My DIY guide for Retro fitting Puddle Lights
RobinA3 Jul 19, 2008
  1. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
  2. schuey564
    schuey564 New Member
    Hi robin,
    ive sent you a pm
  3. RobinA3
    1,826
    46
    It looks like on the newer A4 models (post 07) which run the CAN system footwell lights could be fitted. Will confirm when i know 100%.
  4. RU55SSO
    RU55SSO Member
    792
    24
    I have red reflector things on my doors? But they don't light up
  5. RobinA3
    1,826
    46
    All A3's have red reflectors in the doors, they are dummy blank ones. You need to replace them with red lights and fit a loom.
  6. neu318
    neu318 New Member
    Do you ship to the US? Can you tell me how much you would charge for each individual kit? Thanks
  7. RobinA3
    1,826
    46
    Nue318 i do ship to the US, have had a few members from the US having looms from me.
    You got pm.
  8. neu318
    neu318 New Member
    Thanks RobinA3, will be making a purchase with you as soon as I have some spare cash.
  9. schuey564
    hi robin.
    sorry for late reply,been a tad busy.
    those lights and harnesses arrived safe and sound....well impressed with the quality,absolutely spot on.
    speak to you soon,
    regards.........Alan.
  10. 1animal1
    9,978
    Just got these looms through from Robin today...excellent work mate, quality is 100%
    just want to clarify.... for both door cards i need pins 18 and 19 for an MY09 car?
  11. 1animal1
    9,978
    Confirmed....it is pin 18 + 19 as there are no pins @ 1 + 2 on the MY09....
  12. RobinA3
    1,826
    46
    spent this morning in the rain fitting a set of lights to a B6 Avant, thankfully Alan was very helpful with drilling the holes etc and finally got them all working!
  13. 1animal1
    9,978
    looking good those mate.....
    Will post up pics of mine once i have the footwell lights in, absolutely chuffed to bits with the door lights...... just this minute finished fitting them, took me about 2 hours in total due to sussing out which pins, otherwise a half hour per side job (assuming full light and no rain!)
  14. Essflee
    Essflee Well-Known Member
    2,142
    66
    Strange... Don't seem to have any of these 'how to fit puddle lights' threads for the 8L S3.
  15. RobinA3
    1,826
    46
    The 8L doesn't support these lights, the control system for the lighting etc is a lot different to the 8P control system.
  16. 1animal1
    9,978
    you arse lol
    Robin he's taking the piss mate ;) , the 8L S3 had the puddle/warning lights as standard :readit:
  17. Essflee
    2,142
    66
    Lol, clutching at straws mate, all I had haha...
    :beerchug:
  18. 1animal1
    9,978
    haha, i could give you much more ammo, but i won't on this occasion :)
  19. Joereynolds89
    Joereynolds89 2010 Facelift!
    163
    How much for looms for a 04 3 door A3, for both footwell lights, puddle lights, warning lights, and handle illumination?
    Do you supply the actual lights yet? If not do you have the additional part numbers on top of the guide for the handle illumination?
    Thanks, Joe
  20. RobinA3
    1,826
    46
  21. 1animal1
    9,978
    I fitted Robins looms last week, absolutely brilliant OEM looking looms and do the job nicely - heres some pics i managed to take last night showing the warning/puddle/footwell lights
    no brainer of a mod and the first thing i did - i know its been said a million times but cant beleive the bellend who bought my car didnt spec thse for the sake of £80
  22. RobinA3
    1,826
    46
    is it an £80 option? i thought it was a part of the lighting pack which was around £300
  23. 1animal1
    9,978
    i thought the lighting pack was £80 mate..... cant be arsed to check though :)
    sure it wasnt as much as £300 but i have ben wrong before ;) also just been quoted £77 from Stoke for the map reading lights, seeing as i will most likel never use, i'm gonna keep my eye on the bay as you suggested Robin ;)
  24. RobinA3
    1,826
    46
    I think i paid £65 for my reading light but it was new.
  25. robp_kent
    robp_kent New Member
    20
    Finally got my puddle lights and footwell lights coded in today. Working perfectly. Another big thumbs up for Robin's workmanship and excellent service.:anbet:
    Cheers fella.
    Think I need to order a set of puddle lights for the rear doors now though, should have got em all at the same time:think:
  26. RobinA3
    1,826
    46
    Many people buy just the fronts to try out how hard it is to fit and then realise its really easy and then they come back for the rear door looms!
  27. SootyTDI
    SootyTDI Member
    39
    If you've got a cabriolet you'll know that the single light on the one side isn't really enough. The boot opening isn't particularly large then add in the fact that your own shadow blocks most outside light from reaching the boot means a lot of rummaging around in the dark :ermm:
    After fitting Robins puddle lights to the doors I had the idea of extending the existing wiring harness to add a second light on the other side of the boot, whilst wishing to keeping all existing wiring intact.
    A few emails later and Robin had modified a new light fitting to include a new extension cable. Simple to fit, just remove your existing light fitting, plug Robbins modified fitting in its place then route the cable along the cars existing cable paths across the rear of the boot. You'll need to remove the rear and offside boot trim in order to get access to these cable runs, but that pretty easy.:icon_thumright:
    The hardest part of the install is cutting the hole for the new light fitting, but if you've fitted the puddle lights then its no harder.
  28. RobinA3
    1,826
    46
  29. SootyTDI
    SootyTDI Member
    39
    Cable length was pretty much spot on considering I was guestimating with all the trim in place at the time.
    With the cable following existing cable runs, so as to use existing mounting clips etc, also leaving a little slack to pull the fittings forward to change bulb I'd say it was fine at that length. If I was being pedantic you could make it 50mm shorter for a perfect fit, but loosing the 50mm was easy.
    I thought it might be useful to show that now you can actually see what's in the boot at night! The picture's been taken by a cheap automatic camera with the flash turned off. Since pretty much the whole of the boot is black its not the ideal way to take the picture, however you can see that there is enough light to pick out certain details.
  30. RobinA3
    1,826
    46
  31. pooley
    pooley New Member
    hi mate can you fit this to my audi a4 b7 and how much
  32. pooley
    pooley New Member
    hi mate can you do this for an a4 b7
  33. s3ollie
    s3ollie Member
    762
    Fitted my puddle, warning and footwell lights yesterday. All brought frorm Robin.
    The worst bit was removing the door cards, it did take some force!
    Thanks Robin, great service
  34. RobinA3
    1,826
    46
  35. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    342
    Top service from Robin again, he's the man! Door lights fitted bang on in my 2010 S3. A+ :)
  36. HTR
    HTR Mark H
    15
    Just a quick thank you to RobinA3 again! Received my looms for a 5dr Sportback, took prompt delivery of his custom OEM quality looms and he also kindly ordered the light holders from Audi on my behalf. You're a credit to this forum!
    Regards, Mark
  37. Jason Owsley
    Jason Owsley New Member
    how much would the full kit cost? if it is still available
  38. RobinA3
    1,826
    46
    Prices are as follows:
    Door Loom (puddle and warning light) - £17.50 each
    Door Loom (puddle, warning light and door handle LED) - £27.50 each
    Footwell Loom - £17.50 each
    Red warning lights - £10.50
    White footwell/puddle lights - £7.50 each
    1st Class Recorded postage - £5.
  39. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    May have a foot well loom off you soon Robin, is that just the loom without the actual lights?
  40. Farhan
    Farhan Active Member
    1,234
    57
    looms is without the holder. I bought mine complete very good mod. Excellent service from robin
