My Big Brembo Dilemma :( Here's the stress...
DJ_Troopa Oct 12, 2010
  1. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    So, i bought a Brembo kit from a guy a couple months back off ED38. He said he's sure they came from an Alfa GT V6. The kit came with the following:
    Brembo calipers
    Adapters to fit my car
    New EBC Red Stuff pads
    New LCR 323mm discs
    New Braided brake hoses
    New pistons and seals
    I don't want the EBC Red Stuff pads because they're rubbish so i'm looking for Ferodo DS2500's. Here's my problem, the guy said he's 'sure' they came from an Alfa GT V6. I need to know 100% where they came from so i can get the correct pads!! I'm so stuck because i don't know where they come from :(
    The piston sizes in the caliper are 42mm all around not like other ones which have different sizes. Can anyone shed some light on this please? I've been on this case for nearly 2 weeks now and it's really stressing me out. I've got the calipers back yesterday from paint in gleaming smooth bright red and i can't even get them on the car yet because of this! If you have any questions about sizes etc please just ask.
    Thanks all
    Jay
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Jay, might be an obvious route that you have already covered, but might be worth ringing Brembo themselves, quoting a part number and seeing if it rings true with any of their systems?
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    That's another problem, apparently Brembo don't have phones because they have no contact number on their site and prefer to be contacted via email! God knows how i'd explain this to them over email lol.
  4. <tuffty/>
    21,353
    3,921
    post a pic of the actual calipers and the actual pads...
  5. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    I'm at work all day now so i can't get pics today, i'll get them up tomorrow morning.
    This sucks :(
  6. thorsy22
    thorsy22 Member
    308
    Should be able to get dimensions of the brake pads from the manufacturers site, so if these ebc red stuffs fit measure the pads and compare to the dimension for the Alfa GT V6 ferodo ds2500's dimensions?
  7. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    Have you or are you able to obtain the part number for the pads themself to confirm the ebc pads are for the alfa?
  8. Prawn
    11,535
    3,474
    ''Dear Brembo,
    I have a set of your front brake calipers, apparently from an Alfa romeo GT V6, although I am unable to confirm this, and as such, cannot buy new pads.
    the part numbers on the calipers are: XXXXXX and XXXXXX
    Could you please confirm which vehicle these were fitted to originally? or which other vehicles would use a brake pad compatable with my calipers?
    I have attached some pictures of the calipers in question for clarity
    (insert pics here)
    Kind regards
    DJ Troopa''
    Simples.
  9. badger5
    9,502
    2,002
    I have already told you to send picture of the pad..
    why is that so difficult?
  10. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Well i would of done that Prawn but the serial numbers on the Brembo calipers don't match up on their website. There are also no numbers on the pads and i've already spoken with EBC about this but they are useless! I've checked pad dimensions against Alfa GT V6 pads but they do not match up.
    I faxed it the day after you gave me your number Bill?
  11. mk1chopper
    1,092
    12
    Just searched on ebc website and the dimension for GT V6 (and GTV 3.2V6) pads (brembo) 131x75x15 so when you get home get the tape out, part no. is DP31540C (BR)
    For the earlier GTV (3.0) and fiat coupe turbo which also ran brembos the pad dimensions are 110x69x17 part no. DP31031C, these have the same dimension as the seat leon cupra R pads (110x69x14 part no. DP31140/2C) except they are thicker
  12. badger5
    9,502
    2,002
    nothing arrived here
    can you scan it and email it to bill@badger5.co.uk
  13. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Thanks Chopper. The length of my pads are 132mm and height from the highest part of the pad to the lowest part of the pad is 67mm. This has been measured on the backplate of the pad. Am i measuring from the correct points? I was told backplate by someone and another company said do it from the actual pad?
    Bill - You'll have another one coming to you shortly. Won't be able to scan as i don't have one here at work unfortunately!
    Jay
  14. mk1chopper
    1,092
    12
    Taken from ebc website:
    Dimensions are Width x Height x Total Thickness in mm.
    Total Thickness = New thickness of the pad including the backing plate.
    Width x Height = As if you a drawing a box around the pad and measuring left to right and top to bottom (the measurements may include gaps depending on the pad design).
    I think you have GTV calipers not GT ones. The GTV discs are the same thickness as the LCR discs so you wont have any issues with fitting, where as the GT discs are 4mm thicker.
  15. quattro1
    quattro1 Member
    639
    why dont you look for an alfa of the same model being broken on ebay and ask the guy for a single set of pads and match them up to the pads you already have?
  16. mk1chopper
    1,092
    12
    Am unsure to your calipers now after re reading your opening post and saying the pots are all the same size unlike the GTV/fiat brembos. Why dont you go into a alfa dealership and ask if you could see a set of pads from a GT V6 and compare
  17. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Thanks for the info guys. I've spoken to an Alfa dealership and they don't want to help. They said they don't have any part numbers for Brembo's so they won't know anyway? Confusing i know lol.
    Bill - you have fax! ;) Bill if i'm right, something is telling me the EBC Red Stuff part number for what i have is, DP31110C. I have a PDF version of the EBC catalogue with all pads they supply with pictures and dimensions. It also shows what car/caliper it goes for. The DP31110C comes under the Brembo Racing Caliper range. Let me know.
    Appreciate your help guys.
  18. badger5
    9,502
    2,002
    no fax mate.. Just chasing demon now.. nothings coming thru.
  19. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    No worries, i've found a way to send by email so i'll do it now to the email address you provided above.
  20. badger5
    9,502
    2,002
    not the same size pad as LCR's
    LCR one below:
    the number you posted up
  21. badger5
    9,502
    2,002
    if its a thicker version of a leon pad then a pug 406 coupe is thicker..
    as below
  22. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    The number i posted up is this one...... it's also printed in the EBC pdf catalogue i have.......
  23. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
  24. mk1chopper
    1,092
    12
    According to the ebc website the part no you posted returns a pad with dimensions of 123x44x17 and is for a db7 and other high performance makes (F40, F50 Audi R8)
  25. badger5
    9,502
    2,002
    Its listed as this one on my search..
    DP31110C - EBC Redstuff Brake Pads ' Both Wheels '
    Be the first - write a review
    Type: Car Brake Pads
    Someones catalogue listing is wrong!
    regardless of that, it is not the same pad as a leon cupra-r
  26. badger5
    9,502
    2,002
    GTV Alfa..
    DP41031R - EBC Yellowstuff Brake Pads ' Both Wheels'
    lol - so many to choose from..
    that image you scanned and sent, is 1:1 scale yea?
  27. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    lol i'm so confused with these pictures. Your one says 123mm and mine is 132mm length??
    The picture i sent you Bill is exactly how i drew it here. Is it measuring 132mm length when you put a ruler on it? If so then that's okay then. I just popped it into the scanner and hit send so it should go through as original.
  28. ben_turbo1
    ben_turbo1 Member
    181
  29. badger5
    9,502
    2,002
    your image is the same 132mm size you posted yes.
    to answer your earlier question, the pads are not like lcr's at all
  30. badger5
    9,502
    2,002
    i have sent the picture to my ferodo distributor to see if they can match it up
  31. jojo
    28,907
    3,563
    Should have got some LCR Brembo's Troopa. lol
  32. finesse
    finesse Active Member
    2,805
    oh dear
  33. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Thank you Bill, really appreciate that!
    Yes LCR Brembo's would have been alot easier but oh well! When we figure out where these are from and they go onto the car then maybe people will start to find what i have and put them on their S3's too, especially if they're cheaper than other Brembo options.
  34. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Here's pics of my Brembo's as requested (fresh from the painters might i add!) You will see calipers, adapters, and 1 pad (yes i do have 4 pads lol) ..........
    Jay
  35. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Very nice, they are similar to the lcr,s although i think they split in half , how wide are your discs?
  36. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
  37. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Thanks Dave, the discs which came with the kit are LCR discs. 323mmx28mm.
  38. s3dave
    10,110
    736
    did you not fancy trying the red stuff? my mate has them on his car with no probs....
  39. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    I heard they're no good and eat into your discs easily? Even if i put the red stuffs on, when it comes to getting new pads, i'd still be stuck! I need to get everything figured out now before it goes on the car.
  40. thorsy22
    thorsy22 Member
    308
    Seeing as it hasn't been mentioned I'll throw the spanner in the works, are these definately the right pads for those Brembo calipers?
