My Brembo 4 pots - brake pad question...
DJ_Troopa Oct 5, 2010
  1. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    I've got Brembo 4 pots waiting to go on my car within the next 2 weeks. They came with 323mm Leon Cupra R discs. I'm going to buy Ferodo DS2500 pads but i'm wondering what application i go for when i buy the pads? Do i just search for the pads under the Mk1 Leon Cupra R section??
    Thanks!
  2. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Thanks, just seen that in the other topic.
    But do i look for pads which come under the Mk1 Leon Cupra R section?
  4. <tuffty/>
    20,847
    3,687
    Ask Bill... he sells DS2500's for Brembos... LCR Brembos are different to Brembo Jnr calipers that are available as after market upgrades but pretty sure the pads are the same... LCR Brembos come with an external pipe linking the 2 halves of the caliper for brake fluid, Brembo Jnr calipers do not have this pipe as its internal to the caliper... both types of caliper work with LCR 323mm x 28mm discs, if you have Brembo Jnr calipers then fairly sure the LCR brackets won't be suitable but Bill does ones for the Jnr calipers..
  5. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    The guy i bought the Brembo's off said they're the same ones as the Leon Cupra R ones. Apparently they came from an Alfa Romeo GTV? I've got the adapter brackets with them too which fit onto my car. Confused.com lol.
  6. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Paul - I'm pretty sure mine are the LCR Brembo's as i have the thin pipe on the outside of the caliper. It looks like this one in the picture......
    and there's no pipe in this jnr kit in this picture but i have that pipe like the first picture i've put up.............
  7. jojo
    28,833
    3,488
    The pads should be the same for both calipers, I'm using LCR pads in my Brembo jnr kit.
  8. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Now i'm more confused lol
  9. <tuffty/>
    20,847
    3,687
    Jay, the calipers you have 'look' like LCR ones... I don't know for sure they are the same if they come off a different vehicle but I would imagine the pads would be the same...
  10. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Yeah, i heard all Brembo 4 pot pads are the same? Paul, do you know where Bill is by any chance? Been trying to call him.
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    me too....lol
  12. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Go away lol me first!
  13. <tuffty/>
    20,847
    3,687
    In a meeting I would expect....
  14. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    This could be a really silly answer but I have Evo 8 calipers and the pads are meant to be the same as every other bremb four pot. If this IS the case, then check out the Camskill website as they do Evo brake pads at silly cheap prices. Worth looking in to.
    Sorry if I've confused you even more!
  15. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    That's what i said up there ^^ apparently all Brembo 4 pots are the same and take the same pads. Just need to confirm that with Bill and if that's the case i'll be ordering from him!
  16. Prawn
    11,370
    3,234
    they wont be the same, absolutely definitely not a chance. it makes no sense.
    Pad shape and size depends largely on disc size, as teh radial curve on a smaller disc will be much tighter than a larger disc.
    Also, the surface 'height' of a disc varies greatly from car to car, so the pads would need to be different sizes.
  17. badger5
    9,374
    1,916
    hello - only me..
    sorry been in meetings on and off all day.. doh!
    pad backplate shape is the same between LCR and GT junior pads.. yes. LCR ones have leading/trailing edge chamfer and one pad has a wear sensor (as std)
    same ds2500's fit both these.
    not all brembo's are the same however.. so I can only comment on these 2
    available by phone now
    cheers
    bill
  18. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Thanks for the info over the phone Bill. I will hopefully have this problem answered tonight if there's a part number on the EBC's! What a hassle eh lol.
    Jay
  19. Hadders
    Hadders Member
    134
    My Brembos don't use the same pad I don't think, but then I'm silly and running the Brembos from a Clio 197/Megane R26/Megane R26.R :)
  20. gez
    gez S3 hunter
    109
    if you have brembo calipers of a Alfa GTv they will not fit. they are lug mounted and leon ones are radial mounted.
