My day is getting worse!! Cd error service...?
DJ-S3 May 19, 2013
  1. DJ-S3
    DJ-S3 Active Member
    690
    43
    Right I'm assuming I'll need vcd's to sort this? Or is a remove and dismantle job?
    Bassically as I was driving home my cd started skipping and then just stopped. When I tried to eject it is goes bong, cd error service. So I can't even eject the damn thing!!
    Bonnet latch and now this. I reckon it's because my other half has just bought a brand new car and its feeling sorry for its self. Lol.
    Any help on the matter will be much appreciated. Audi S3 8P 56plate concert system with Bose.
    Thanks Dom
  2. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Mine does this a lot, usually just skipping to the next track fixes it
  3. DJ-S3
    DJ-S3 Active Member
    690
    43
    It won't let me onto the cd anymore. So can't even skip a track...
  4. phil77
    phil77 Member
    56
    Mine did this also. Just bought an adaptor so use USB stick now
  5. NHN
    29,345
    1,719
    Not a good sign, if you cant resolve, I have the ipod module that goes in place of cd changer connection available.
  6. Aidy06
    412
    19
    What is this iPod module you speak of Nigel???
  7. big harty
    big harty Member
    307
    15
    I have a double din genuine audi 6 disk stereo out of an a4 sline going very cheap if interested
  8. NHN
    29,345
    1,719
    Just the standard audi ipod interface that uses the changer connection, I have 2 actually.
  9. percymon
    percymon Member
    156
    Anyone know of a reset function ?
    On the Porshe CDR-23 (made by Becker) you could press and hold the TP, 1 and 4 radio presets for a few seconds and it would reset. I used to get similar issues with my CDR-23 - Porsche replaced a load under warranty only for units to be returned to the factory and found to work perfectly when reconnected - they then issued a service bulletin telling dealers not to replace head units.
  10. NHN
    29,345
    1,719
    Could try a battery disconnect.
  11. DJ-S3
    DJ-S3 Active Member
    690
    43
    I've got a iPod connector in my glovebox. I was hoping there'd be some way to reset it if I'm honest. Disconnecting the battery was a though but about 2hours earlier I tried opening my bonnet and it wouldn't. 2things in one day, and I'm awfully worried that bad things usually come in 3s!
    If I manage to get the bonnet open and disconnect the battery it won't lose my mileage or remap or anything will it?
  12. NHN
    29,345
    1,719
    No you wont lose any data.
  13. DJ-S3
    DJ-S3 Active Member
    690
    43
    Good good. Cheers Nigel
  14. R34nel
    R34nel Active Member
    323
    33
    If your revo mapped you may lose your settings, mine did this when they fitted my clutch last week, went back to 1-0-0 which is stock mode, I noticed straight away because when I dropped it off it was in valet mode, unless they have an sps but I can't see why they would intentionally alter my settings without telling me
  15. sliced
    sliced Drive safe, stay alive.
    1,559
    334
    did this solve it? could try removing cd with tweezers.
  16. DJ-S3
    DJ-S3 Active Member
    690
    43
    Funnily enough after I left it all night it's decided to work again. Which is funny because when it happened I turned the engine off and pulled the key out and it still didn't work. Strange. I wouldn't be able to disconnect the battery as I can't open the bonnet... Due to the bonnet release not working. That will hopefully be resolved tomorrow night by my friendly panel beater. I hope...
  17. NHN
    29,345
    1,719
    Depends where its snapped, but remove the drivers wheel, arch liner & see if you can reach up into cavity to grab the cable, otherwise maybe need to drop the rad fans & reach up to lock from below or through the grill somehow, real pita job tbh.
    Good luck getting discs out with tweezers, that IMHO isn't going to happen if the carriers locked them into position.
  18. DJ-S3
    DJ-S3 Active Member
    690
    43
    Cheers Nigel, but of a legend at this stuff!
    Dont need to get cd out, all is working fine with it now.
  19. Aidy06
    412
    19
    Would this work with a Concert 2 single DIN without CD changer or does it have to have the changer to work?
  20. NHN
    29,345
    1,719
    You'd need to buy the loom for it & of course have the glovebox for changer to slot into, have got the glovebox aswell.
  21. Aidy06
    412
    19
    Why would I need to have the glovebox that the changer can fit into? My glovebox has a shelf with two compartments on it
  22. NHN
    29,345
    1,719
    Because the ipod interface module sits in the same socket as a changer would, which is a specific glovebox version, wont fit the standard glovebox.
  23. Aidy06
    412
    19
    Ah I see, how much would this little modification cost Nigel? I need iPod connectivity and was looking into a few things mainly the Dension
  24. NHN
    29,345
    1,719
    Dension is probably easiest option costwise.
