My expectation too high?
I oOEddOo I Jun 12, 2013
  1. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Hi folks
    Had revo install today on my S3
    As I put my foot down I dont feel that pull like my previous audi a3 which is 2.0T front wheel drive
    I have three things in mind
    -Do i need to let it settle for couple of days before i notice anything
    -Due to the weight of the S3 it does pull little bit better than stock
    -Am I expecting too much from stage 1?
    Thank you
  2. NHN
    29,510
    1,764
    Maybe it was already mapped :p
    Should be obviously noticeable tbh.
  3. I oOEddOo I
    I oOEddOo I Member
    340
    15
    but it doesnt throw me back to the seat when I put my foot down :shrug:
  4. sliced
    sliced Drive safe, stay alive.
    1,568
    335
    check out the thread about the Diverter valves
  5. I oOEddOo I
    I oOEddOo I Member
    340
    15
    I have asked to garage guy he said it doesn't need to be change
  6. S3Alex
    10,826
    4,820
    Don't forget....it's no lightweight at 1500kgs,and the power/weight ratio at Stg1 is about 200bhp/tonne.
    It will be brisk,but not scary.
    Also,the ECU will adapt for a period of time following the remap,and there may also be parameters like boost which need tailoring to your own preferences,but for it to feel fast,you may need more power.
  7. bmh.01
    bmh.01 Member
    291
    17
    I found stage 1 wasn't had i'd had in previous cars ass dyno wise, but it definetly is quicker by stopwatch.
  8. sliced
    1,568
    335
    HI mate, you could get it dyno'ed and see what power its laying down. If its quite far of what it should be doing then you could investigate
    I oOEddOo I likes this.
  9. I oOEddOo I
    I oOEddOo I Member
    340
    15
    The mechanics got me excited saying u should feel it straight away:eyebrows:
    Yes I guess my old A3 is lighter and only a front wheel drive so it feels very quick and throw me back to the seat
    I see in these couple of days let the ECU settle first
  10. Minstadave
    Minstadave Member
    560
    19
    I'd definitely want the DV checked. Did your mechanic actually inspect the membrane?
    Sounds like you need to get it on a rolling road and see what's going on.
  11. S3Alex
    10,826
    4,820
    I would go with that.
    As was said above,the real proof is against the clock,and the S3 can be deceptively fast,without ever feeling neck-snappingly fast.
    I certainly felt Stg1 was worthwhile,and made the car much more usable overall,with a good deal more torque,and after a couple of days,you may well notice that,compared to what it was like before.....try it at around 3500-4000rpm and see how it pulls.
    Also,different maps may be set up differently,and will therefore feel very different in use,although it is true that an aggressive map may actually not be as quick as a more linear one.
  12. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Yh will do pal cheers
  13. TDI140
    TDI140 Well-Known Member
    1,632
    174
    This is the reason i say go to reputable tuners and tuners that have dyno's for before and after printouts, for all you know hes given you a 10bhp increase that you cant even notice
  14. phil76
    phil76 Active Member
    572
    40
    Dyno'd you should be hoping to see 290-310 bhp depending on the dyno,like people say let it adapt,use good fuel v-power etc if you dont already,intake always good for helping them rev out through the gears,maybe stick a set of nology plugs in it,they arent necking snappingly fast stage1 or really any but the pull through 3rd and 4th should have you a bit more excited than you sound,i would also say check the DV for the sake of it
  15. TDI140
    1,632
    174
    Your dyno result should be 305-310bhp on a decent stage 1 map, the s3's produce alot of power
  16. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    You should notice a big difference between stock and Stage 1.
    What are your REVO settings?
    If they are set too conservative then that could be the issue.
    NHN likes this.
  17. gilberto
    gilberto Member
    156
    I had the same thoughts when i went to Revo Stage 1, give it a few days, the S3's a really smooth car but decepively quick.
  18. I oOEddOo I
    I oOEddOo I Member
    340
    15
    I am on revo stage 1 too hopefully the ECU adapting soon
  19. S3Alex
    10,826
    4,820
    Mine made around 310 bhp on Stg1,but as I said,it doesn't feel neck-snappingly fast,but is a lot more usable than stock.
    More torque,a bit more bhp,and better to drive....don't expect miracles from Stg1,it's more of the start of the slippery slope to more power!
  20. NHN
    29,510
    1,764
    How can you say that when it got you addicted in the 1st place :p
  21. S3Alex
    10,826
    4,820
    LOL...and like I said....it's the start of the slippery slope.
    It just made me think this car cries out for more power,and then more,and then some more after that!
    NHN likes this.
  22. NHN
    29,510
    1,764
    and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more
    Ooops sorry my S3Alex special keyboard got stuck lmao
    S3Alex likes this.
