my a6 keeps locking itself is this normal?
bigblokey0 Jul 9, 2006
  1. bigblokey0
    bigblokey0 Member
    745
    ill be doing something in the car then ill shut the door walk off come back and the car has locked itself :confused:
  2. mickey_a6
    mickey_a6 Member
    126
    Haven't noticed that - but if I unlock it and don't then open a door it does re-lock itself within a couple of minutes.
  3. bigblokey0
    bigblokey0 Member
    745
    yea thats what i was on about i timed it after 1 min it locks it self
  4. madvw
    madvw Active Member
    2,489
    I know that most newer audis are supposed to re-lock themselves after 60 seconds if you've unlocked the car with the remote, but not opened the door. Its supposed to be in case you accidentally unlocked your car.
    I'm not sure why your's is re-locking despite you having opened the door though? Perhaps one of your door switches is stuck and permanently registering closed? Do you have the DIS on your car? - if so does it show the relevant door open symbol when you open each door or the boot?
  5. bigblokey0
    bigblokey0 Member
    745
    no it only locks if ive closed the door
  6. Marks
    Marks New Member
    9
    My 98 A6 is the same..... can be a problem if you've left the keys on a seat or in the boot while you're unloading etc.
  7. Nelson_R32
    Nelson_R32 Member
    305
    Sounds like a faulty microswitch in the door lock. Have you had any readings saying your o/s door is closed when its open, or showing that all four doors are open etc?
  8. bigblokey0
    bigblokey0 Member
    745
    theres nowt wrong it just locks itself if you forget to lock it
  9. scusse
    scusse New Member
    I have had same problem. Vindis Audi of huntingdon could not find fault but after discussing problem. it appears I don't use the car enough so the motor sticks:ermm:
