probs. if it finds a problem with any of the symbols shown it will beep and that symbol will remain on screen
