My A4 1.8TQ "Evolet"
Mäki Feb 15, 2009
  1. Mäki
    Mäki Guest
    I wanted to start a thread about my car to get some opinions about it, feel free to say anything you like about the car.
    I'll also make this thread to a little project.
    And I'm sorry for the spelling!
    Here's the picture from the ad, bought it 2 days later, june 6th -08.
    Interiour.
    And this is how she looked from august.
    Then it became winter and the ice came!
    Then the turbo gave up, so I decided I would go a bit further with the project and this is now, she's quite sad:sorry:
  2. Adam-D
    Adam-D Member
    457
    whats the plans for it
  3. Siena
    Siena Active Member
    2,626
    Nice car, I admired it too on Audizine.
  4. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Loving this pic.
  5. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Buy my 415bhp S4 engine (94k miles) off me!
  6. Mäki
    Mäki Guest
    New turbo, manifold, VR6 throttle, 3" downpipe, FMIC. And there will be some other small things as well.
    Thank you, love your car as well!
    Yes, he's a very good photographer!
    Can't afford that, and it's an all day car so it would be much work to change engine every year. :)
  7. CraigG
    CraigG Member
    190
    is the an M3 CSL rear spoiler? or is it custom fab'd? looks exactly like what im wanting for mine.
  8. Mäki
    Mäki Guest
    That's a rieger spoiler that I molded into the trunk, it was the only way I liked it :thumbsup:
  9. jcb
    jcb Active Member
    4,132
    13
    nice.
    what turbo? why VR6 throttle body out of interest?
  10. aragorn
    18,579
    868
    I presume its larger?
  11. Mäki
    Mäki Guest
    I bought a quite cheap turbo just to try if it will hold up. And the VR6 tb is bigger than the stock one.
    Exacly!
    Pics of those parts.
  12. jcb
    jcb Active Member
    4,132
    13
    looks good, what A/R or trim is it?
    reason I ask about the TB is that the general consensus from people running much larger turbos (GT35 etc) at very high power (500bhp+) is that the Throttle body makes little difference in power output.
    there are much more restrictive aspects of the inlet tract than the throttle body.
    I would send you a link to a very interesting trhead but the search function on Vortex is down.
  13. Mäki
    Mäki Guest
    I'm sorry but you will have to excuse me.
    But what do A/R mean?
    And I'm not really sure what you mean about " much more restrictive aspects of the inlet tract".
    But the maf will be modified to 3,5", it will be a new air filter and the piping to and from fmic will be all new also, the intake manifold will be just a little bit modified to match the tb better.
    Again, sorry for my english.
  14. Oranoco
    Oranoco Well-Known Member
    3,994
    408
    Love it.
    It looks spot on. Subtle but different without being too much.
  15. Mäki
    Mäki Guest
    Thank you, s4 sideskirts is on the "to buy" list also:happy:
  16. Oranoco
    3,994
    408
    Not just me with an ever growing shopping list then.
    Mine was supposed to be a daily hack for the work run.
  17. Mäki
    Mäki Guest
    Mine still is and will still be a all day car (when the engine is running again ofc), but I always find new things to do. But who said everyday cars couldn't be fun?:whistle2:
  18. jcb
    jcb Active Member
    4,132
    13
    the A/R gives the ratio of the turbine/compressor wheels to the housing and gives an indication to the flow capability of the turbo. usually expressed as a decimal less than 1.0
    i.e GT2860 turbine (exhaust) A/R 0.56
    the restrictive bit was about the inlet system as a whole. Excluding the MAF as that needs to be bigger to feed the turbo, but there no point having a huge 3.5" throttle body if your intercooler outlet pipe or any I/C tubing is 2.5" or smaller than the TB.
    your most restrictive point is where your pressure and limitations will be.
  19. Mäki
    Mäki Guest
    Okey! 0,63 A/R.
    Well, the IC tubing will be the smalles part, but I got the tb free, so I don't loose anything to use it.
  20. jcb
    jcb Active Member
    4,132
    13
    good deal.
  21. Mäki
    Mäki Guest
    So, hope this mani will do it's job now, I'll have som friend who's a welder to check it before I mount it.
  22. Broken Byzan
    13,237
    465
    I have loved this since i saw it on the 'Zine , in fact it inspired me to get the LED tails too.
    Is that turbo an Ebay jobbie??
  23. Mäki
    Mäki Guest
    Thank you :sm4: That's nice, have you mounted the led's yet?
    I didn't buy it from ebay, but it is a cheap turbo, so this is most to learn how to build. But I think the turbo will work, I'm not plannin any huge hp.
  24. Broken Byzan
    13,237
    465
    Yeah they are on, look very good IMHO The best aftermarket ones yet!!!!
    It looked like a non Garret, but if yo are not going to push it too hard then it should be ok i recon
  25. Mäki
    Mäki Guest
    Yes, they are great, good fitting and everything!
    Ah I se, yes, I think it will hold up good with not to much pushing.
  26. jcb
    jcb Active Member
    4,132
    13
    that looks like an eBay chinese stainless special.
    I bought one a whie back but they had cunningly photographed it so as not to show the dreadful welding under the merge collector.
    wil do the job if you can get it checked over and stop it cracking.
  27. Mäki
    Mäki Guest
    Ok! I just gave it to a welder to weld on a T25, and I asked him to check all the welds when he was on it. :sm4:
  28. Mäki
    Mäki Guest
    The head is of now.
    Not to bad :)
    I miss the driving :sob:
  29. Mäki
    Mäki Guest
    I orderd megasquirt today! A lot better when I'm tuning and changing my mind often :)
  30. Mäki
    Mäki Guest
    So I got the manifold from my neighbour today, he replaced the T3 with a T25. I also tested how it would look with the new wastegate on. I'll mount the head tomorrow.
    And I will adjust the boost with this.
  31. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    looks good so far
  32. Mäki
    Mäki Guest
  33. frankiejr
    frankiejr Member
    53
    looking interesting!
  34. Mäki
    Mäki Guest
  35. Markey
    Markey Active Member
    2,175
  36. Mäki
    Mäki Guest
    Today I took her out for the first time since she broke i January! It was SO nice :)
  37. fermented
    fermented New Member
    19
    started life looking exactly like my ugly 1.8tq, but now it looks fantastic :(
  38. Broken Byzan
    13,237
    465
    How does she go on that new turbo? And is the MS on yet?
  39. Mäki
    Mäki Guest
    It's not ugly, just not different ;) Thanks by the way!
    I don't have the tuning on yet. I couldn't afford the rest for the moment, I'll start with it again sometime at the winter.:unsure:
  40. Mäki
    Mäki Guest
    Well here it goes!
    My car the day after the accident (no one got hurt).
    Stripped it down, it wasn't so bad.
    New and fresh.
    Also quite new [;)]
    These are used though.
    Bye bye interiour.
    This is unnecessary [:p]
    Not broken VS broken.
    And the fan is mounted.
    Need to repair the radiator [>_>]
    Hmm [:D]
    And this is the last picture I got.
