my DTM 'build' - story so far, hybrid K04 - custom FMIC
olethalb Nov 16, 2012
  1. rezulteo
    rezulteo Site Sponsor Site Sponsor
    233
    15
    Really nice car and in great condition too
  2. Golfedd
    Golfedd Active Member
    144
    35
    Digging out the Rotary today man, see what bits I need and then we'll get yours in and shine her up!.. Going to attack mine today / weekend and reduce the swirl-tacular body. Like old times with new toys :sex:
  3. olethalb
    olethalb Active Member
    357
    77
    thanks chaps
    well got my RS4 fuel pressure regulator and 'K' revision fuel pressure sensor / thrust sensor on friday, after reading up on how to fit the FPR it seemed Audi want £200 and 2-3 hours labour and others have done it in about 45mins but require special tools.
    i got up saturday morning (in the rain) and decided i'd crack on, started at 8.50 and by 9.10am it was all back together with new thrust sensor too and no special tools required just a section of 12mm id hose to locate the new FPR before screwing it back in.
    can't say i've noticed any real difference but i'm convinced my intank pump is dying a death so will be upgrading pump for a better flowing item. hoping to order a WMI kit today so when i get that on and the new intank pump i'll be getting it mapped again and hopefully crack the 400bhp mark so the RS4 FPR will help there.
  4. olethalb
    357
    77
    lovely, pics (non iphone) please thank you
  5. Golfedd
    144
    35
    I say... white light on the way for ya bolloywood :hubbahubba: haha
  6. olethalb
    357
    77
    My AEM WMI kit came during the week and i had the day off work today so decided i'd start fitting the kit
    i'd decided the best option was to install the tank (5 litre) and pump in the boot, looked like the passenger side would be the best option as the tank has to be higher than the pump
    the pump looked fairly large and has rubber feet so thought it best if i make a wooden floor (also not keen on screwing through the body of the car) so i made a template
    then made it out of MDF
    it fitted snug but there was a stud so i used a golf trim screw to stop any vibrations, i then made a template and transferred it to wood to mount the tank on
    made some brackets to secure it to the car without screwing into the body
    then trimmed the carpet around the board
    next was to mount the pump
    and tank
    soldered and extended the looms
    and ran the lines and loom up the inner arch
    then fitted it up
  7. olethalb
    357
    77
    i ran the lines down the passenger side to the front kick panel
    and ran into the bay via a grommet next to the A/C pipes
    while i was at it ran a vac line to the cabin that will connect to the boost sensor in the WMI controller
    after a lot of soldering and trimming wires the controller is mounted in the glovebox
    i am waiting for a vac / boost take off from forge and need to get an ally threaded boss made up so it can be welded in my boost pipe to mount the injector. ran a test program and it worked well
  8. olethalb
    357
    77
    oh and a pic of the thrust sensor and fuel pressure reg pre fitting
  9. olethalb
    357
    77
    i've decided i will completely hide the tank so have ordered another level sensor that i will fit at the top of the tank but spun 180*, i will hook this up to an led that will be mounted near the fill spout. this will light up when the tank is full so there will be no need to see the tank or have and overfill / spill in the boot.
  10. Golfedd
    144
    35
    sounds like it was nagging in the back of your head to be done! haha! Nice man... tidy little install waiting on results
  11. olethalb
    357
    77
    did it all in one day and takes a lot longer than i thought, started in the rain - worked through the cold and into the dark. get it fitted properly and functioning was the order of the day.
    i've ordered some carpet and trying to locate a skoda filler neck to make it look more OEM, want it to be easy to live with, reliable and not look like it's been thrown in.
    i took the injector nozzle to my engineer friend yesterday so he can make an ally threaded boss so i can pop my boost pipe down and he can weld it in. after christmas (and uprated intank fuel pump is done) i'll probably order a flow rate monitor to keep an eye on things.
  12. Golfedd
    144
    35
    Nice...probably be one of the cleanest installs of WMI yet lol... where you thinking of installing the injector? just after the welded flange already and underside hidden?
  13. olethalb
    357
    77
    will probably be on the side, the injector has a 1 way valve so ends up being about 50-60mm long then the 1/4" pipe comes off it so would struggle for room and pipe angle underside.
    hoping to get a new filler for the tank in the next few days, ordered a few more parts off ebay to complete the install, the 'full tank' led turned up and some dark grey acoustic carpet. also 'forge' boost take off came through but have to say it looks like copy tat, the seal is now a cork gasket not an O ring as shown on the website.
    also got cheapy digital boost gauge on the way so i can keep an eye on boost levels, had to be digital so it can be easily read - i'll be mounting it out of direct sight.
  14. olethalb
    357
    77
    got a couple more bits through toward completing my water meth install
    vag oem washer bottle filler neck, level sensor and caravan waste outlet
    fitted the caravan waste outlet to the AEM tank cap also got forge bost take off and 12v green LED
    my grey carpet came through too
  15. pburv
    pburv Well-Known Member Team Glacier Gold Supporter Audi S3 quattro saloon DSG
    5,199
    10,892
    Hope it wasn,t a second hand waste outlet!:jester:Nice install mate.Wish I had the patience,time and money to do this.Respect...Paul:o.k:
  16. olethalb
    357
    77
    thanks Paul, finished the install side today
    first job for the day was to make a board to hide the tank
    then a couple of pieces to space it out
    then i removed the tank and fitted the second level sensor
    made a loom for the LED
    bound the looms and outlet pipe in fabric tape
    made looms for the level sensors and to connect to the LED, also wrapped in fabric tape
    fitted tubing to outlet on cap and made cut out in the board
    next i made a stainless bracket for the fill pot
    covered the board, fitted the LED and fill pot
    tested the 'FULL' LED
  17. Golfedd
    144
    35
    So clean and OEM... nice one ollywood! ( cough cough UD? cough)
  18. olethalb
    357
    77
    Cheers Eddwin, just wanted it to look tidy and be easy to live with. got a suitable sized bottle i'll make a bracket for on the other size to keep for when the 'low level' light on the dash comes on.
  19. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,766
    356
    Fair effort to keep it nice and behind-the-scenes.
  20. olethalb
    357
    77
    thanks Martay, i think i'll paint the stainless bracket black and see if i can pull it 10mm closer to the edge.
  21. Adam.
    Adam. Meow.
    662
    34
    lol'd @ edwin giving it the real Miami.
  22. olethalb
    357
    77
    sweaty barefoot on my carpet :(
  23. D2NY G
    D2NY G Well-Known Member
    1,088
    132
    that set up looks spot on mate, oem+ indeed
  24. olethalb
    357
    77
    thanks bud :)
    well a lovely rainy day and no batteries for my cam so iphone pics it is.
    my box of pipes arrived this morning
    i've been trying to sort out a better solution to my turbo intake so bought several bends to try and make something i could keep away from the turbo.
    after tring a few different routes i've settled for this but still not happy with it but it'll have to do for now
    once that was mocked up i wanted to hard pipe the DV return too
    i'm still nt happy with the intake, it'll function better as the filter is now away from the turbo and near the drivers side bumper vent but just looks rubbish :(
    also fitted the LED boost gauge in the glovebox to keep an eye on things when needed
  25. Morgan46
    Morgan46 Member
    34
    I revert to my 1st reply......is that all haha looks awesome and by looks and sounds of mods it's gonna be a beast ,wish mine was like that especially as the other day a B6 S4 pulled up beside me ,we both nailed off lights mine spun like a ***** (was very damp) his s4 just flew away lol bet when they see yours with 2.0turbo on it an s4 driver is gonna be like see ya then like WTF haha
  26. Golfedd
    144
    35
    Can you not stainless heat shield around the turbo a bit more, three bolts into the top of the drivers chassis leg, then it bends towards the plugs like this angle > / then bends and covers the manifold and hot side mostly. here's a SHOCKING drawing... LOL
  27. olethalb
    357
    77
    thanks Morgan, i just want it to go as well as it looks :)
    Eddwin - i have a sheet of stainless on order to make a better heatshield and been considering ceramic coating the decat pipe. the plan originally was to have a 90* bend out of the turbo towards the rear of the car, then 180* back towards the front and sweep down to behind the headlight but there just isn't room for the angles with the 3" piping :(
  28. andymartin045
    andymartin045 Member
    47
    have you seen the carbon fibre difuser for the dtm valance from osir design usa, it might just finish your car off a treat since your a subscriber to genuine carbon
  29. olethalb
    357
    77
    andy - i'd always wondered if someone produced a rear panel like that. thanks for the company name, at $500 + shipping i'll try and put some money by next year once i've finished messing in the engine bay.
    my stainless sheet arrived last night, hopefully if i can get this mk2 golf 20vt i'm building done i may have a little time for my car :)
  30. olethalb
    357
    77
  31. andymartin045
    47
    TTS Roadsport in Bedford are the UK agents for OSIR. They ordered it from Hong Kong (a 4 week wait) and fitted it for around £300 I think. The weave is the same thickness as the weave in the DTM's dash and the quality is fantastic.
  32. olethalb
    357
    77
    AWESOME! thanks Andy
    i take it you have it on yours then? any pics? was looking at the pillars too ;)
  33. andymartin045
    47
    Ive had it fitted yes. Im out of the country at the moment and so cant post any pics. But I would recommend it. The red towing eye draws the eye and the diffuser completes the look. Now I just need to dremmel the front and rear vents. Do you think you'll get the b pillars?
  34. olethalb
    357
    77
    thanks Andy, had a look on the website and says £400 so i'll await pics before taking the pluge :)
    now for quite possibly the most boring update i've ever posted
    got my carbon fibre gearknob through today, i'm not a fan of non oem and hate things that look 'bolted' on so some modification was required
    the gearknob
    the DTM knob / surround
    stripped apart from the gator
    trial fit of the sleeve against the new knob
    cut the gearknob shaft in half, needed the lower section to secure the gator and part of the upper to secure the sleeve
    gator secured
    sleeve in place
    gator on and slid down, rubber sleeve fitted
    gearknob tightened down
    gator slid back up and secured
    done
    unfortunately the carbons not an exact match but i'm happy with it :)
  35. olethalb
    357
    77
    oh also took delivery of 25 litres of virgin grade methanol over christmas so i can knock up a 50 / 50 mix and have 50 litres ready to use.
    and less excitingly bought a new battery as the cold and 1 mile journey to work has taken it's toll on mine :(
  36. Golfedd
    144
    35
    what if you forget where a gear is... there is no like diagram and stuff?
    haha - does it sit a bit taller or is it just the photo?
  37. olethalb
    357
    77
    same height good buddy :)
  38. olethalb
    357
    77
    the little lady had these made up for me for Christmas
    and she also fot me a new 3" neck filter in blue which will go on with my new intake when it's finished
  39. olethalb
    357
    77
    yet another 'mod' i'm not sure i like the look of, i can already see it being removed or reworked - anyway....
    decided to have a crack at heatshiled, removed original
    made a cardbord template of the shape i was aiming for
    unpacked the stainless
    marked it out
    started to take shape
    drilled hole for lambda
    trimmed a little further
    fitted
    i don't particularly like the look :(
    James.c likes this.
  40. Inertiauk
    Inertiauk Active Member
    575
    29
    I love your DTM
    I want it!
    b7 + Quattro + lots of boost. What a combo.
