Cars a 58 reg audi a3 2.0 tdi 130 cr.
My cars been pretty much faultless but today i was driving home steady in traffic and noticed esp light flashing by the time i had noticed that the engine management light was then on too and the coil light flashing, put my foots to the floor no power, tried to restart and eventually restarted drove anoher kilometer it was running ok but warning lights still on cut out twice one and managed to get to my driveway. Once on the drive way i started the car ran ok then cuts out and now it wont restart at all. Some im thinking its a sensor or problem with ecu heres the vcds readout if anytone can help tell me what it means:-
btw the faults recorded with the rear light are from a few weeks back from when it went into the body shop for the rear quater to be repaired / painted i think so nothimng to do with this.
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 77
VIN: WAUZZZ8PXxxxxxxx Mileage: 39790km/24724miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3066
Revision: 13H01--- Serial number: AUX7Z0H6FNN05I
Coding: 0000072
Shop #: WSC 83968 026 674567
VCID: 75EAE38A239B20B4
8 Faults Found
004997 - Control Module Malfunction - Lambda Sensing Circuit
P1385 - 000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 31
Mileage: 39788 km
Time Indication: 0
Freeze Frame:
RPM: 1840 /min
Speed: 79.0 km/h
Lambda: 95.5 %
Mass Air / Rev.: 525.0 mg/str
Voltage: 1.800 V
(no units): 0.0
Voltage: 1.275 V
008482 - Accelerator Position Sensor (G79): Signal too Low
P2122 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 7
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:26
Freeze Frame:
RPM: 1679 /min
Speed: 73.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Voltage: 0.684 V
Voltage: 0.304 V
Bin. Bits: 0 01 0
008487 - Accelerator Position Sensor 2 (G185): Signal too Low
P2127 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:26
Freeze Frame:
RPM: 1679 /min
Speed: 73.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Voltage: 0.684 V
Voltage: 0.304 V
Bin. Bits: 0 01 0
001576 - Fuel Pump Relay Control Circuit: Short to Ground
P0628 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39791 km
Time Indication: 0
Date: 2011.12.19
Time: 18:42:28
Freeze Frame:
RPM: 0 /min
Speed: 45.0 km/h
Voltage: 12.46 V
Pressure: 80.0 bar
Inj. Quantity: 0.0 mg/str
Lambda: 30.0 %
Lambda: 19.7 %
005000 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:08
Freeze Frame:
RPM: 1311 /min
Speed: 54.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Voltage: 0.760 V
Voltage: 0.380 V
Temperature: 17.1°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:08
Freeze Frame:
RPM: 1518 /min
Speed: 53.0 km/h
Load: 0.0 %
Bin. Bits: 0000000
Hex Value: 0xFF2A
Hex Value: 0xFF01
001027 - EGR Valve (N18): Malfunction
P0403 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:11
Freeze Frame:
RPM: 1104 /min
Speed: 42.0 km/h
Load: 0.0 %
Load: 14.9 %
Lambda: 15.8 %
Mass Air / Rev.: 520.0 mg/str
Temperature: 85.5°C
001575 - Fuel Pump Relay Control Circuit: Malfunction or Open Circuit
P0627 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 39790 km
Time Indication: 0
Freeze Frame:
RPM: 161 /min
Speed: 31.0 km/h
Voltage: 13.15 V
Pressure: 72.0 bar
Inj. Quantity: 19.8 mg/str
Lambda: 30.0 %
Lambda: 25.3 %
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 13424012092400FBC80F02E8901E00823800
Shop #: WSC 06314 000 00000
VCID: 74ECDE8E28E139BC
1 Fault Found
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 185
Mileage: 39788 km
Time Indication: 0
Date: 2011.12.19
Time: 18:39:00
Freeze Frame:
Count: 0
Count: 32768
Count: 12800
Count: 8196
Count: 50505
Count: 1
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000885 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73EEDD922DEF3E84
No fault code found.
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008699708
Coding: 15A82F07A0141380EF00001C4F00000000084E0564010003002000000000
Shop #: WSC 06314 000 08192
VCID: 48945A7E04E9ED5C
Part No: 8P2 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
4 Faults Found
03099 - Right Rear Turn Signal Lamps (M8)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Date: 2011.11.26
Time: 15:48:00
Freeze Frame:
ON
Voltage: 11.55 V
OFF
ON
OFF
OFF
OFF
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Date: 2011.11.26
Time: 15:48:00
Freeze Frame:
ON
Voltage: 11.40 V
OFF
ON
OFF
OFF
OFF
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Date: 2011.11.26
Time: 15:48:00
Freeze Frame:
ON
Voltage: 11.45 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52330819707905
Coding: 000003
VCID: 4182475A27D3DC14
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49925F7A1FE31454
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H15 0830
Revision: D0H15005 Serial number: 2246H005003556
Coding: 0004428
Shop #: WSC 00503 210 83701
VCID: 39722FBA4F0384D4
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K087150884
Coding: E9A01F061006020101
VCID: 356A238A631B60B4
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H15005 Serial number: AUX7Z0H6FNN05I
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000636
VCID: 438E4D523DCFCE04
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5000F6BAA53F4C
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
Component: Sounder No Answer
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found
01134 - Alarm Horn (H12)
004 - No Signal/Communication
00849 - S-contact at Ignition/Starter Switch (D)
008 - Implausible Signal - Intermittent
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850214948
VCID: 346C1E8E686179BC
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000636
VCID: 448C4E4E38C1C93C
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 195 M HW: 8P0 035 195 M
Component: R Symphony2+ H04 0270
Revision: 00H04000 Serial number: AUZ1Z4H7176712
Coding: 0730211
VCID: 3C7C36AE4031B1FC
1 Fault Found
00857 - CD Changer Unit (R41)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 33
Reset counter: 182
Mileage: 33146 km
Time Indication: 0
Date: 2011.07.26
Time: 15:36:28
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 N HW: 8P0 862 335 N
Component: FSE_256x BT H34 0520
Revision: 00000000 Serial number: 00000005020108
Coding: 0001222
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0000072
8 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Mileage: 39788 km
Time Indication: 0
Freeze Frame:
RPM: 1840 /min
Speed: 79.0 km/h
Lambda: 95.5 %
Voltage: 1.800 V
(no units): 0.0
Voltage: 1.275 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:26
Freeze Frame:
RPM: 1679 /min
Speed: 73.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Voltage: 0.684 V
Voltage: 0.304 V
Bin. Bits: 0 01 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:26
Freeze Frame:
RPM: 1679 /min
Speed: 73.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Voltage: 0.684 V
Voltage: 0.304 V
Bin. Bits: 0 01 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39791 km
Time Indication: 0
Date: 2011.12.19
Time: 18:42:28
Freeze Frame:
RPM: 0 /min
Speed: 45.0 km/h
Voltage: 12.46 V
Pressure: 80.0 bar
Lambda: 30.0 %
Lambda: 19.7 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:08
Freeze Frame:
RPM: 1311 /min
Speed: 54.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Voltage: 0.760 V
Voltage: 0.380 V
Temperature: 17.1°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:08
Freeze Frame:
RPM: 1518 /min
Speed: 53.0 km/h
Load: 0.0 %
Bin. Bits: 0000000
Hex Value: 0xFF2A
Hex Value: 0xFF01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 39790 km
Time Indication: 0
Date: 2011.12.19
Time: 18:41:11
Freeze Frame:
RPM: 1104 /min
Speed: 42.0 km/h
Load: 0.0 %
Load: 14.9 %
Lambda: 15.8 %
Temperature: 85.5°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 39790 km
Time Indication: 0
Freeze Frame:
RPM: 161 /min
Speed: 31.0 km/h
Voltage: 13.15 V
Pressure: 72.0 bar
Lambda: 30.0 %
Lambda: 25.3 %
Revision: 00H35001
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 185
Mileage: 39788 km
Time Indication: 0
Date: 2011.12.19
Time: 18:39:00
Freeze Frame:
Count: 0
Count: 32768
Count: 12800
Count: 8196
Count: 50505
Count: 1
Count: 0
Count: 0
Coding: 00056595
Shop #: WSC 06314
4 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Date: 2011.11.26
Time: 15:48:00
Freeze Frame:
ON
Voltage: 11.55 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Date: 2011.11.26
Time: 15:48:00
Freeze Frame:
ON
Voltage: 11.40 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 39242 km
Time Indication: 0
Date: 2011.11.26
Time: 15:48:00
Freeze Frame:
ON
Voltage: 11.45 V
OFF
ON
OFF
OFF
OFF
Coding: 000003
Coding: 0004012
Coding: 0004428
Coding: 0000636
Revision: 00H15000
2 Faults Found
Coding: 0000636
Coding: 0730211
1 Fault Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 33
Reset counter: 182
Mileage: 33146 km
Time Indication: 0
Date: 2011.07.26
Time: 15:36:28
Coding: 0001222
