my esp light wont turn off
s3gazz Jan 4, 2011
  1. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    hi does anyone no how i can get my esp to turn off its been on for a week now and wont turn off checked fuses thats about it tar for any help
    gaz
  2. alijames
    alijames Active Member
    1,024
    Get it scanned for faults. Could be one of many sensors faulty.
    Cheers,
  3. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    1. Steering angle sensor
    2. Lateral Acceleration Sensor
    3. Longitudinal Acceleration sensor
    Its one of them! Expensive fix :(
  4. Carpy25
    Carpy25 Member
    279
    mine was the steer angle sensor , sometimes called the clock spring not cheap £200 plus vat from audi and you need vagcom to set it up hope your luck is better than mine
    Rob
  5. s3gazz
    1,376
    99
    checked it on vag com nothing like that came up just brake light switch , purge valve , 4 lambda sensor faults thanks for help
  6. s3gazz
    1,376
    99
    great not looking forward to this buy hopefully not any of them ha
  7. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    what system did you scan and what did you scan with as it looks like you just scanned the engine side?
  8. thegoal007
    thegoal007 Another S3 owner....
    804
    26
    Isn't the the esp ultimately activated by the haldex ? If that is the case then the brake light switch is the only thing in your list of vagcom errors that sends a signal to the haldex, so it may be that.....possibly.
    Indeed the other items listed by the others do also feed into the haldex too, but as you have not got any of those errors on vagcom then hopefully it is unlikely to be them. The bad news is this is not always the case especially if one of those sensors is sending the wrong signals, but does not think there is a fault or if there is a transient electrical problem which would not show up on vagcom.
    I would start with the brake switch - simples.
  9. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    sure it isnt the actual button/switch on ur centre console
  10. s3gazz
    1,376
    99
    just scanned the engine and haldex side of this mate
  11. s3gazz
    1,376
    99
    i dont think so pressed it so many time ill take it out tomoz and have a look
  12. gavin89
    214
    Erm thats not the right group for ESP! :blink:
    You need to scan Group 3 (ABS Brakes), then post the faults...
  13. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    its not on there,do abs mate.
  14. s3gazz
    1,376
    99
    hi mate i had it on vag com again and these came up will they have owt to do with it got these faults 2
    01314 engine control module
    18057 powertrain data bus missing message from abs controller
  15. s3gazz
    1,376
    99
    done abs come up with these mate
  16. superkarl
    superkarl MAN OF STEEL
    9,430
    2,399
    Abs controller is under the airbox and battery, that area. Check all wiring and plugs to and from that and the ecu.
  17. s3gazz
    1,376
    99
    ye will do mate
    can u help on the othe one by any chance tar
  18. superkarl
    9,430
    2,399
    ECM is the ecu I think. I would just check all electronics, plugs and wires. Corrosion and dirt can play havoc, I have similar problems and need to check abs module wires like you. I have intermittent no communications between the two
  19. s3gazz
    1,376
    99
    i no they just do my head in ill check all i can find and see mate willany of the other faults courz it if ya look at my other thead abit more down page
    starting with changed my lambda sensor cheers for any help mate
  20. superkarl
    9,430
    2,399
    You've got alot the same as me.
    New egt sensor isn't cheap as I've recently learned. If your wantin to pass an mot you need that and your lambdas sortin, make sure you replace right one though there is 2 if you have a facelift car.
  21. s3gazz
    1,376
    99
    whats the etg mate and where is it tar
    iv learnt there are 2 lol changed the wrong one yesterday how much are the other ones mate
  22. superkarl
    9,430
    2,399
    Egt is plugged into the turbo housing.
    2nd lambda is on the downpipe right at the top.
    Tufty said the egt is around 180 quid. Not sure on lambda probes
  23. s3gazz
    1,376
    99
    ryt sound mate can u get to it from top of engine
    take it that lambda will be same price as well then cheers
  24. <tuffty/>
    21,016
    3,780
    If you mean is it the same price as the post CAT one then that depends if its wideband or not... if your S3 is AMK or BAM engine code then its a widebande lambda on top and are £80 and upwards depending where you get one from... GSF sell Bosch sensors and you should only get a Bosch one especially if its a wideband one... dealer prices are around £120 IIRC...
    Only difference between the GSF version and the OEM version is the GSF version has a longer cable (more generic fitment) and doesn't have the heat shroud for the lead... I used a GSF one and cut the heat shroud off the old one and wire wrapped it to the new one..
  25. s3gazz
    1,376
    99
    thanks tuffty great help ill be going gfs tomoz then for it how hard are they to fit mate and im getting it de cated wed so hopfully will run ok
    in need or brake light switch as well cos im getting fault from that even tho brake lights are working
    cheers
  26. lee111s
    lee111s Member
    54
    Mine was an ABS sensor
  27. s3gazz
    1,376
    99
    how much was that mate if ya dont mind me asking tar
  28. s3gazz
    1,376
    99
    how do i get my traction control light to turn off can anyone help tar
  29. lee111s
    lee111s Member
    54
    The part was about 50 quid I think. It also stopped my quattro from working so get it sorted ASAP
  30. s3gazz
    1,376
    99
    cheers where from mate and wont the traction control light go out when change brake
    switch as i been told they have the sensors for that in them
  31. lee111s
    lee111s Member
    54
    There are many sensors that provide the same issue in terms of the ESP light not going out. In my case it wasn't on when I started the car and only illuminated once I went above 20km/h, if I drove below this speed the ESP light stayed unlit.
  32. s3gazz
    1,376
    99
    mine constentlly mate
  33. lee111s
    lee111s Member
    54
    Take it to an audi specialist and have them check it out. Where are you based?
  34. s3gazz
    1,376
    99
    in bradford mate
    got a vag com mechine to use so no point going to audi realy
