my DTM 'build' - story so far, hybrid K04 - custom FMIC
olethalb Nov 16, 2012
  1. olethalb
    olethalb Active Member
    357
    76
    when i joined i said i wasn't going to make a 'build' thread as not a lot was going to be done to this one, unlike my old bora.
    this is still the case but i had a little thread on uk-audis as a record of what has been done, but they've recently upated the site and i cannot get on with it at all so i'll transfer what i have done so far.
    spec - A4 TFSI permanent quattro DTM LTD edition made in 2006 to celebrate audis success in DTM racing
    as i bought it - 220bhp k03 turbo recaro half leathers and DTM specific carbon extras
    first things first - new fuel pump tappet and cam chain and tensioner to keep things sweet
    and after the work spruce the bay up a little
  2. olethalb
    357
    76
    after the engine had been treated it was time for wheels, these came up fairly cheap so snapped them up
    next was to 'joey' the headlights and de tango
    soon after the long awaited coils arrived
    and with 12mm spacers a little fitment
    also ebayed a leather arm rest
  3. olethalb
    357
    76
    more power was on the cards so started accumulating parts
    k04
    DV
    one stage cooler plugs
    s3 injectors
    with more to follow.....
    the DTM comes with 320mm front discs which aren't the best so upgraded to S4 345's
    aux belt tensioner started clicking so on with a new one
  4. olethalb
    357
    76
    the rotis came with tyres but size wasn't ideal so i changed them for 215/35's and tweaked the ride height a little
    and purchased a new reg from DVLA
    after having a lot of bits and bobs on order from UK and USA they started trickling through
    ATP 3" decat
    polybush snub mount
    milltek cat back system
    Autotech HPFP internals
  5. olethalb
    357
    76
    the day of exhaust fitting came
    when i removed the original cat the wastegate flap had disintegrated from vibration
    all i could do at that piont was weld the flap back to the arm....
    fitment of the milltek went well until it came to the tailpipes
    they stuck out far too much so had to trim an inch off each tailpipe trim
    they still didn't sit evenly in the cutouts in the bumper so i had to cut a bracket off that regulated the distance between the pipes and weld a correct sized rod in between
    the left pipe would not sit high enough no matter how much tweaking so i had to splice the tailpipe trim and reweld
    perfecto
  6. olethalb
    357
    76
    as i was gearing up for the K04 swap i spoke to MRC who advised FMIC - the kits i had seen weren't too impressive, either required bumper chopping or losing the crash bar, neither was an option
    i measured up and went for a core intended for another audi
    then set about mocking up custom hard boost pipes with a variety of ally bends
    mocked them all up to size and correct path making no contact and gave them to my ally welder
    also decided to weld the s3 dv flange to the boost pipe
    painted and fitted
  7. olethalb
    357
    76
    next was the modified k04
    tt225 outlet welded on
    downpipe bolts repostitioned and rethreaded
    test fitted
    bolted up
    intake with recirc inlet for DV
    front end slotted back on with no mods or trimming :)
    DIY heatshield box
    now it was all up and together next was MRC for mapping
    made 330bhp and 350 torque but had budget fuel and clutch was dying :(
    well fitted a new clutch yesterday, brimmed it with optimax and went to RR day today but was too low for the rollers :(
    James.c likes this.
  8. olethalb
    357
    76
    oh one from Surrey RR day today - ignore the tit in the wifebeater
    few more pics - one from players
    one with new honeycomb satin grill
    and completed the de-chroming with some carbon fibre mirrors
  9. olethalb
    357
    76
    also fitted BSH PCV fix but will be making custom catch can set up
    refitted stock 'D' diverter valve
    near future mods include:
    better custom intake set up
    custom manifold / turbo heatshield
    better p/s fluid cooler
    WMI kit
    uprated intank pump
    make a new crash bar
    source 'open' grill or make my own
    remap (3rd time lucky)
    next year will be fbsw and some new wheels i think
  10. mancdan
    mancdan Active Member
    485
    50
    Excellent write up and cracking looking car. Hats off to you sir.
    Did you wrap the chrome mirrors in Carbon or replace them completely?
  11. olethalb
    357
    76
    mancdan - thanks, i replaced the covers completely. got these ones from felondnb off edition38 :)
  12. mancdan
    485
    50
    whats edition 38?
    Also,dso you still have your chrome mirrors?
  13. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    1,990
    755
    Here ye go fella
    Edition 38
    Mac
  14. stuiwhite
    stuiwhite Member
    53
    Car looks awesome!
    Is that grille off eBay? - apologies if this offends!
    Just, I want one!
    Thanks,
    Stui
  15. Morgan46
    Morgan46 Member
    34
    Is that all you've done lol
  16. AudiB7Jay
    AudiB7Jay Active Member Audi A4 S-line owners group Team Aruba Blue TDi saloon Manual
    448
    26
    Soooo unfair! :( I wanted rotiform blq 19's on mine once lowered! You beat me too it :/ looks sweet too!
    Did you have to add spacers with them? What kind of alignment settings you running too? How far did you lower by also?
    So jealous right now lol sweet car :)
  17. chrisa4quat
    chrisa4quat Active Member
    970
    This is a great thread! Exactly what I want to be doing to mine!! Are the s4 pads and discs a straight fit?
  18. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    Looks stunning, i'll be the last to fit my ko4 at this rate lol,cheers Andy
  19. chrisa4quat
    970
    Doubtful Andy ill be one of the last! Lol
    sams13 likes this.
  20. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    easily the best DTM i have seen!
    well done fella! :wub:
  21. chrisa4quat
    970
    Agreed!!!
  22. sewell10
    sewell10 Member
    236
    That car looks mint mate credit to u fella I have a yellow one great car
  23. Jez-dtm
    Jez-dtm Member
    90
    15
    What a beaut! Do the s4 disks and pads just fit the original dtm callipers or would I need a fitting kit ? Cheers! 👍❤
  24. chrisa4quat
    970
    I'm still waiting to see if they do too Jez. That would be my next mod if they do as I need brakes soon!
  25. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    Wow.....that's a lot of beer tokens spent on that! Amazing stuff and lots of ideas there too! Well done Sir.
    A
  26. BA4
    BA4 Member
    76
    really really nice car, best of luck with it
  27. Olly P
    Olly P My other cars a mk2 Golf GTi
    702
    12
    Awesome DTM, given me some ideas!
  28. olethalb
    357
    76
    wow - quite a response over the weekend :0
    mancdan - it's a vag forum. i think the covers got thrown out, it wasn't 'til i removed them i saw they were ebay copies.
    Macdoon - thanks
    Stui - yes ebay item, i was after the more open holes but it's only available from Australia at the mo with £145 postage
    Morgan46 - yes, not a lot in comparison with my last car :)
    AudiB7Jay - they have 12mm spacers on the rear, all allignment is stock but obviosly had to have tracking done. i didn't take measurements, just lowered it so the front and rear arch to tyre distance was even and there was no contact.
    P.S Roti's will be for sale next year
    Chris - i was told to fit S4 fronts all you need is discs pads and S4 carriers, i fitted the carriers to my DTM calipers and popped the discs and pads on but the very top and bottom of the caliper contacted the disc. i could have ground a bit out but i picked up the proper calipers for cheap enough and bolted them on.
    ANDY - thanks, i still have my dead one sat on the bench :(
    CHEZ - thats quite a compliment, thank you
    Sewell - thanks, do you have a thread? i'd like to see a yellow one
    Jez - see reply to chris above RE brakes :)
    Molnbowman - i had my last car 'show car' bora up for sale but decided to break it so when something sold i'd treat the A4.
    BA4 - thanks, i need some after my turbo died
    Olly - thanks, and thanks for spelling 'Olly' in the correct way :)
  29. ANDYTQ
    1,184
    105
    Pipework looks really neat,where did you source the front mount from?
  30. Jez-dtm
    Jez-dtm Member
    90
    15
    Cheers mate! One more quick question....
    Do you have a guide, or a link to the one you used to get rid of those awful orange reflectors?
  31. Olly P
    702
    12
  32. solaris
    solaris Member
    416
    17
    Well done, good to see another DTM with a KO4 :happy:
  33. olethalb
    357
    76
    Jez - i just went at it :yes: i think i must have seperated and redone my bora headlights in different styles about 6 times.
    Olly - thanks, i just went for the leave them off with them chrome / orange bulbs
    Solaris - my turbo died a short time after my first MRC mapping session, so i went to turbo dynamics and bought a brand new item and had hybrid work so it should be the same spec as yours now. ordered a new K revision thrust sensor and RS4 pressure regulator yesterday, next will be uprated intank pump then WMI. i'm hoping to crack 400bhp with the hybrid.
    i'll also be making a tubular crash bar so i can expose the full fmic and will have to buy / make a more open grill - remove or reduce number plate plinth.
  34. olethalb
    357
    76
    ANDY - nearly missed you out :0 it's from an ebay kit for a B6, i looked at a lot of cores from jap to RS500 but this fitted my dimension needs best. the hard pipes, silicon joiners and clamps were all binned and custom pipework made up. the pipes that came with the kit were ridiculously narrow :haha:
  35. Golfedd
    Golfedd Active Member
    144
    35
    looking good Olly man, Nice to see the full pics and the bits you've done! Didn't realise the level of love you gave this one (it comes as no surprise though) haha. Catch you soon no doubt for some A4 rolling times! :rockwoot:
  36. olethalb
    357
    76
    i'll be happy when it's making good power with a decent map, you know i can't leave things alone. the bora was supposed to be my sensible car....
  37. stuiwhite
    stuiwhite Member
    53
    Any build thread of this Bora you speak of :) - would be nice to see other pieces of art you have mastered!
    Really jealous of this one - wish i had the funds to buy such a gorgeous vehicle!
    Ill have to stick to me SE TDI!
  38. olethalb
    357
    76
  39. stuiwhite
    stuiwhite Member
    53
    WOW!
    Ill watch this thread with eager eyes!
    *Tail between legs* - Back to work I go!
  40. sewell10
    sewell10 Member
    236
    All I can say is mint well done
