My a3 sport still loosing water
Rallynut87 Feb 27, 2013
  1. Rallynut87
    Rallynut87 New Member
    Hi bad news lifted the bonnet this morning to top the pissers up and noticed the the coolant had drop slightly again, I've only had it back 2 weeks from the garage I brought it from, after the 1st time it went in they replaced the egr cooler, came back and still lost water, then went back and the said the head gasket had gone so they took the head off and sent it away to be pressure test properly ad get it overhauled and skimmed, as they were aware of the dreaded head cracks on that model engine, when I picked it up they said it may still use a little water as the system it purging, is that normal, but they never changed the water pump nor the cam belt as they said because its a warranty claim the warranty company won't pay for the cam belt, ****ers, but that's not the point my point is should it of used a little water like they stated, if not what else can it be that's leaking, rads fine, and the matrix is fine, unless its the water pump, or worse still the head is actually cracked and they are covering there own ****, help me cos this is driving me mad as I have always been a audi fan but this is making me want rid,
  2. Rallynut87
    Oh nealy forgot, should the system be pressurising, because the water level does drop but when te cap is loosened it hisses and the level pops back up to where it should, but this morning it did hiss but the level only went up to the min mark, should it be doing this if not why when its had all that work done, and why is it still leaking
  3. A3Craig
    A3Craig Member
    85
    Only check the coolant level when the car has been off for a while (atleast an hour) to allow it to cool and water to settle and yeah it will have pressure in when the coolant is hot, avoid opening when hot as you could quite easily burn yourself when opening due to the pressure,
    when having work done on the coolant system you do need to top the water up a few times afterwards but only a couple of times normally
  4. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    i had small leak ended up been the water pump was leaking but never had any water on floor and only lost a little amount .
    are you sure they done the head ?
  5. Rallynut87
    Yeh I have been opening it when cold, at least it's normal for there to be pressure in it, and for it to raise when opened, ill just keep an eye on it,
