My engine knocking :( tdi a4 tdi Quattro
Hasan1 Sep 24, 2013
  1. Hasan1
    Hasan1 Member
    32
    I start the car and the engine was knocking like mad but I was about to service my car. The milage is 172 it seem missin firing or cud it be injector help
  2. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    2.5TDi?
    Its hard to tell what it is without hearing / seeing the engine - where are you located?
    I don't mean to frighten you / jump to conclusions, but a common issue with these engines is camshaft wear on engines with high mileage on the long life service intervals.
    A good place to start would be to open your oil filler cap and shine a torch in, there will be a camshaft lobe visible, see if it has any wear.
    If it does it will look like this;
    http://2.bp.blogspot.com/_zYJ4700BbOU/TEYhqrM7wbI/AAAAAAAACZs/5jZ5aQEc57c/s1600/IMG_3379.JPG
  3. Hasan1
    Hasan1 Member
    32
    It's a 2.5 tdi Quattro I'm based in sheffield and I can't see much any more advise it can't be injectors it could be cam shaft but before I park it up it was fine soon as I start it so I could service it making a noise
  4. AlexGSi2000
    1,464
    199
    If you were closer I would have taken a look.
    Does it knock constantly, or just the first few seconds after starting?
  5. Hasan1
    Hasan1 Member
    32
    Would it make any different if u herd it threw the fone it's constantly
  6. AlexGSi2000
    1,464
    199
  7. Hasan1
    Hasan1 Member
    32
    Cheers pal it's knocking constantly I wish never got it becous I just just got it the other day would it be better if u herd it threw the fone
  8. Hasan1
    Hasan1 Member
    32
    Omg that the same noise would it cost alot to fit I'm guessing it not driveable hey
