hi,
i didnât want my first post to be asking for help but am in need of some. I have looked on the site but i cant fined anyone with the same fault as me.
i was just about to go to the scrappy to pick up a rear window wipe motor when i thought i would check the fuse to see if it was ok, so when i got there i could try the new motor before i bough it. While checking the fuse i also check the abs fuse as it comes on now and again but pulled one or two other fuse's out by mistake while looking for the abs one. i then put the covers back on and went to start the car to see if the abs light was off but the car started then cut out. I tried again but this time i noticed the dash cluster wasnât lighting up. My windows wont work either?
i have check all the fuse's there all ok. i have tried my other key same thing happens, i have run torque app on my phone to check for fault code but its clear. I have also disconnected the + battery wire but the fault is still there.
i have seen something about putting the to battery wires together for 15sec to discharge the ecu or something like that but that didnât work.
anyway here is the link to the vid so you can see whatâs going on:
http://www.youtube.com/watch?v=g3Lj_fEX9fc&context=C3e92011ADOEgsToPDskJ4DRMvqR7mP_i_6_NzSY9C
any help is appreciated cheers scott
