My a3 died on my way home tonight - Now it wont start at all :(
TDIDAN Dec 19, 2011
  1. TDIDAN
    TDIDAN New Member
    Cars a 58 reg audi a3 2.0 tdi 140 cr latest shape.
    My cars been pretty much faultless but today i was driving home steady in traffic and noticed esp light flashing by the time i had noticed that the engine management light was then on too and the coil light flashing, herd a funny clicking sound coming from dash too but that could have been esp or something, put my foots to the floor no power, tried to restart and eventually restarted drove another kilometer it was running ok but warning lights still on cut out twice one and managed to get to my driveway. Once on the drive way i started the car ran ok then cuts out and now it wont restart at all just spins over but doesnt fire. Some im thinking its a sensor or problem with ecu heres the vcds readout if anytone can help tell me what it means:-
    Also i do remember seeing the dpf light come one for a second but thb its always done that if you stall it a restart it whilst moving
    btw the faults recorded with the rear light are from a few weeks back from when it went into the body shop for the rear quater to be repaired / painted i think so nothing to do with this.
    Hope someone can shed some light on what these faults mean ? :hi:
    Chassis Type: 1K0
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 77
    VIN: WAUZZZ8PXxxxxxxx Mileage: 39790km/24724miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
    Component: R4 2,0L EDC 0000SG 3066
    Revision: 13H01--- Serial number: AUX7Z0H6FNN05I
    Coding: 0000072
    Shop #: WSC 83968 026 674567
    VCID: 75EAE38A239B20B4
    8 Faults Found
    004997 - Control Module Malfunction - Lambda Sensing Circuit
    P1385 - 000 - - - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100000
    Fault Priority: 2
    Fault Frequency: 31
    Mileage: 39788 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1840 /min
    Speed: 79.0 km/h
    Lambda: 95.5 %
    Mass Air / Rev.: 525.0 mg/str
    Voltage: 1.800 V
    (no units): 0.0
    Voltage: 1.275 V
    008482 - Accelerator Position Sensor (G79): Signal too Low
    P2122 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 7
    Mileage: 39790 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 18:41:26
    Freeze Frame:
    RPM: 1679 /min
    Speed: 73.0 km/h
    Load: 0.0 %
    Voltage: 13.91 V
    Voltage: 0.684 V
    Voltage: 0.304 V
    Bin. Bits: 0 01 0
    008487 - Accelerator Position Sensor 2 (G185): Signal too Low
    P2127 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Mileage: 39790 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 18:41:26
    Freeze Frame:
    RPM: 1679 /min
    Speed: 73.0 km/h
    Load: 0.0 %
    Voltage: 13.91 V
    Voltage: 0.684 V
    Voltage: 0.304 V
    Bin. Bits: 0 01 0
    001576 - Fuel Pump Relay Control Circuit: Short to Ground
    P0628 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 39791 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 18:42:28
    Freeze Frame:
    RPM: 0 /min
    Speed: 45.0 km/h
    Voltage: 12.46 V
    Pressure: 80.0 bar
    Inj. Quantity: 0.0 mg/str
    Lambda: 30.0 %
    Lambda: 19.7 %
    005000 - Control Module Malfunction - DBW Throttle Monitoring
    P1388 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 39790 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 18:41:08
    Freeze Frame:
    RPM: 1311 /min
    Speed: 54.0 km/h
    Load: 0.0 %
    Voltage: 13.83 V
    Voltage: 0.760 V
    Voltage: 0.380 V
    Temperature: 17.1°C
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 39790 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 18:41:08
    Freeze Frame:
    RPM: 1518 /min
    Speed: 53.0 km/h
    Load: 0.0 %
    Bin. Bits: 0000000
    Hex Value: 0xFF2A
    Hex Value: 0xFF01
    001027 - EGR Valve (N18): Malfunction
    P0403 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 39790 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 18:41:11
    Freeze Frame:
    RPM: 1104 /min
    Speed: 42.0 km/h
    Load: 0.0 %
    Load: 14.9 %
    Lambda: 15.8 %
    Mass Air / Rev.: 520.0 mg/str
    Temperature: 85.5°C
    001575 - Fuel Pump Relay Control Circuit: Malfunction or Open Circuit
    P0627 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 39790 km
    Time Indication: 0
    Freeze Frame:
    RPM: 161 /min
    Speed: 31.0 km/h
    Voltage: 13.15 V
    Pressure: 72.0 bar
    Inj. Quantity: 19.8 mg/str
    Lambda: 30.0 %
    Lambda: 25.3 %
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0104
    Revision: 00H35001
    Coding: 13424012092400FBC80F02E8901E00823800
    Shop #: WSC 06314 000 00000
    VCID: 74ECDE8E28E139BC
    1 Fault Found
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 185
    Mileage: 39788 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 18:39:00
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 12800
    Count: 8196
    Count: 50505
    Count: 1
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
    Component: KlimavollautomatH09 0100
    Revision: 000885 Serial number: 8P0820043BH
    Shop #: WSC 00000 000 00000
    VCID: 73EEDD922DEF3E84
    No fault code found.
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000008699708
    Coding: 15A82F07A0141380EF00001C4F00000000084E0564010003002000000000
    Shop #: WSC 06314 000 08192
    VCID: 48945A7E04E9ED5C
    Part No: 8P2 955 119 F
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    4 Faults Found
    03099 - Right Rear Turn Signal Lamps (M8)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 39242 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 11.95 V
    OFF
    ON
    OFF
    OFF
    OFF
    00988 - Lamp for Brake Light; Right (M10)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 39242 km
    Time Indication: 0
    Date: 2011.11.26
    Time: 15:48:00
    Freeze Frame:
    ON
    Voltage: 11.55 V
    OFF
    ON
    OFF
    OFF
    OFF
    00985 - Right Tail Light (M2)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 39242 km
    Time Indication: 0
    Date: 2011.11.26
    Time: 15:48:00
    Freeze Frame:
    ON
    Voltage: 11.40 V
    OFF
    ON
    OFF
    OFF
    OFF
    01506 - Bulb for Rear Fog; Right (L47)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 39242 km
    Time Indication: 0
    Date: 2011.11.26
    Time: 15:48:00
    Freeze Frame:
    ON
    Voltage: 11.45 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 F HW: 8P0 919 475
    Component: PARKHILFE 4K H06 0102
    Revision: 11001001 Serial number: 52330819707905
    Coding: 000003
    VCID: 4182475A27D3DC14
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142413039303030384A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 49925F7A1FE31454
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
    Component: KOMBIINSTR. VDO H15 0830
    Revision: D0H15005 Serial number: 2246H005003556
    Coding: 0004428
    Shop #: WSC 00503 210 83701
    VCID: 39722FBA4F0384D4
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K087150884
    Coding: E9A01F061006020101
    VCID: 356A238A631B60B4
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H15005 Serial number: AUX7Z0H6FNN05I
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0060
    Coding: 0000636
    VCID: 438E4D523DCFCE04
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 233 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5000F6BAA53F4C
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980200002186D2D8505489AC637
    Component: Sounder No Answer
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    2 Faults Found
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    00849 - S-contact at Ignition/Starter Switch (D)
    008 - Implausible Signal - Intermittent
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
    Component: AB2 SUBWOOFERBOXH30 0160
    Revision: 00006 Serial number: 30659850214948
    VCID: 346C1E8E686179BC
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000636
    VCID: 448C4E4E38C1C93C
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 M HW: 8P0 035 195 M
    Component: R Symphony2+ H04 0270
    Revision: 00H04000 Serial number: AUZ1Z4H7176712
    Coding: 0730211
    VCID: 3C7C36AE4031B1FC
    1 Fault Found
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 33
    Reset counter: 182
    Mileage: 33146 km
    Time Indication: 0
    Date: 2011.07.26
    Time: 15:36:28
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 N HW: 8P0 862 335 N
    Component: FSE_256x BT H34 0520
    Revision: 00000000 Serial number: 00000005020108
    Coding: 0001222
    End ---------------------------------------------------------------------
  2. Broken Byzan
    13,237
    465
    Seeing it's a multiple failure, I'd say check your fuses, or an earth
  3. TDIDAN
    TDIDAN New Member
    Turns out water has entered the ecu as its located under the wipers :(
    £750 + vat just for the part from the dealers
  4. MTRL
    MTRL Split Grill!
    459
    52
    Very similar thing happened to mine on the drive home just after I brought it.
    For me it was a Mass Air Flow (MAF) problem.
    Driving home from Manchester to Birmingham I lost power in the fast lane.
    Pulled it over and had ECU and ESU lights on, wouldnt start back up.
    Left it a few minutes and it started up again.
    10 minutes down the motorway it all happened again....ECU then ESU then it entered into limp mode.
    Got it home, took apart the air filter and cleaned all connections/sensors and Reset the ECU to clear the codes.
    Not had a problem since
