my a3 2.0tdi has the strangest problem
davidfox280585 Jul 3, 2013
  1. davidfox280585
    davidfox280585 Member
    107
    its a 2005 sportback 2.0 bkd
    now the issues,
    1. alarm goes off when stood
    2. randomly says boot open then when i drive off its ok and rear wiper decides to work only when driving
    3. traction only light comes on randomly and turns itself off after cycling ignition
    4. the clocks went fully off while driving for 5 seconds then turned back on
    5. cruise control works when it wants 95% time its ok
    ive stripped the bootlock but there different on the sportback 1 sealed unit,
    no signs of leakage in there anyway
    the battery looks fairly old so will be changing this,
    ive checked every fuse
    im at my witsend with the car
    any suggestions?
  2. sliced
    sliced Drive safe, stay alive.
    1,524
    327
    Scan with vcds?
  3. davidfox280585
    107
    ive done it flags approximatelt 40 codes saying lost connection with interface,
    ive ordered a new boot switch from audi,going o try this and a new battery and see where i go from there
  4. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    How olds your battery? Could be that whilst your having issues with pretty much everything electrical lol, and the rear wipers are common to leak on the A3 so check for damp around the rear
  5. Mikemc
    1,024
    37
    And sorry didn't read the last bit about the battery!
  6. davidfox280585
    107
    thanks for the reply mike,
    its an original battery,and ive checked the rear wiper all is perfectly dry and connected,no signs of leakage at all around there
  7. davidfox280585
    107
    new battery hasn't cured it, will try boot switch on friday
  8. Pimpinthepidge
    Pimpinthepidge Member
    30
    Had a polo that did strange stuff, windows wouldn't work, head unit would go off, turn off then back on all would got ok but pretty much everything electrical was playing up, had it in vw at 80 pounds for an hours labour they said it was alternator, changed that still did it. I then sold the car to a friends dad who found the clocks to be playing up, he changed the clocks and hey presto all good. Have you had it plugged into vag com?
  9. NHN
    29,284
    1,695
    Logged codes shown on here, would help your request for help.
  10. davidfox280585
    107
    fixed
    bootcatch caused every issue £35 new from the stealers
