my DTM 'build' - story so far, hybrid K04 - custom FMIC
olethalb Nov 16, 2012
  1. olethalb
    olethalb Active Member
    357
    76
    right....
    now i had the clutch and knee is a little better (not much) i decided i'd start the swap
    i've had the new engine for a while and other parts were slowly coming together
    well first (easy part) was to strip out the old engine
    little clean up
  2. olethalb
    357
    76
    now i had the lump out i could start building up the new one
    90% of ancillaries are different from tranverse to in line
    swapped;
    alternator bracket
    alternator
    p/s pump
    a/c pump
    all water ways and hoses
    sump
    cambelt cover
    cam cover
    also A4 mounts bolted up
    the A4 uses a spigot bearing in the end of the crank so fitted one of them
    fitted new clutch and fly
    the dowels were longer on the A4 too so they had to be swapped out
    the hybrid strapped on with proper k04 lines
    new plastic water way as the original broke up on removal
    now it was al fitted up with s3 injectors, new inlet mani, painted TB, new pump with original auto tech internals i wiped it over and
    sat it back in the bay
  3. olethalb
    357
    76
    few other bits needed attending to while i was at it
    the decat pipe i got from the states pushed the lambda up against the heatshield, so i welded a new boss in
    and heat wrapped it
    new position, you can see issue where the blank is
    also got another fmic core to modify to fit
    new pipes made to be welded
    new custom crash bar mocking up with 30mm 3mm wall tube
  4. olethalb
    357
    76
    i also wanted to smarten things up, i never painted the lower boost hose and the throttle body one had been sanded for WMI injector and chipped. was also not happy with the cam cover
    so i braved the VHT wrinkle finish and set to work
    lower boost pipe
    tb boost pipe
    turbo intake pipe
    fitted the TB boost pipe and DV etc
    popped off the old cam cover and looks like new :)
    fitted the new cam cover
    unfortunately thats as far as i've got it's been raining heavy all day, i'm going to run the old FMIC while the new one is welded and i
    can properly fit and paint the crash bar
    also got this to modify on somehow, it's from a mondeo to replace my existing p/s cooler
  5. jetskijimmy
    jetskijimmy QUATTRO
    77
    Hi olethalb
    Ive got the same sprint blue DTM :beerchug:I want to upgrade to s4 discs 345mm what will I need to adapt this Mod ive seen something before about changing the caliper bracket
  6. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    Nice work ,if you get bored when yours is finished i'll leave mine with you for a month .lol.
  7. ANDYTQ
    1,184
    105
    Which flywheel did you get ? ,steel single mass or alloy with steel insert?,this is my next job,i was thinking of getting a clutch off drake on audizine he does modified rs4 clutch kit,i'm just not sure which flywheel.I need to get them ordered as mine is getting a bit worn.cheers Andy
  8. Golfedd
    Golfedd Active Member
    144
    35
    Nicely done Olly, that VHT stuff gave a good finish! mmmm the painful memories of wrinkle haha.
    Looks good!
  9. Golfedd
    144
    35
    imagine, how epic it would be... to have like, some kind of RS4 style start button, that would flip up in the cigarette lighter?
    #BITTER!
  10. olethalb
    357
    76
    cheers chaps, will reply when i get a little more timewell the engine was fitted idled perfectly, took it out for a spin and got a misfire on boost on cylinder 3 swapped loads of parts including 4 new gen plugs and coilpacks.
    yesterday i took out the injectors (PITA job) and swapped cylinder 3 injector to #4, took it out and misfire on #4 so seems one of my 3k old S3 injectors are dead, looked it up on ETKA and they're £150 each. also been getting 'low fuel pressure' code so looks like intank pump is dying - another £300 :( - ah well pics of the progress anyway
    fitted pics and painted parts
    James.c likes this.
  11. olethalb
    357
    76
    next i plucked up the courage to hack two grils apart to make one...
    removed the frame and trimmed the edges off the RS6 grill
    http://i276.photobucket.com/albums/kk32/ollethalb/dtm/CFC79E6C-8FD6-48B4-B0C9-400E0A43C2D7-957-
    stock SE grill
    frame removed and measured up against the RS6 item
    i decided i'd trim the outer edge off of the SE grill as i did with the RS6 grill and glue them together as the witdth and angles were pretty close
    once i'd trimmed the RS6 to size i secured it with cable ties then glued it
    after leaving it to set for a week with the cable ties holding it in position i removed the ties and painted the surround wrinkle black
    also did this, not sure if i like it yet will need to use it some more
    also ordered a lot of bolts / clips and a new drivers vent, i'd noticed a few rusty looking bolts mainly on the front panel and a few damaged plastic loom clips when i swapped out the engine
  12. N8
    17,163
    718
    Saw the pics of FB earlier Oli, love your work, looking forward to seeing it in the flesh, and you of course :wub:
  13. S3 Rav
    S3 Rav Well-Known Member
    2,824
    30
    Looks great.
  14. harvey01
    harvey01 Member
    523
    9
    hi mate looks good did you bake it all to get the wrinkle
  15. olethalb
    357
    76
    Nate - thanks bud, DC was last time i saw you. i was with Dele and the hamster :D
    Rav thanks
    harvey - no i just heated it up carefully though as it's mainly plastic
    yesterday i went and picked up a new injector and RS4 in tank pump, unfortunately the fuel filter was out of stock
    took out the old pump and the gauze was floating around in the bottom of the tank
    http://i276.photobucket.com/albums/kk32/ollethalb/dtm/FC063C54-C902-4325-9F97-02FA9839402D-6967-
    while i was at it i dropped the tank to fit the RS4 pump controller
    and removed the old one
    http://i276.photobucket.com/albums/kk32/ollethalb/dtm/7EF24F53-E34F-4121-A2AC-6121A957AA01-6967-
    got a call from audi to say my filter and new brake light switch were in stock, while i was collecting them the welder called to say the FMIC was ready for collection
    mounting brackets fabricated
  16. Golfedd
    144
    35
    not seen the detail on that new IC - looks good man! looking forward to this being on the road, ripping up the road.
  17. olethalb
    357
    76
    me too Eddwin
    well thought i'd set about getting this front end sorted today
    dropped the bumper off
    removed the old fmic and started mocking up the new crash bar
    welded 16mm thick wall tube to the crash bar mounting points
    test fitted the bar
    then offered up the FMIC - unfortunately there had been a miscommunication in measurements so i had to mod the pipes
    then trimmed the mounting brackets, added some rivnuts to the bar and bolted it up
    once that was in place i needed to mount the horns so i welded the brackets to the crash bar mount
    popped some paint on
    fitted the 'new' grill in the bumper
    and test fitted the bumper
    that was it for now 'crash bar' has been painted but need to get the pipes rewelded and my welder is away this weekend :(
  18. weekenny
    weekenny Active Member
    139
    51
    Looks great, what was the original front mount from?
  19. AudiB7Jay
    AudiB7Jay Active Member Audi A4 S-line owners group Team Aruba Blue TDi saloon Manual
    448
    26
  20. olethalb
    357
    76
    weekenny - the one i removed or the new one?
    Jay - i'm happy with the wa mine's turned out
    magic happend today, i called my welder, not only did he answer the phone on his day off he agreed to run a couple of welds for me :)
    got to work and dropped some paint on the cooler pipes, as soon as was touch dry set about fitting it up with the painted crashbar
    next i had to address the power steering cooler - not many pics as it was snowing on and off so no time for pics. mounted the
    mondeo cooler
    with bumper fitted
    all back together
  21. weekenny
    139
    51
    The one you removed. Cheers.
  22. olethalb
    357
    76
    it was from a B6 1.8T kit, i only needed the core so ditched the pipes and welded my own ally pipes on to give clearance for the bumper
  23. weekenny
    139
    51
    Cheers looked great.
  24. olethalb
    357
    76
    will be on ebay this week :)
    gave it a wash
  25. DTM_T4
    DTM_T4 New Member
    29
    On eBay? You selling up dude?
  26. Steve220
    Steve220 Member
    234
    15
    Is that a 2" core? Bit thin for your turbo spec isn't it?!
  27. olethalb
    357
    76
    the old FMIC will be on ebay bud :)
    ran some logs earlier to measure intake temps and normal driving was around 22* with ambient of 9.5* and spirited driving with WMI was seeing as low as 2* so seems to be performing well, no noticeable lag over old item :)
  28. Golfedd
    144
    35
    Took a trip over to see the scruffy DTM. It was in much need of a day's worth of Detailing up, paint was faded and dull and the sprint blue certainly can shine.
    With the up coming show at Elemental it was time to sort it out...
    Products:
    Two Bucket wash: Fairy liquid
    Cleaned off: Tardis all round
    Clayed with: Elite Fine Grade
    Rinse and Dry
    Taped up and prep for rotary
    Stage 1 all over: Lake Country Pads - S3 Gold class
    Stage 2 on some areas: Lack country Pads - S17
    Stage 3 all over: Lake country finish pad - S40
    Rinsed down and gentle dry
    Dodo Juice Acrylic Spritz sealant
    Dodo Juice and Smartwax finish
    The Photos
    General dull paint
    Ready to go
    Driver door comparison
    Rear Quarter comparison
    Mirror- light buff as it's a soft clear coat on these
    had to be a bit gentle around the arches, they are a tad - frail
    Bonnet after stage 2 pass
    Boot done final stage (no protection)
    Exhaust tips got a quick whip over
    Finished up
  29. olethalb
    357
    76
    Oh Edd she's so shiny and clean :)
    thanks bud, was good to catch up with you and the lads saturday
  30. mancdan
    mancdan Active Member
    491
    50
    Fairy Liquid, is that not the devil for detailing cars.
  31. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    391
    Should never use fairy washing up liquid anywhere near quality paintwork, It's full of salt and will ruin a good shine.
  32. Golfedd
    144
    35
    haha yup, you're both right. I didn't use Fairy - Used meguiars Gold wash, then a rinse down with Auto-Glym Shampoo etc etc etc
  33. mancdan
    491
    50
    Phew, thats good then :arco:
  34. olethalb
    357
    76
    James.c likes this.
  35. craichouse
    craichouse Member
    99
    10
    there is 2 new pic's for my desktop wallpaper :respekt:
    there my only be 213 of them left but this surely is the best one of them all, :applaus:
  36. olethalb
    357
    76
    Wow, thanks for compliment bud
    spent the day at MRC today and i got a good service and a fair amount of tweaking
    James.c likes this.
  37. craichouse
    craichouse Member
    99
    10
    does that say 363 BHp?
  38. Chris-Vspec
    Chris-Vspec Member
    248
    43
    Amazing build, just been engrossed in it for an hour reading every post, what an amazing car also thanks for all the useful information in your thread.
  39. olethalb
    357
    76
    craic - indeed it does, was hoping for more to be honest
    Chris - thanks for taking the time to read :)
    didn't do much at the weekend but it was nice weather so could take my time on the long over due rear brakes
    when i bought the car it had just had new rear pads so plan was to get a bit of like out of them before doing anything with them, recently been getting a very annoying brake squeal so enough was enough.
    i bought a pair of drilled and grooved discs to match the front, rears on DTM are 288mm but unfortunately solid
    anyway, a pic of the nasty nasty rear set up
    after a good clean up, regrease, blue paint, new discs, mintex pads and repainted splash shield
    hoping this is going to be new turbo week :)
    James.c likes this.
  40. DOHxP
    DOHxP New Member
    20
    alot of good work going on here
    but out of curiosity, why didnt you just go ahead and buy yourself an rs4 for the money you spent on this?
